    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 262.5k Views 32 Watching
    • soloS Offline
      I'd think Vue would be able to use this if an exporter could be worked out, there is a script that Alex made which exports SU camera's into Vue.
      Currently Vue is interchangeable with XSI, MAX and C4D as far as camera animations go.
      Vue has a bezier type camera path creator.
      • soloS Offline
        Actually I thing that if you can make the path editable, I could use it in Vue as a camera path.
          In a rendered TwilightRender Animation it processes the Model's Scene Tabs and 'betweens' between them... so an additional option/button to 'Add Frames as Scene Tabs' which then adds the needed page (scene) tabs would be very useful too...
          • Chris FullmerC Offline
            Do we know how many scenes a model can have before it explodes? Its easy to make thousands of frames with this plugin. If I convert them all to scnes, is that going to do some massive damage? or is SketchUp ok with that?
            Chrs
            • soloS Offline
              I say try and see...what's the worste thing that can happen? Bugsplat? I get them often enough one more won't hurt.
                If your model dies with 1000 then set that as a limit ? ๐Ÿ’ญ
                • E Offline
                  Ecuadorian
                  Walkthroughs look best when the motion is slow and smooth, not jerky and with sudden changes. I've rendered SU animations with 50+ frames in-betweened between scene tabs, and they look good. I used only 18 tabs for a full minute of video. What matters is that the path must remain more or less smooth and not become too obviously polygonal. I used RickW's flightpath2 for that, and this Camera Recorder promises to be more intuitive. ๐Ÿ‘
                  -Miguel Lescano
                  • X Offline
                    xrok1
                    nice plug!
                    how does SP send animation to the render engine? it doesn't make scene tabs!
                    โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                      all right, I've finally got this updated with some substantial help from Jim who had to explain to me how to escape backslashes in windows paths.
                      This version I tweaked a few things that could work differently on a Mac. Please if any function does not work on a Mac (or PC too), let me know. I tried to test it all on my PC, but its possible some of the tweaks for the Mac might not have gotten worked out yet.
                      So here's whats new:
                      UPDATES v 1.7 Nov. 19, 2009
                      • Added the ability to export frames to scenes
                      • Script now remembers user settings from SketchUp session to session
                      When you click the export icon, you get to choose scene or images. So you can export to images like before, or export each frame to a scene. I think that will help get this animation to export to renderers like twlight Podium, VRay, Kerky, etc. I'd be interested in seeing a quick rendered animation if someone gets one done. I was imagining you could record at 15 frames per second. Then export to scenes. Then set you SketchUp model animation transition time to 1/15, which is 0.067. And to get a value below zero in the animation transition time in the model info window, it has to start with a 0. So .1 does not work. 0.1 will. Maybe you don't even need to do that, I suppose I really don't know how the renderers are using scenes to export their animations.
                      So anyhow, check out the new version. And of course let me know about bugs and problems, thanks!
                        Panga
                        Damn Chris !! This one rocks...It'll help me so much in my work in order to make quick preview of my animation path for my boss !!
                        Just another time saver. Thanks.
                          Great, glad it worked!
                          Anyone who renders have a chance to see if this new version helps make it work with renderers? Anyone?
                            rod1233
                            Hi Chris Fullmer
                            There is a problem I have please help
                            When I download clf_camera_recorder-v1.7
                            Knowing that I've downloaded in advance and did a wonderful job, but not what happened Lardy
                            A copy of the problem ๐Ÿ˜ž ๐Ÿ˜ž
                            Note
                            When I download clf_camera_recorder-v-1
                            The device Ballowavqp it
                            Please help in this problem
                            rode
                              It looks like you do not have the files put in the correct locations. In the plugins folder, you should have a single file and a folder
                              clf_camera_recorder_loader.rb
                              clf_camera_recorder <---FOLDER
                              And inside the folder you should have the file:
                              clf_camera_recorder.rb
                              along with all the icons.
                              So check to see if that you have everything installed correctly and let me know if it works.
                                rod1233
                                Hi Chris Fullmer
                                Thank you for the attention
                                And I would like to tell you in detail the problems of
                                At first you download the files as explained and you are quite successful and after two days .. got this error after you have downloaded the Camera Recorder v1.0
                                And succeeded in it and when I try to download Camera Recorder v1.7 the result is an error
                                I do not know what is wrong please help
                                I hope you send the file to my email
                                rod1233@hotmail.com
                                This image is when you download the Camera Recorder v1.0
                                This image is when you download the Camera Recorder v1.7
                                  rod1233
                                  Hi Chris
                                  I think the problem in the size of the file in the image
                                  clf_camera_recorder. employer
                                  Because I do I replace the file Shahu Camera Recorder v1.0
                                  The success
                                  Please help
                                    You should delete all camera recorder files. Then re-dnwload and re-install. See if that helps. I think that mighty do the trick. let me know how it goes,
                                    PS What is your native language?
                                      rod1233
                                      hi Chris
                                      I have deleted all the files and the files you have to re-descend again, and I encountered the same problem
                                      I do not know if the file size minus
                                      I repeat, when I put the files for the first time the result was quite successful, but know what happened to get that error
                                      I speak the Russian language
                                        Hi Rod, I still don't see what the error is. The files are where they should be, their sizes are correct. They are very small files. The size discrepency is normal and it is due to how Windows stores files tot he disk.
                                        Is SketchUp giving you an error? You have not posted any actual SketchUp error. If so, what does it say?
                                          rod1233
                                          hi Chris
                                          I can not succeed in this. I'm very sad for that ๐Ÿ˜ž ๐Ÿ˜ž ๐Ÿ˜ž
                                          And thank you for the efforts made by me
                                          I do not know where the problem
                                          Perhaps there may be settings in the program led to this error
                                          Thank you
                                            Rod, what is not working? Is it not appearing in SketchUp?
                                            Maybe it just needs to be enabled. Go to Window > Preferences > Extensions and make sure that Camera Recorder is enabled.
                                            See if that helps. Then let me know.
                                            • 3 / 7
