    Looking to make a script, but dunno how.
    34 Posts 7 Posters 3.0k Views 7 Watching
      global variable? I'd recommend an module variable instead.
      • Chris FullmerC
        I never played with the @ and @@ variables inside of modules. Do they work as expected? Will his script remember the value over multiple script sessions?
          Use @ variable within a module and it's global within that module and it doesn't interfere with any other scripts.
          module MyModule
            @module my_var = 'Hello World'
            def self.foo
              return @my_var
          For classes - have a look at this: http://sporkmonger.com/2007/2/19/instance-variables-class-variables-and-inheritance-in-ruby
            MartinRinehart
            Agamemnus,
            Having Chris Fullmer help you with Ruby programming is like having Roger Federer help you with your tennis. Beyond what money could buy.
            Sorry about the off topic stuff, but here's some more:
            @chris fullmer said:
            oh Gaieus, you can do it! Its not too late to build some way cool Gaieus Toolset for SU πŸ˜„
            Gaieus, Chris is so right! I'm working on my tutorial's Ruby half (yes, half!). See if you can read this script:
            # /t/stairs1.rb - a stairway in SketchUp Ruby Talk (aka SketchTalk)
            =begin
            The following bit of SketchTalk builds a 36"-wide stairway. Rise is 7 inches; run is 9. Built from 1.5" thick lumber. It has 15 steps. It has a 1.5 inch square banister on the left. The banister is supported by 1x1 balusters.
            =end
            require '/t/sketch_talk'
            n # my keyboard shortcut for File/New
            box [0,0,0], [36,1.5,0], 5.5 # riser
            box [0,0,5.5], [36,10.5,5.5], 1.5 # tread
            box [1.25,1,7], [2.25,2,7], 38 # ballusters
            box [1.25,5.5,7], [2.25,6.5,7], 38+(7.0/2)
            all # select all
            step = g 'step' # turn selection into a component named 'step'
            mc step, [0,9,7], 14 # Move/Copy, 14x
            box [1,0,36+7], [2.5,15*9,36+7+15*7], 1.5 # bannister
            I'll bet you can read that script. I'll bet you can't build the model half that fast any other way!
              agamemnus
              The first script is almost done. I have a few problems --
              1. I could not find a way to convert groups to components so I changed them to unique components and then changed the definition of THOSE to the randomly selected base component. Isn't there a more efficient way?
              2. I can't seem to convert the target groups to components fast enough -- I used 'if (current_entity.typename == "Group") // current_entity.to_component // end', but that only applies at the end of the script so I have to run it twice.. dunno how to make it convert instantly. Tried shoving "Sketchup.active_model.commit_operation" after and then converting the unique components to base components but it won't budge.
              3. When I do "@target_entities = target_entities", and I already had a non-empty @target_entities, am I leaking?
              4. (mini-gripe) The rand function is glitchy. Sometimes it gives several (3-4) repeats in a 90-size or so list, which has an incredibly low chance of occurring.
              require 'sketchup.rb'
              module Convert_objects_randomly
               @base_entities = []
               @target_entities = []
               def Convert_objects_randomly.choosebase
                @base_entities = Sketchup.active_model.selection.to_a
                if @base_entities.empty?
                 results = UI.messagebox "Please select base groups and/or components first."
                 Sketchup.send_action "selectSelectionTool;"
                 return
               def Convert_objects_randomly.choosetarget
                target_entities = Sketchup.active_model.selection.to_a
                 return
                if target_entities.empty?
                 if @target_entities.empty?
                 results = UI.messagebox "Please select target groups and/or components first."
                 return
                 target_entities = @target_entities
                target_entities.each do |current_entity|
                 if (current_entity.typename == "Group") or (current_entity.typename == "ComponentInstance")
                  current_entity.make_unique
                  current_entity.definition = @base_entities[rand(@base_entities.length)].definition
              end #Convert_objects_randomly module
              Convert_objects_randomly_menu = UI.menu("Plugins").add_submenu("Convert Objects Randomly")
              Convert_objects_randomly_menu.add_item("Select base objects") {Convert_objects_randomly.choosebase}
              Convert_objects_randomly_menu.add_item("Convert selected to random base objects") {Convert_objects_randomly.choosetarget}
              file_loaded(__FILE__)
                agamemnus
                Thanks. I couldn't do it with "@module base_entities = '' "-- that gave me an error. I used " @base_entities = '' ". And looks like I need that " @base_entities ='' " or else something weird happens (maybe undefineds everywhere?) and the if statement for base_entities did not work. (it does now, of course)
                So now I have to figure out how to iterate through target_entities and convert each to a random base_entities ..
