    Render this: SSS
    174 Posts 44 Posters 47.5k Views 44 Watching
    • E
      Ecuadorian
      Sure, I posted some settings here:
      http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=356&p=2350
      Actually, a lot of materials present Sub-Surface Scattering. Just put a strong light behind a slab of marble, a plastic toy, or a china plate. The human body has SSS, too; wax candles, paper, even wood has it. It's just that most of the time it's not that noticeable under normal lighting.
      I made two 30-minute renders with Twilight, one with Easy 09 (aka MLT or Metropolis Light Transport) and another with Easy 10 (aka Bidirectional MLT). These popular render methods are also available in Indigo and other unbiased render plug-ins. Spot the differences between MLT and Bi-MLT:
      MLT:
      Bi-directional MLT:
      Here's the file so you can check the settings used:
      sss cat.zip
      Pete, I believe SSS looks much more spectacular on a dragon statue or something similar. Do you have one around? 💚
      -Miguel Lescano
      • soloS
        Pete, I believe SSS looks more spectacular on a dragon statue or something similar. Do you have one around?
        I actually do, in fact I have a few. But the problem is they are only one material, and the SSS effect is only dynamic with a light behind technique, this way you can have two materials giving more options for SSS and not only the light trick. I wanted to have the option of having another material behind a SSS one, like veins under skin.
        • X
          xrok1
          hey guys, that would make an awesome preview object for Twilight's material editor!
          nice job guys but i think that last one is the cats meow!
          • E
            Ecuadorian
            I think Remus (Indigo), Brodie (Maxwell) and Pete (Vue) have shown the best SSS examples here.
            -Miguel Lescano
            • boofredlayB
              boofredlay
              Twilight
              • E
                Ecuadorian
                Another try with Twilight's Bi-directional MLT, this time using the plexiglass template for the outer shell.
                EDIT: A stacked version of all three previous Twilight Renders (MLT, Bi-MLT and Bi-MLT with Plexiglass) with some post-pro in the cat's eyes.
                -Miguel Lescano
                • T
                  tallbridgeguy
                  cool stuff
                  Nielsen
                  http://www.tallbridgeguy.com/
                  • T
                    tallbridgeguy
                    still cool!
                    Nielsen
                    • T
                      tallbridgeguy
                      Pretty cool Dermot! I thought you were sitting this one out.....(its pretty fun stuff)
                      Nielsen
                      • T
                        tallbridgeguy
                        I am using Kerkythea and I downloaded a number of their great material libraries. Since you have twlight I'm sure you have access to tons of materials on their forum.
                        s
                        Nielsen
                        • T
                          tallbridgeguy
                          I looked on the kerkythea forum and found some more info on SSS. (actually today was the first time I ever heard of sss.)
                          s
                          Nielsen
                            dacad
                            Ecuadorian
                            If i'm not mistaken the BPT is better suited for interiors, other way there's no much diference between btp and MLT. You should try the two in a interior room with lighs coming from the windows with real glass just with sun to see the big diferences.
                            • T
                              tallbridgeguy
                              Is this kinda sss?
                              thanks!
                              Nielsen
                              • EarthMoverE
                                EarthMover
                                Torus Knot emitter, inside of ice, inside of honey. FryRender - 15% Isotropic Scattering with 85% Dielectric Transmittance.
                                Content Creator at Skapeup
                                • EarthMoverE
                                  EarthMover
                                  TBG - It is to a degree, although it appears to be more of a frosted glass. With SSS you'd expect to see less light absorbed into the thicker areas (i.e. the corners of the cube) and more light absorbed into the thinner areas (those closest to the sphere). In your render you can see the light passing through the thick areas too uniformly to be a true rendition of what SSS would look like. The dark areas in your render appear to be more shadow casting than that of light block through physical density. Keep trying though...you're getting closer.
                                  • T
                                    tallbridgeguy
                                    Thanks for the help! It is an interesting subject and I appreciate the feedback. I have to say it is a difficult subject.
                                    s
                                    Nielsen
                                    • olisheaO
                                      olishea
                                      frosted glass and a shiny ball! my god sss takes long time to render! this ones not exactly sss but looks pretty cool!
                                      earthmover: those look sweet! could be ornamental lights!
                                      oli
                                      • david_hD
                                        david_h
                                        here's one. . .no idea what I am doing. Just clicking a lot of buttons and hoping for the best. 😲
                                        • jeff hammondJ
                                          whaat's wax.. no ambient
                                          http://homepage.mac.com/jeffhammond/.Public/scf/ssswax.jpg
                                          • olisheaO
                                            olishea
                                            we should be using an organic model for SSS:
                                            this is with some fake emitters within rubber ball material, SSS density 0.05
                                            oli
                                            • 2 / 9
