    Scifi Sketchup Modeling
    454 Posts 57 Posters 215.0k Views 57 Watching
    • L
      liam887
      Missing a few little details, changed the configuration a bit but thinks it looks better this way round.
      VISIT MY ONLINE GALLERY
      • boofredlayB
        boofredlay
        Great work. Keep it up.
        • MarianM
          Marian
          πŸ‘ 😎
            dolphus
            Great detail modeling thanks for sharing πŸ‘
            • C
              Cyberdactyl
              Very nice collection Liam.
              You're a busy fellow!
              One odd thing though, that walkers profile is quite suggestive. 🀣
              By the way, your elevator made me think of a game I played 7 years ago or so, called I-War, Independence War.
              Far and away the most physics-realistic game...probably to this day. Anyway, it has a cool elevator in the game.
              • L
                liam887
                Been busy with uni but just got past the first deadline so nothing to d for a while. Been working on a more realistic model maybe set a hundred years from now.
                All the physics is about right so far taking into account the spin of each floor in each module to create so some gravity that is comfortable for humans, the right types of fuel and how much is needed verses the ships weight, how many radiators etc, I dont have a clue myself but some people cleverer than myself have done a lot to tell me what goes where lol.
                Anyway here it is with a bit of PP in photoshop to get the details out. Its about 100ft high and 650 ft long at the moment, but its far form done and this wil only be a small part of the finished model.
                • L
                  liam887
                  hahahaha didnt even clock on to that I didnt put a little articulated arm there for that same reason lol. Ahh well once the bulldog rails and lights are on it might look less like a penis!
                  EDIT: ahh yeah I checked out the video of the elevator it looked good especially when it goes through the clouds. You tube tho at the moment is a nightmare. I know my internet is fast but you tube takes years to buffer even the smallest videos, i can stream HD form the BBC download a game form steam in minutes but youtube is sooooooo slow. I know its not just me ive been reading all over the internet about people with similar problems.
                  • L
                    liam887
                    update
                      dolphus
                      Well done! Liam887....this is the sci fi modeling that really pushes some of my buttons "realistic space vehicles and satellites" when the Railway itch is scratched this is what i would like to do thanks for the inspirational nudge πŸ‘
                        sepo
                        These look very good Liam. πŸ‘
                        • MarianM
                          Marian
                          Wow, that is just AWESOME Liam. πŸ‘
                          • L
                            liam887
                            thanks everyone!
                            Hey by the way sepo is there a way to do bump maps in podium? Ive got a really good texture for the solar panel cells and ive made a bump map but have no idea how to make it work!
                              sepo
                              Yes of course. have a look here. http://www.suplugins.com/index.php?p=page&page_id=materials
                                Simon B
                                Liam, these are excellent models.
                                I like the solar explorers especially. I am working on similar stuff for a game idea.
                                Check out this site for some in depth technical info for developing realistic spaceships.
                                I think the maximum speed for generating 1G artifical gravity by centrifuge is 2 revolutions per minute (any faster and your crew would start puking due to awareness of spin: the coriolis effect). This rotation speed for 1G requires a minimum diameter of nearly 500 metres - half a klik! A slower spin would need a larger diameter to maintain 1G - if you see what I mean.
                                You could have spins at equivalent martian or lunar gravities though.
                                I'm a fan, keep it up.
                                • L
                                  liam887
                                  If you want to have ground-gripping joe-smoe man-on-the-street untrained people in absolutely no danger of spin nausea (i.e. 1 RPM), you'll have a microscopic 0.02g
                                  If you don't mind if the ground-grippers might initially have some nausea but get over it, you can go up to 3 RPM and have 0.2 g (about Lunar gravity)
                                  But if you have trained astronauts who have undergone spin acclimation, you can crank it up to a full 6.5 RPM and have 1.0 g.
                                  (5 RPM will give you 0.5 g)
                                  These calculation are correct but it all depends on your diameter form the center rotators. As I am only 70ft from the center in the modules I have made so far these calculations are relevant to me!
                                  Basically you can work out the spin ratio for any size module using this equation, Its straight from NASA and has been researched:
                                  Ca = 0.011 * Cr2 * Cl
                                  Cl = Ca / (0.011 * Cr2)
                                  Cr = sqrt( Ca / (0.011 * Cl))
                                  where
                                  Ca = centrifugal artificial gravity acceleration at point X (m/s2)
                                  Cl = distance from point X to the center of rotation (m)
                                  Cr = rotation rate at point X (rotations per minute)
                                  Remember that 1.0 g is 9.81 m/s
                                  Notice that as point X is moved further from the center of rotation the artificial gravity increases.
                                  To have a comfortable 1G you would need a rotating section of at least 300ft. that is it would be acceptable to any normal person without prior training.
                                  • C
                                    Cyberdactyl
                                    Thanks for that site Simon.
                                    I think I have most of that information, but it's across a dozen sites.
                                    It's kinda cool to find it all collected in one place.
                                      Your work is very creative and the detail is amazing.
                                      The Space Explorer reminds of the alien ship in Arthur C Clarke's Rama Series. He too mentions all about spin/gravity and from what I remember that ship even had an ocean!
                                      Keep up the good work
                                        11zulu
                                        Mornings All
                                        liam887, excellent modelling as usual.
                                        You might want to head over to
                                        BunnyCDN Node LA1-1001
                                        (www.bambam131.com)
                                        its the site of David Robinson, he is a most excellent artist
                                        using Bryce of all things to model, and I am sure will give
                                        you a lot of inspiration as to what real world space craft
                                        concepts would look like.
                                        For Actual Concept images you might want to check out
                                        secretprojects.co.uk, as they have a Space Forum.
                                        Regards
                                        • L
                                          liam887
                                          Nice!
                                          Thanks for that link, its got some pretty good designs and in bryce too, I though bryce was pants, I was obviously wrong!
                                          I find lots of help at scifi meshes forums, there are always people willing to help as I posted previously somebody helped me work out how to achieve gravity that will be comfortable, the amount of fuel it will need for the range it has, how much consumables how the air recycling works etc etc.
                                          Im pretty pleased so far and in keeping the design as real as possible its actually looking better then the more far off scifi designs I have done before!
                                          As for 'Check out this site for some in depth technical info for developing realistic spaceships.' the guy whose site it is, is a member of scifi meshes and is giving me advice, actually he was the one who worked out the gravity for me!
                                          And I look forward to seeing your models dolphus when you have finished your trains! After this model is complete I might make a pack of ship parts, each module etc etc. Then can put them together in different arrangements sort of like spaceship lego lol!\
                                          There will be updates later today I just wanted to do a lot more work before I posted an image again!
                                          EDIT: New pic
                                            Simon B
                                            Wow, the internet is getting smaller and smaller all the time.
                                            Glad to be of help.
                                            • 22
                                            • 23
                                            • 3 / 23