                There isn't a native function I could use?
                Edit: Figured it out mostly... See post 1 below.
                • Chris FullmerC
                  #1 groups have the .to_component method that will turn them into a component. But it makes each group a unique component, because there is no built in way to determine if a group is an identical copy of another group. There is some work arounds that can be done on certain groups that are exact copies of another group, but generally speaking, groups can't be turned easily into a single component and instances.
                  #2 - I'll have to look at later
                  #3 - The @target_entities will hold its value until SketchUp is closed, after it is given a value once. So you should clear it after your script is run each time. Add a @taget_entities = [] to the end of your script. That is my gess as to what is happening.
                  #4 - Yeah, that happens. Adam Billyard once took some time to explain about how random functions work in programming. It was eye opening....or rather, my eyes popped out from all the terms he used that didn't make any sense to me. But essentially random is a tricky thing to nail perfectly I guess.
                  Sounds like its coming along well!
                    agamemnus
                    Well, I know that it holds its value -- that was a way to re-randomize if the user wanted to without selecting those same groups again. But, if I set @target_entities to something else and it (@target_entities) is already set to something, that won't cause a leak, right? (the array it was previously set to will be cleared from memory?)
                    • Chris FullmerC
                      Ahh, correct. If you set it to seomthing new, then it clears its old value.
                        Ruby uses garbage collection - so it keeps track of all the junk we throw about and sweeps it all away! πŸ˜„
                        • C
                          cjthompson
                          @agamemnus said:
                          1. I can't seem to convert the target groups to components fast enough -- I used 'if (current_entity.typename == "Group") // current_entity.to_component // end', but that only applies at the end of the script so I have to run it twice.. dunno how to make it convert instantly. Tried shoving "Sketchup.active_model.commit_operation" after and then converting the unique components to base components but it won't budge.
                          the reason why is because .to_component creates a new entity.
                          Try current_entity = current_entity.to_component.
                            Also .typename is very slow.
                            Instead of current_entity.typename == "Group" use current_entity.is_a?(Sketchup::Group).
                            http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&start=0#p162235
                              agamemnus
                              Thanks guys. Got myself two more issues now, though. 😞
                              1. The code refuses to convert lines to groups!! (I have "current_entity = current_entity.add_group")
                              2. Is there any way to make a yes/no dropdown, and if not how do I change the size (width) of the inputbox text?
                               @base_entities = []
                               @convert_only_groupsinstances = true
                                 return
                                 return
                                 return
                                 if current_entity.is_a?(Sketchup;;Group)
                                 elsif current_entity.is_a?(Sketchup;;ComponentInstance)
                                  current_entity = current_entity.make_unique
                                 else
                               def Convert_objects_randomly.settings
                                if (@convert_only_groupsinstances == true)
                                 default = "yes"
                                else
                                 default = "no"
                                settings_query1 = inputbox(["Convert only groups/components to base objects?"],[default],"Convert Objects Randomly Settings")
                                if (settings_query1[0] == "yes")
                                else
                                 @convert_only_groupsinstances = false
                              Convert_objects_randomly_menu.add_item("Settings") {Convert_objects_randomly.settings}
                                Check the API on that method. It only belongs to Entities collections. Not single Entity
                                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html
                                @agamemnus said:
                                1. Is there any way to make a yes/no dropdown
                                Check the second example in the manual:
                                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#inputbox
                                  MartinRinehart
                                  @agamemnus said:
                                  Ok, thanks. How do I convert an entity to an entities collection?
                                  You don't. Use an entities collection returned by the entities method:
                                  Sketchup.active_model.entities
                                  myGroup.entities
                                  someComponent.entities
                                    agamemnus
                                    Edit: The textbox width is still really long, even with the dropdown now...
