    Upgrade NotePad++?
    16 Posts 5 Posters 2.4k Views 5 Watching
      I always use NotePad++.
      You probably noticed I often use stuff like entities.each{|e|...}: I hadn't appreciated that {...} were so difficult to type on some non-English keyboard layouts !
      • Chris FullmerC
        And oddly Martin has not even come by to see if my fix worked for him....I guess he's away from his keyboard this afternoon (or evening or whatever).
          MartinRinehart
          @chris fullmer said:
          I guess [Martin]'s away from his keyboard this afternoon (or evening or whatever).Chris
          Mornings are my thing.
          I'm doing the tutorial. for e in entities do ... end strikes me as a lot more beginner-friendly than entities.each { |e| ... }. Guess I'll have to try some editors.
          There's an old saying, something like: "An editor a day keeps the productivity away."
          • Chris FullmerC
            But I think your usage of " do" might be incorrect syntax in any ruby editor. It looks like the do should not be included with the for loop.
            Programming Ruby: The Pragmatic Programmer's Guide
            (www.ruby-doc.org)
              hm.. it does look like the do is redundant in for ... in syntax... But Ruby doesn't throw any errors...
                MartinRinehart
                Tried SciTE. Excellent text editor. High marks for ".properties" files, one per language, that make it easy to customize.
                Downside: exact same bug as NotePad++.
                The two forms of for/in that load without errors are:
                for x in foo do ... end
                for x in foo # no do
                  Jim
                  That's odd because NPP and Scite (as well as many others) are based in the same editor core Scintilla.
                    Odd? They both use Scintilla and both have the same syntax issues?
                      Jim
                      Oh sorry - I mis-read Martin's post.
                      • Chris FullmerC
                        I guess I would recommend using it without the do, since ruby syntaxd seems to think its redundant (which I do find odd as it does not fit their other loop syntaxes).
                        Or if it helps, I learned the array.each do |e| ... endmethod first and I was able to understand it fairly quickly. And I hve zero programming experience outside of Ruby for Sketchup.
                        Another bonus to teaching that method is that all the API uses it, as apposed to the for in end loop. So it might help readers transition into the API smoother. But that is just a thought,
