    Looking to make a script, but dunno how.
    34 Posts 7 Posters 3.0k Views 7 Watching
    • Chris FullmerC
      oh Gaieus, you can do it! Its not too late to build some way cool Gaieus Toolset for SU πŸ˜„
      Then you can present it at the next basecamp!
      • GaieusG
        No way Chris, that would be waste of resources. Like if (instead of working hard on your next, cool plugin) you dealt with stupid spammers and kept banning them.
        everyone does his own job. Mine in this subforum is to be amazed and enjoy every new gem.
        πŸ˜‰
        • C
          cjthompson
          are you looking for a script to do what you ask for, or are you asking for a tutorial on how to do it?
            agamemnus
            Either. Anyway, here's what I have now. I already have a problem I can't figure out-- I can't get both IF statements to work in the second def. It will skip the second if statement as of now... dunno why.
            require 'sketchup.rb'
            module Convert_components_randomly
             def Convert_components_randomly.choosebase
              base_entities = Sketchup.active_model.selection
              if base_entities.empty?
               results = UI.messagebox "Please select base groups and/or components first."
               Sketchup.send_action "selectSelectionTool;"
               return
             def Convert_components_randomly.choosetarget
              target_entities = Sketchup.active_model.selection
              if target_entities.empty?
               results = UI.messagebox "Please select target groups and/or components first."
               return
              if Convert_components_randomly.choosebase.base_entities.empty?
               return
            end #Convert_components_randomly module
            convert_components_randomly_menu = UI.menu("Plugins").add_submenu("Convert Components Randomly")
            convert_components_randomly_menu.add_item("Select base components") {Convert_components_randomly.choosebase}
            convert_components_randomly_menu.add_item("Select components to convert") {Convert_components_randomly.choosetarget}
            • Chris FullmerC
              The if statement is invalid:
              That is calling a method (which does not exist). It needs to looking at an array. So in your choosebase method, you should make an array that holds all the selected components.
              Then in this method, you can determine if that array is empty. You might need to make your component selection be a global variables. So change base_entities to $base_entities in the first method. Then change the if statement to:
              if $base_entities.empty?
              That might begin to get you somewhere. But I have a feeling you are going to run into some more problems with the selection set. base_entities is currently pointing at the selection object - it is not pointing to an array of objects that are selected. Which is different. So maybe change line 6 to read:
              $base_entities = Sketchup.active_model.selection.to_a
              Now your base_entities is an array of SketchUp entities. And hopefully now when you get to the "if" statement, it will recognize your if statement as a valid statement, and parse it correctly.
              But I have not tested any of this, so it might need tweaks still.
                global variable? I'd recommend an module variable instead.
                • Chris FullmerC
                  I never played with the @ and @@ variables inside of modules. Do they work as expected? Will his script remember the value over multiple script sessions?
                    Use @ variable within a module and it's global within that module and it doesn't interfere with any other scripts.
                    module MyModule
                      @module my_var = 'Hello World'
                      def self.foo
                        return @my_var
                    For classes - have a look at this: http://sporkmonger.com/2007/2/19/instance-variables-class-variables-and-inheritance-in-ruby
                      MartinRinehart
                      Agamemnus,
                      Having Chris Fullmer help you with Ruby programming is like having Roger Federer help you with your tennis. Beyond what money could buy.
                      Sorry about the off topic stuff, but here's some more:
                      Gaieus, Chris is so right! I'm working on my tutorial's Ruby half (yes, half!). See if you can read this script:
                      # /t/stairs1.rb - a stairway in SketchUp Ruby Talk (aka SketchTalk)
                      =begin
                      The following bit of SketchTalk builds a 36"-wide stairway. Rise is 7 inches; run is 9. Built from 1.5" thick lumber. It has 15 steps. It has a 1.5 inch square banister on the left. The banister is supported by 1x1 balusters.
                      =end
                      require '/t/sketch_talk'
                      n # my keyboard shortcut for File/New
                      box [0,0,0], [36,1.5,0], 5.5 # riser
                      box [0,0,5.5], [36,10.5,5.5], 1.5 # tread
                      box [1.25,1,7], [2.25,2,7], 38 # ballusters
                      box [1.25,5.5,7], [2.25,6.5,7], 38+(7.0/2)
                      all # select all
                      step = g 'step' # turn selection into a component named 'step'
                      mc step, [0,9,7], 14 # Move/Copy, 14x
                      box [1,0,36+7], [2.5,15*9,36+7+15*7], 1.5 # bannister
                      I'll bet you can read that script. I'll bet you can't build the model half that fast any other way!
                        agamemnus
                        The first script is almost done. I have a few problems --
                        1. I could not find a way to convert groups to components so I changed them to unique components and then changed the definition of THOSE to the randomly selected base component. Isn't there a more efficient way?
                        2. I can't seem to convert the target groups to components fast enough -- I used 'if (current_entity.typename == "Group") // current_entity.to_component // end', but that only applies at the end of the script so I have to run it twice.. dunno how to make it convert instantly. Tried shoving "Sketchup.active_model.commit_operation" after and then converting the unique components to base components but it won't budge.
                        3. When I do "@target_entities = target_entities", and I already had a non-empty @target_entities, am I leaking?
                        4. (mini-gripe) The rand function is glitchy. Sometimes it gives several (3-4) repeats in a 90-size or so list, which has an incredibly low chance of occurring.