                                      agamemnus
                                      > myGroup.entities
                                      But I can't... it's not a group or component. It's a line.... tried "current_entity = current_entity.entities", no go.
                                        You can't convert any raw geometry to a Group.
                                        But...
                                        my_group=model.active_entities.add_group(my_line)
                                        might work if the line has no face etc, then
                                        my_instance=my_group.to_component
                                        my_definition=my_instance.definition
                                        Otherwise clone the line into a group and leave the original alone with
                                        my_group=model.active_entities.add_group()
                                        my_group.entities.add_line(my_line.start.position,my_line.end.position)
                                        which recreates the line inside the new group...
                                          agamemnus
                                          Ugh. Maybe it's just better to use Chris's unsorted geometry->groups script first. πŸ˜„
                                            agamemnus
                                            Okay, script 1 is finished. It could use some expansion though, possibly. (eg: (1) convert areas instead of just lines, groups, and components [hard] and (2) don't make identical unique components as options [very doable, but might not be worth it]) The only real problems now are cosmetic:
                                            1. I am not sure that "Convert objects randomly" is a very good name for the script. I can't think of anything else that is both short and also semi-self-explanatory, though.
                                            2. The dropdown in the "options" is too big! I don't know how to set its width.
                                            Code:
                                            # "Convert objects randomly" script
                                            # Released into the public domain by Agamemnus.
                                            # Version 1; November 10, 2009
                                            # Contact the author; sketchup at flyingsoft dot phatcode dot net
                                            # Purpose;
                                            #     Easily converts a set of objects (target) into another set (base) randomly,
                                            # distributed amongst members of the base set.
                                            # Use;
                                            # 1)  Select a set of objects -- currently only components and/or groups work.
                                            # 1b) Pick "Select base objects" in "Plugins">"Convert Objects Randomly".
                                            # 2)  Select a target set of objects -- currently only components, groups, or lines.
                                            # 2b) Pick "Convert selected to random base objects" in "Plugins">"Convert Objects Randomly".
                                            # 2c) Done! You may pick "Convert selected to random base objects" again if you wish --
                                            #     your previous base and target object sets apply if you did not fundamentally change
                                            #     (explode, convert to group, etc-- geometry editing is fine) the target components.
                                            # 3) Set "Plugins">"Convert Objects Randomly">"Settings">"Convert lines to base objects?" to "YES"
                                            #    if you want ungrouped lines in the target set to be affected. Set "NO" otherwise.
                                            #    The default is "YES".
                                            # Behavior of result objects in version 1;
                                            # If the picked "base" object is a group, the target object is converted into a unique component.
                                            # If the picked "base" object is a component, the target object is converted into a component
                                            # instance of that component type.
                                            # ==Miscellaneous Notes;==
                                            # 1.) Much thanks to the Sketchup forum regulars in helping with problems in this script.
                                            # 2.) Looking for Work ;(
                                            # ...in the fields of;
                                            # economic analysis
                                            # business strategy
                                            # marketing
                                            # UI design
                                            # web based programming
                                            # 2D visual art
                                            # 3D visual art.
                                            # general programming.
                                            # M.A. in International Economics and Finance at Brandeis IBS, BA in economics at Brandeis IBS and Brandeis University.
                                            # 16 years of experience in amateur programming in BASIC-based languages (Basic, Freebasic, VB, etc.)
                                            # Several years of experience in PHP and Javascript. Experience in C-LISP, Matlab, and "some"
                                            # experience in Ruby (eh!) and C.
                                            # Work environment must at a _minimum_ contain penguins performing tricks, live.
                                             @base_entities = []
                                             @convert_lines = true
                                               return
                                               return
                                               return
                                               elsif (@convert_lines == true)
                                                current_entity = Sketchup.active_model.active_entities.add_group(current_entity)
                                               default = "yes"
                                              else
                                               default = "no"
                                              settings_query1 = inputbox(["Convert lines to base objects? "],[default], ["yes|no"], "Convert Objects Randomly Settings")
                                              else
                                               @convert_lines = false
