    Looking to make a script, but dunno how.
    34 Posts 7 Posters 1.8k Views 7 Watching
      agamemnus
      I want to make two scripts. In one script you would be able to select a series of components and add it to the memory of the script. Then you would be able to select another bunch of components and the script would convert each component to the ones in the memory, randomly and evenly distributed per component-in-memory.
      The second script would be similar except I would be adding to memory colors and randomly replacing colors (of a set of groups or components) instead of replacing component geometry.
      I have no idea what the commands for this would be.
      I'm looking for commands that would let me do pretty much all of this... I looked at
      http://code.google.com/apis/sketchup/docs/index.html and really I'm quite lost as to which commands to use.
      • Chris FullmerC Offline
        Have you succesfully made any little scripts or anything yet? Do you have Jim Ruby Web Console installed?
        For the first script, the easiest way to implement it would be to make it have 2 parts. The user selects base components and activates the first plugin - remember base components. The end. Then the user selects target components and activates the 2nd part of the plugin.
        This was you can avoid having to learn how to write a selector tool, which is a major pain.
        The second plugin would work similarly. Have you looked at my Extrapolate Colrs plugin? It does almost what you want, but it does not work on groups/components because that takes time to program. But you can go into a group or component and run the script and it works inside the group that way. Check it out, the source is open so you can look at what it does. I was also about to do a video tutorial on how to write that exact script. So I'll post a link when I do.
        Also, I have 2 videos currently on my YouTube channel if you wan to watch about beginning ruby.
          OK Chris, I now know why I don't ask questions like agamemnus πŸ˜„
          (sorry agamemnus - no offense meant to you but just realising my limits)
            oh Gaieus, you can do it! Its not too late to build some way cool Gaieus Toolset for SU πŸ˜„
            Then you can present it at the next basecamp!
              No way Chris, that would be waste of resources. Like if (instead of working hard on your next, cool plugin) you dealt with stupid spammers and kept banning them.
              everyone does his own job. Mine in this subforum is to be amazed and enjoy every new gem.
              πŸ˜‰
                cjthompson
                are you looking for a script to do what you ask for, or are you asking for a tutorial on how to do it?
                  agamemnus
                  Either. Anyway, here's what I have now. I already have a problem I can't figure out-- I can't get both IF statements to work in the second def. It will skip the second if statement as of now... dunno why.
                  require 'sketchup.rb'
                  module Convert_components_randomly
                   def Convert_components_randomly.choosebase
                    base_entities = Sketchup.active_model.selection
                    if base_entities.empty?
                     results = UI.messagebox "Please select base groups and/or components first."
                     Sketchup.send_action "selectSelectionTool;"
                     return
                   def Convert_components_randomly.choosetarget
                    target_entities = Sketchup.active_model.selection
                    if target_entities.empty?
                     results = UI.messagebox "Please select target groups and/or components first."
                     return
                    if Convert_components_randomly.choosebase.base_entities.empty?
                     return
                  end #Convert_components_randomly module
                  convert_components_randomly_menu = UI.menu("Plugins").add_submenu("Convert Components Randomly")
                  convert_components_randomly_menu.add_item("Select base components") {Convert_components_randomly.choosebase}
                  convert_components_randomly_menu.add_item("Select components to convert") {Convert_components_randomly.choosetarget}
                    The if statement is invalid:
                    That is calling a method (which does not exist). It needs to looking at an array. So in your choosebase method, you should make an array that holds all the selected components.
                    Then in this method, you can determine if that array is empty. You might need to make your component selection be a global variables. So change base_entities to $base_entities in the first method. Then change the if statement to:
                    if $base_entities.empty?
                    That might begin to get you somewhere. But I have a feeling you are going to run into some more problems with the selection set. base_entities is currently pointing at the selection object - it is not pointing to an array of objects that are selected. Which is different. So maybe change line 6 to read:
                    $base_entities = Sketchup.active_model.selection.to_a
                    Now your base_entities is an array of SketchUp entities. And hopefully now when you get to the "if" statement, it will recognize your if statement as a valid statement, and parse it correctly.
                    But I have not tested any of this, so it might need tweaks still.
                      global variable? I'd recommend an module variable instead.
                        I never played with the @ and @@ variables inside of modules. Do they work as expected? Will his script remember the value over multiple script sessions?
                          Use @ variable within a module and it's global within that module and it doesn't interfere with any other scripts.
                          module MyModule
                            @module my_var = 'Hello World'
                            def self.foo
                              return @my_var
                          For classes - have a look at this: http://sporkmonger.com/2007/2/19/instance-variables-class-variables-and-inheritance-in-ruby
                            MartinRinehart
                            Agamemnus,
                            Having Chris Fullmer help you with Ruby programming is like having Roger Federer help you with your tennis. Beyond what money could buy.
                            Sorry about the off topic stuff, but here's some more:
                            Gaieus, Chris is so right! I'm working on my tutorial's Ruby half (yes, half!). See if you can read this script:
                            # /t/stairs1.rb - a stairway in SketchUp Ruby Talk (aka SketchTalk)
                            =begin
                            The following bit of SketchTalk builds a 36"-wide stairway. Rise is 7 inches; run is 9. Built from 1.5" thick lumber. It has 15 steps. It has a 1.5 inch square banister on the left. The banister is supported by 1x1 balusters.
