    Spacebar woes
    15 Posts 11 Posters 2.1k Views 11 Watching
    • jeff hammondJ
      reinstall? πŸ˜„
      dunno, that would drive me nuts too.. fwiw, the spacebar works fine for me.
      maybe delete the preference list and relaunch SU? (user/library/preferences/com.google.sketchuppro7.plist)
      or,
      delete the shortcuts plist? (user/application support/google sketchup 7/sketchup/shortcuts.plist)
      [edit- oh wait, did the spacebar act like that since you installed sketchup or did it start acting up after a while?)
      • troyhomeT
        troyhome
        reinstall? πŸ˜„
        or,
        It only started acting up weeks after install- but i'll try the preferences thing out and let you know.... thanks
        IOviz.com
        SU Pro 2024 PC
          david.
          The spacebar works fine for me.
          • GaieusG
            This seems to be a Mac issue.
              sketchup guide jody
              Hi troyhome,
              This is actually an issue with Mac settings for keyboard shortcuts. If you go to System Preferences > Keyboard & Mouse > Keyboard Shortcuts and change the setting to "All Controls" then it should get you back in business.
              Jody Gates
              SketchUp Support
              • wind-borneW
                wind-borne
                Occasionally have situation where spacebar tap will not exit Rectangle tool.
                There is another default shortcut for Select on Macs also, Command /
                "To read between the lines was easier than to follow the text."OSX 10.11.6
                %(#BF80BF)[SU 8 pro
                  danbig
                  Thanks, Jody.
                  I've been frustrated with this on my mac @ home.
                  As you know, I haven't had any issues on my pc @ work.
                    Mark Leichliter
                    Jody - that does seem to help in most cases. I do still get the Model Info window popping on using the Spacebar when working inside a group or component. Don't have time right now to properly trouble shoot the issue.
                      danbig
                      I just checked the keyboard shortcut preferences, and it is set as indicated.
                      It has not solved the problem for me.
                      Mac OS 10.4. SU 7.1.
                      • H
                        Heaps
                        The same has happened to me a few times. I find that opening the Disk Utility program (found in Applications/Utilities) clicking the hard disk reference and running the Repair Permissions routine does the trick.
