    [Preview] UVTools 0.2
    74 Posts 23 Posters 13.3k Views 23 Watching
    • EarthMoverE Offline
      EarthMover
      Looks pretty cool. I think TT is right about the bridge. Looks like you could potentially do it now using U3D, it would just take a few extra export/import steps. Whaat appears to have sped up the process.
      Never used U3D, but looks like a good investment, albeit a bit complicated with a lot of buttons. UV is something I could never really unwrap my head around. At least the unwrap UI in 3ds Max, which I find a bit intimidating. Hopefully this is simpler.
      Content Creator at Skapeup
      • plot-parisP Offline
        plot-paris
        come on whaat, enlighten us... 🎉
        is looking really good, this one. just had a project where I was fighting with textures on organic surfaces...
        • W Offline
          Whaat
          Hi all,
          I updated the first post with some explanation.
          I presume this should work also with other software, say Blender, which allows to save the UV-mapped OBJ model, am I right?
          Right now, the plugin will only work with U3D. I tried Blender but ran into some issues that were tricky to solve. Maybe in a future version, though.
          • W Offline
            Whaat
            @notareal said:
            With a quick look the unwrap3d do have a skp importer, but this is far better work flow.
            😮 Really? I'm not aware of a skp importer for U3D. Where do you see it?
            • W Offline
              Whaat
              Exactly! Without using the plugin, the process would be extremely tedious and frustrating.
              I was a bit overwhelmed at first with U3D myself. I had really used UV mapping software before so I was quite lost. There is a bit of learning curve here but there are also some good tutorials and documentation available.
              When you are trying to learn U3D, first just focus on the basics. First, learn to use the selection tools, then, try some simple UV methods like box, spherical, and cylindrical. One step at a time!
              • soloS Offline
                Dale, UU3D imports .skp, but no export available, thus your setup will be much better.
                Ultimate Unwrap 3D - File Formats
                Ultimate Unwrap 3D, UV Mapping. Ultimate Unwrap 3D is a standalone UV mapping software for unfolding and unwrapping 3D models.
                (www.unwrap3d.com)
                  dacad
                  Whaat i really don't care if this is going to be free or not, because i want that so badly!!I can't thank you enough for this effort for the comunity.
                  unwrap3d has a skp importer (it's on the compatible formats list, in the features webpage) but not a exporter so that will allways lead to problems (we all know how sk importers behaves...).
                  I would like to ask you one thing if possible, please try to do the blender version also, as you said, just because blender can also paint directly the mesh on the unwarped texture.
                  A full featured uv mapping in sketchup...SEE AND LEARN GOOGLE!!
                  A big thanks to you Whaat
                  Is it possible to donate beers (or whatever you prefer to drink) using paypal? 😉
                  • soloS Offline
                    However.....
                    It does NOT work on Mac's and there are issues with Vista, apparently it runs great with XP and windows 7.
                      dacad
                      Blender?!?
                        richcat
                        Looks like dream coming true. Can't wait
                        The other is Argile, which I have trying on and off for the past 2 years.
                          dedmin
                          PhotoshopCS4 can open .kmz files and you can paint the surfices and then export again to .kmz and open in SketchUP. Here a quick try
                            plot-paris
                            great suggestion. how did you do it exactly? can't seem to find an option to export it to kmz anymore...
                            that seems to be a great way to add detail like rust, stains, dirt...
                            but to actually wrap textures around an object it doesn't seem ideal to me...
                              dedmin
                              • N Offline
                                notareal
                                (www.unwrap3d.com)
                                Indeed, need to use some other format and import that back to SU.
                                Take look at the end of page "Third Party Plugins".
                                http://www.unwrap3d.com/u3d/downloads.aspx
                                Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                • jeff hammondJ Offline
                                  @solo said:
                                  However.....
                                  that's fine.. anyone without the required hardware/software can just upload here and beg someone to map it for them 😄
                                  • majidM Offline
                                    majid
                                    Whaat, your job is great , but even a simple improved uvmapping tool is appriciated enough, something to have a better cubic, and maybe more options for sylendrical and spherical mapping, maybe a "gost view" for mapping...or something...for me it hasn't been never any serius need to strange organic texturing, BTW your plugin is really great. thanx again Whaat
                                      kwistenbiebel
                                      @solo said:
                                      Sweet!!
                                      If it's a bridge, and free then I would hope Dale has a link for us users to purchase U3D where he can get some sort of commission. It would be only fair for both him and the company as this bridge opens up a huge market for them.
                                      If Whaat could also pay a visit to Asgvis, Next Limit and Random control, we would finally see some decent Sketchup bridges appear for the mainstream render engines. 😄
                                        pav_3j
                                        i need a new piggy bank...
                                        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                        • MALAISEM Offline
                                          MALAISE
                                          🎉 🎉 🎉 🎉 I can't wait , go ahead Whaat 👍 👍
                                          MALAISE
                                          • W Offline
                                            Whaat
                                            So, other than Blender, are there any other apps that you would like to see supported by this plugin? I am thinking more in terms of UV mapping apps than 3D modelling packages such as 3DS max, etc.
                                            • 2 / 4
