    Mac OSX and plugin problems
    21 Posts 6 Posters 1.7k Views 6 Watching
      @bowesy said:
      Yep - thats what I do.
      @bowesy said:
      applications>Google Sketchup>Contents>Plugins
      is not the same as Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/
        bowesy
        Ah ok! I'll drag the plugins folder out of contents and see how I go. Cheers.
          To find where your OS looks for Plugins paste this into the Ruby Console:
          Sketchup.find_support_file("Plugins")
          The string returned is the path to the Plugins folder - so put your plugins & sub-folders into there ???
            bowesy
            Thanks TIG. SU looks in plugins according to that string. I've time machined back to an earlier version of my SU and got all the plugins back but I have noticed that it never had sketchup.rb in there. Neither is there a tools folder available. Do you have the plug-in sketchup.rb at all?
              Where abouts in the system are you now? Where did you get the sketchup.rb file?
              sketchup.rb is a file all plugins require and should be left where Sketchup installs it.
                bowesy
                From what I can gather it cant ever have been there. I've read that this has been a bit of a problem with SU6 - some copies just didn't ship with it and some sketchup.rb files were old versions and didn't work with SU6. I downloaded a copy from somewhere - may well have been an archived page from the Google site but it didn't work
                  Some plugins might have shipped a copy, and if that's an old copy it will cause problems. You should not need to download an extra copy.
                    I checked my Windows installation - sketchup.rb is located in the Tools folder where Sketchup was installed. Not sure where it belongs in Mac, but you should never have to deal with that file at all. You might want to reinstall Sketchup again to get a clean installation.
                      bowesy
                      I've just had a eureka moment!! Thanks Jeff and thanks ThomThom - it's obvious that I'm not that computer literate isn't it?! If only I had followed ThomThom's directions to the letter earlier we wouldn't still be here!!?
                      • jeff hammondJ Offline
                        no, don't do that..
                        thom pointed this out earlier but i'll try again..
                        this:
                        is not the same thing as this:
                        (which is where the plugins should be placed)
                        you're right clicking on the SU app icon and that's not where you need to be.. follow the path highlighted in red above
                          I'm still wondering where you got that sketchup.rb file from... might you have moved it away from somewhere you should not?
                          • daleD Offline
                            dale
                            On my mac the SketchUp.rb is located in the HD/Library/Application Support/Google SketchUp 7/SketchUp/tools
                            If you use spotlight you can trace it. My get info window looks as follows:
                              bowesy
                              Cant remember where I found the sketchup.rb file. I'll check thru my history files - think I probably googled "sketchup.rb download" and then just searched through!
                                @honoluludesktop said:
                                In a windows box, don't you need to install sketchup.rb in the plugin folder? Or will the system find it in the Tools folder?
                                No, you never need to bother about the sketchup.rb file. It's installed by Sketchup. And the Tools folder acts just like the Plugins folder with the exception that it contains the bundled Sketchup ruby extensions.
                                • honoluludesktopH Offline
                                  honoluludesktop
                                  In a windows box, don't you need to install sketchup.rb in the plugin folder? Or will the system find it in the Tools folder? Hmm....The file in the plugin folder is different from the one in Tools, which has something for the ruby console.
                                    honoluludesktop
                                    Thanks, I must have done something s****d, like copy the file from v6.x, when I didn't see it in the v7.x plugin folder.