                        module Convert_objects_randomly
                         @base_entities = []
                         @target_entities = []
                         def Convert_objects_randomly.choosebase
                          @base_entities = Sketchup.active_model.selection.to_a
                          if @base_entities.empty?
                           return
                         def Convert_objects_randomly.choosetarget
                          target_entities = Sketchup.active_model.selection.to_a
                           return
                           if @target_entities.empty?
                           return
                           target_entities = @target_entities
                          target_entities.each do |current_entity|
                           if (current_entity.typename == "Group") or (current_entity.typename == "ComponentInstance")
                            current_entity.make_unique
                            current_entity.definition = @base_entities[rand(@base_entities.length)].definition
                        end #Convert_objects_randomly module
                        Convert_objects_randomly_menu = UI.menu("Plugins").add_submenu("Convert Objects Randomly")
                        Convert_objects_randomly_menu.add_item("Select base objects") {Convert_objects_randomly.choosebase}
                        Convert_objects_randomly_menu.add_item("Convert selected to random base objects") {Convert_objects_randomly.choosetarget}
                        file_loaded(__FILE__)
                          agamemnus
                          Thanks. I couldn't do it with "@module base_entities = '' "-- that gave me an error. I used " @base_entities = '' ". And looks like I need that " @base_entities ='' " or else something weird happens (maybe undefineds everywhere?) and the if statement for base_entities did not work. (it does now, of course)
                          So now I have to figure out how to iterate through target_entities and convert each to a random base_entities ..
                          There isn't a native function I could use?
                          Edit: Figured it out mostly... See post 1 below.
                          • Chris FullmerC
                            #1 groups have the .to_component method that will turn them into a component. But it makes each group a unique component, because there is no built in way to determine if a group is an identical copy of another group. There is some work arounds that can be done on certain groups that are exact copies of another group, but generally speaking, groups can't be turned easily into a single component and instances.
                            #2 - I'll have to look at later
                            #3 - The @target_entities will hold its value until SketchUp is closed, after it is given a value once. So you should clear it after your script is run each time. Add a @taget_entities = [] to the end of your script. That is my gess as to what is happening.
                            #4 - Yeah, that happens. Adam Billyard once took some time to explain about how random functions work in programming. It was eye opening....or rather, my eyes popped out from all the terms he used that didn't make any sense to me. But essentially random is a tricky thing to nail perfectly I guess.
                            Sounds like its coming along well!
                              agamemnus
                              Well, I know that it holds its value -- that was a way to re-randomize if the user wanted to without selecting those same groups again. But, if I set @target_entities to something else and it (@target_entities) is already set to something, that won't cause a leak, right? (the array it was previously set to will be cleared from memory?)
                              • Chris FullmerC
                                Ahh, correct. If you set it to seomthing new, then it clears its old value.
                                  Ruby uses garbage collection - so it keeps track of all the junk we throw about and sweeps it all away! πŸ˜„
                                  • C
                                    cjthompson
                                    @agamemnus said:
                                    1. I can't seem to convert the target groups to components fast enough -- I used 'if (current_entity.typename == "Group") // current_entity.to_component // end', but that only applies at the end of the script so I have to run it twice.. dunno how to make it convert instantly. Tried shoving "Sketchup.active_model.commit_operation" after and then converting the unique components to base components but it won't budge.
                                    the reason why is because .to_component creates a new entity.
                                    Try current_entity = current_entity.to_component.
                                      Also .typename is very slow.
                                      Instead of current_entity.typename == "Group" use current_entity.is_a?(Sketchup::Group).
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&start=0#p162235
                                        agamemnus
                                        Thanks guys. Got myself two more issues now, though. 😞
                                        1. The code refuses to convert lines to groups!! (I have "current_entity = current_entity.add_group")
                                        2. Is there any way to make a yes/no dropdown, and if not how do I change the size (width) of the inputbox text?
                                         @base_entities = []
                                         @convert_only_groupsinstances = true
                                           return
                                           return
                                           return
                                           if current_entity.is_a?(Sketchup;;Group)
                                           elsif current_entity.is_a?(Sketchup;;ComponentInstance)
                                            current_entity = current_entity.make_unique
                                           else
                                         def Convert_objects_randomly.settings
                                          if (@convert_only_groupsinstances == true)
                                           default = "yes"
                                          else
                                           default = "no"
                                          settings_query1 = inputbox(["Convert only groups/components to base objects?"],[default],"Convert Objects Randomly Settings")
                                          if (settings_query1[0] == "yes")
                                          else
                                           @convert_only_groupsinstances = false
                                        Convert_objects_randomly_menu.add_item("Settings") {Convert_objects_randomly.settings}
                                          Check the API on that method. It only belongs to Entities collections. Not single Entity
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html
                                          @agamemnus said:
                                          1. Is there any way to make a yes/no dropdown
                                          Check the second example in the manual:
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#inputbox
                                            MartinRinehart
                                            @agamemnus said:
                                            Ok, thanks. How do I convert an entity to an entities collection?
                                            You don't. Use an entities collection returned by the entities method:
                                            Sketchup.active_model.entities
                                            myGroup.entities
                                            someComponent.entities
