    Effects folder
    3 Posts 2 Posters 447 Views 2 Watching
    • O Offline
      Oma
      I've just downloaded shapes zip includes mesh and torus but it said to unzip and put in an effects folder. I can not locate one in sketchup.
      is this something I must add under programs?
      ciao OMA
        Hi Oma,
        Can you show us where you downloaded and what?
        • O Offline
          Oma
          sorry I should have added this quote (see below). this is where I got the set of shapes. I did manage to find an folder under programs>google and they show up now when I use the sketchup 7 program. But they actually show up twice when I clk draw>shapes. Since I only require them once under draw πŸ˜„ maybe you can help me fix that boo boo. I know I've done something incorrectly.
          ciao
          **@tig said:
          These are the old 'shape' toolset made some years ago - they still work.
          Unzip and put all 3*** of the files into your SUp plugins folder and you get a 'Shapes...' sub-menu under 'Draw'.
          *** There are two versions of 'Shapes' for metric and imperial users. Only put in one of these rubies - ShapesMM.rb is metric(mm) and ShapesINS.rb is in inches. If you put in both you'll get two identical sub-menus but both with metric default values since the MM one loads last and overwrites the INS !
          There's a list of the basic shapes then available:
          Cylinder
          Cone
          Torus
          Tube
          Prism
          Pyramid
          Dome
          Sphere [I added the sphere to @Last's original list].
          The created shape is made inside a group and it is 'parametric' - select it and right-click context-menu to Edit its values later on as needed. You can explode it back to it's base geometry but then it will have these values 'frozen'...
          The 'parametric.rb' and 'mesh_additions.rb' rubies are needed to make the whole thing work.**
