    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Render this: SSS
    174 Posts 44 Posters 27.9k Views 44 Watching
      tallbridgeguy
      You might have a future in this kinda thing (ha!)
      great job and a fun learning tool.
      thanks solo!
      Nielsen
      http://www.tallbridgeguy.com/
      • E Offline
        Ecuadorian
        Pete, I just want to print those images and hang them on my walls! They're renderlicious!
        Best.Render.Challenge.Ever. Just 2 materials on 1 simple object help keep things fun.
        -Miguel Lescano
        • EarthMoverE Offline
          EarthMover
          Fun challenge! Here's my try. Multi-color SSS with smoked glass.
          Content Creator at Skapeup
          • dermotcollD Offline
            dermotcoll
            I'm bent over ready for an arse kicking!!!! Twilight with on an easy medium.
            When you burn your arse - you gotta sit on the blisters!!
              dermotcoll
              When I saw some of the images I just had a crack at it - couldnt believe it when it came out and it wsnt black - where do you guys get all the fabulous materials and how do you store them (what format)
                EarthMover
                Dermot and Tallguy, nice job rendering, although you are lacking any visible sub surface scattering. The idea behind the thread was to display your favorite render engines ability to perform a SSS (subsurface scatter), which is namely the scattering of light below the surface of a material. Light will usually either pass through an object completely (transparency), pass through and bend (refraction), bounce off (reflection), or absorb (sub surface scattering). SSS is dependent upon the physical density of an object and it physical rate of light absorption. Things in the physical world that exhibit this behavior are wax, soap, skin, milk, plastic, etc. If you notice in all of Solo's renders, you can vaguely see where the light has passed through the outer cube and shown a hint of the sphere within.
                It looks like you guys are using Twilight. Try using a SSS template with your materials and use spot lights or emitter lights instead of the physical sky. This will give a concentrated light source which the render engine can use to glean enough direct light bounces to perform the SSS.
                Here's a quick test with Fryrender....emitter within SSS.
                • E Offline
                  Ecuadorian
                  Next time you ignore kitty, the dog will pay.
                  -Miguel Lescano
                    tallbridgeguy
                    THanks obviously I am way off track here. I will try to figure out the SSS system using kerkythea.
                    Thanks for pointing it out to me. I'm still not sure how to do it but I will try and figure out.
                    Oh well sorry to clog the thread.
                    s
                    Nielsen
                      bytor
                      Cherry (flake car paint inside of) Coke - Twilight @ Easy 8 setting
                      Find the Cost of Freedom.....
                        EarthMover
                        s
                        No worries...all in good fun and a method for learning and comparison. Keep on trying and you'll get there before you know it. Wish I could help more with Kerky settings for SSS. Perhaps Miguel could lead you in the right direction.
                        • E Offline
                          Ecuadorian
                          Sure, I posted some settings here:
                          http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=356&p=2350
                          Actually, a lot of materials present Sub-Surface Scattering. Just put a strong light behind a slab of marble, a plastic toy, or a china plate. The human body has SSS, too; wax candles, paper, even wood has it. It's just that most of the time it's not that noticeable under normal lighting.
                          I made two 30-minute renders with Twilight, one with Easy 09 (aka MLT or Metropolis Light Transport) and another with Easy 10 (aka Bidirectional MLT). These popular render methods are also available in Indigo and other unbiased render plug-ins. Spot the differences between MLT and Bi-MLT:
                          MLT:
                          Bi-directional MLT:
                          Here's the file so you can check the settings used:
                          sss cat.zip
                          Pete, I believe SSS looks much more spectacular on a dragon statue or something similar. Do you have one around? šŸ’š
                          -Miguel Lescano
                          • soloS Offline
                            Pete, I believe SSS looks more spectacular on a dragon statue or something similar. Do you have one around?
                            I actually do, in fact I have a few. But the problem is they are only one material, and the SSS effect is only dynamic with a light behind technique, this way you can have two materials giving more options for SSS and not only the light trick. I wanted to have the option of having another material behind a SSS one, like veins under skin.
                            • X Offline
                              xrok1
                              hey guys, that would make an awesome preview object for Twilight's material editor!
                              nice job guys but i think that last one is the cats meow!
                              ā€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.ā€
                              • E Offline
                                Ecuadorian
                                I think Remus (Indigo), Brodie (Maxwell) and Pete (Vue) have shown the best SSS examples here.
                                -Miguel Lescano
                                • boofredlayB Offline
                                  boofredlay
                                  Twilight
                                  • E Offline
                                    Ecuadorian
                                    Another try with Twilight's Bi-directional MLT, this time using the plexiglass template for the outer shell.
                                    EDIT: A stacked version of all three previous Twilight Renders (MLT, Bi-MLT and Bi-MLT with Plexiglass) with some post-pro in the cat's eyes.
                                    -Miguel Lescano
                                      tallbridgeguy
                                      cool stuff
                                      Nielsen
                                        tallbridgeguy
                                        still cool!
                                        Nielsen
                                          tallbridgeguy
                                          Pretty cool Dermot! I thought you were sitting this one out.....(its pretty fun stuff)
                                          Nielsen
                                            tallbridgeguy
                                            I am using Kerkythea and I downloaded a number of their great material libraries. Since you have twlight I'm sure you have access to tons of materials on their forum.
                                            s
                                            Nielsen
                                            • 3 / 9