                            =end
                            require '/t/sketch_talk'
                            n # my keyboard shortcut for File/New
                            box [0,0,0], [36,1.5,0], 5.5 # riser
                            box [0,0,5.5], [36,10.5,5.5], 1.5 # tread
                            box [1.25,1,7], [2.25,2,7], 38 # ballusters
                            box [1.25,5.5,7], [2.25,6.5,7], 38+(7.0/2)
                            all # select all
                            step = g 'step' # turn selection into a component named 'step'
                            mc step, [0,9,7], 14 # Move/Copy, 14x
                            box [1,0,36+7], [2.5,15*9,36+7+15*7], 1.5 # bannister
                            I'll bet you can read that script. I'll bet you can't build the model half that fast any other way!
                              agamemnus
                              The first script is almost done. I have a few problems --
                              1. I could not find a way to convert groups to components so I changed them to unique components and then changed the definition of THOSE to the randomly selected base component. Isn't there a more efficient way?
                              2. I can't seem to convert the target groups to components fast enough -- I used 'if (current_entity.typename == "Group") // current_entity.to_component // end', but that only applies at the end of the script so I have to run it twice.. dunno how to make it convert instantly. Tried shoving "Sketchup.active_model.commit_operation" after and then converting the unique components to base components but it won't budge.
                              3. When I do "@target_entities = target_entities", and I already had a non-empty @target_entities, am I leaking?
                              4. (mini-gripe) The rand function is glitchy. Sometimes it gives several (3-4) repeats in a 90-size or so list, which has an incredibly low chance of occurring.
                              module Convert_objects_randomly
                               @base_entities = []
                               @target_entities = []
                               def Convert_objects_randomly.choosebase
                                @base_entities = Sketchup.active_model.selection.to_a
                                if @base_entities.empty?
                                 return
                               def Convert_objects_randomly.choosetarget
                                target_entities = Sketchup.active_model.selection.to_a
                                 return
                                 if @target_entities.empty?
                                 return
                                 target_entities = @target_entities
                                target_entities.each do |current_entity|
                                 if (current_entity.typename == "Group") or (current_entity.typename == "ComponentInstance")
                                  current_entity.make_unique
                                  current_entity.definition = @base_entities[rand(@base_entities.length)].definition
                              end #Convert_objects_randomly module
                              Convert_objects_randomly_menu = UI.menu("Plugins").add_submenu("Convert Objects Randomly")
                              Convert_objects_randomly_menu.add_item("Select base objects") {Convert_objects_randomly.choosebase}
                              Convert_objects_randomly_menu.add_item("Convert selected to random base objects") {Convert_objects_randomly.choosetarget}
                              file_loaded(__FILE__)
                                agamemnus
                                Thanks. I couldn't do it with "@module base_entities = '' "-- that gave me an error. I used " @base_entities = '' ". And looks like I need that " @base_entities ='' " or else something weird happens (maybe undefineds everywhere?) and the if statement for base_entities did not work. (it does now, of course)
                                So now I have to figure out how to iterate through target_entities and convert each to a random base_entities ..
                                There isn't a native function I could use?
                                Edit: Figured it out mostly... See post 1 below.
                                  #1 groups have the .to_component method that will turn them into a component. But it makes each group a unique component, because there is no built in way to determine if a group is an identical copy of another group. There is some work arounds that can be done on certain groups that are exact copies of another group, but generally speaking, groups can't be turned easily into a single component and instances.
                                  #2 - I'll have to look at later
                                  #3 - The @target_entities will hold its value until SketchUp is closed, after it is given a value once. So you should clear it after your script is run each time. Add a @taget_entities = [] to the end of your script. That is my gess as to what is happening.
                                  #4 - Yeah, that happens. Adam Billyard once took some time to explain about how random functions work in programming. It was eye opening....or rather, my eyes popped out from all the terms he used that didn't make any sense to me. But essentially random is a tricky thing to nail perfectly I guess.
                                  Sounds like its coming along well!
                                    agamemnus
                                    Well, I know that it holds its value -- that was a way to re-randomize if the user wanted to without selecting those same groups again. But, if I set @target_entities to something else and it (@target_entities) is already set to something, that won't cause a leak, right? (the array it was previously set to will be cleared from memory?)
                                      Ahh, correct. If you set it to seomthing new, then it clears its old value.
                                        Ruby uses garbage collection - so it keeps track of all the junk we throw about and sweeps it all away! πŸ˜„
                                          cjthompson
                                          @agamemnus said:
                                          1. I can't seem to convert the target groups to components fast enough -- I used 'if (current_entity.typename == "Group") // current_entity.to_component // end', but that only applies at the end of the script so I have to run it twice.. dunno how to make it convert instantly. Tried shoving "Sketchup.active_model.commit_operation" after and then converting the unique components to base components but it won't budge.
                                          the reason why is because .to_component creates a new entity.
                                          Try current_entity = current_entity.to_component.
                                            Also .typename is very slow.
                                            Instead of current_entity.typename == "Group" use current_entity.is_a?(Sketchup::Group).
                                            http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&start=0#p162235
                                            • 2 / 2
