    Making a horn using Shape Bender
    14 Posts 7 Posters 1.6k Views 7 Watching
      Matsuo
      Hi there,
      I'm trying to make a round horn using a cone, arc and the Shape Bender plug-in. I've come quite far, but I'm not there yet. The file I've attached will show how far I've gotten. Any advice on this? Thanks!
      horn_shape.skp
      • Chris FullmerC Offline
        What kind of horn are you trying to create? A rhino horn, or a trumpet like horn? πŸ˜„
        Looks like you almost have a great rhino horn going there.
          dedmin
          @matsuo said:
          Hi there,
          Better to use FredoScale radial bend
          • numbthumbN Offline
            numbthumb
            Hi, folks!
            What are the advantages of these tools over 2 Faces + Path?
            Thanks in advance.
            Comfortably numb...
              They each do differnr things. Fredoscale is an entire suite of tools that include sheer, twist, taper, etc. It's a great tool for changing the shape of objects.
              I wrote shape bender to help bend shapes to match a desired bend. So if you have a curvy wall and want to apply 3d text to it (like a string of words) and you want them to bend to follow the curvature of the wall, then use shape bender. That is precisely what I had in mind when I wrote it. But it is much more versatile than just that too though.
              I would recommend downloading and playing with both of those plugins.
                numbthumb
                Thanks for your reply, Chris.
                Your Shape Bender and Fredo6Β΄s FredoScale have already saved me lots of frustration. Needless to mention the effort and hard work you folks put into it, providing us with extra functionality in SU.
                I was just referring to this particular "horn" case and possible differences in bending a cone vs. making a curvy horn from the start.
                If there are any, of course.
                Thanks again.
                Comfortably numb...
                  😳 😳 Hehehe, oops!
                    Matsuo
                    Right...I've tried using Radial Bend by Fredo, and I'm almost there, except for 1 problem...after the bending holes appear in the horn! Any suggestions?
                    horn_shape2.skp
                    • Alan FraserA Offline
                      Alan Fraser
                      Depending on how much you want to bend the shape, one suggestion would be to use Spiralizer and import the resulting dxf. That's its sole function...to bend horn shapes into a tight a spiral as you want.
                      3D Figures
                        dedmin
                        First, there is a plugin to make shapes like cone, torus and etc.
                        Play with the parameters - press tab. Try this
                          Koosie van Tutte
                          i don't know if this will help, but i bent a house and got the same (and extra) problems. after exploding everything (bomb all) and making it a group again, it worked without any trouble.
                            Matsuo
                            Playing with the settings seems to do the trick! Thanks to all for the help!
                            Cheers
                              Alternatively for simpler shapes like a horn try Extrude Edges by Edges...Horn_EEbyRails.pngHorn_EEbyRails.skp
                                Matsuo
                                Sorry for the late reply!
                                Everything worked out in the end πŸ˜‰
