    Roman basilica - WIP
    54 Posts 18 Posters 11.2k Views 18 Watching
      Aerilius
      Also in my region, the barbarians abused the roman remains, mainly as stone quarries. From one villa rustica, there are still 2 out of ~35 columns left - used as grindstone by a blacksmith.
      By the way, how did you make the fire basins (is that the english term?)? When I place a KT light in a png image of a flame, the image turns out too bright.
      • GaieusG
        @pichuneke said:
        I supose that the walls were painted.
        Pure, whitish ("eggshell") colour of stucco/plaster with mixed stone and brick bumpmap underneath. Just like in my regular corner bar ("bodega")
        @aerilius said:
        By the way, how did you make the fire basins (is that the English term?)? When I place a KT light in a png image of a flame, the image turns out too bright.
        The original name would be tripous (this is what the English distort as tripod - from the stem of the Genitive case "tripodos") but I am not sure how they would call it as they use the term for photographic and other "three legs" (which it means in Greek).
        Anyway, place the point light in front of the flame image as per Miguel's (Ecquadorian's) method here. Actually, you can even re-use the flame/fire component - just change the Twilight spotlight to a KT spotlight and ready to go.
        Going on with texturing (now it looks like a little scale model placed on the grass 😄 )
        • P
          pichuneke
          I believe that you are modeling the new ampliaton for your corner bar... (the words that all tourists learn in spain are fiesta, paella, vino and bodega) 😆 😉
          Well, It's really curious for me the way the roman empire style ended in your country. Here, visigoths evolved using a style (columns and arcs) that is believed they took from some regions at the north of spain in later roman period (not remains of it except in tombstones). After it, moorishes copied it:
          http://img169.imageshack.us/img169/6085/arcodeherradura28lascla.jpg
          (Source: http://es.wikipedia.org/wiki/Archivo:Arco_de_herradura_%28Las_Claras%29.jpg )
          It hapened in all the roman empire. In Spain too. In fact the famous mosque of Córdoba (now is catholic Cathedral) has one of the best collection of roman capitals of spain. In their columns.
          http://farm4.static.flickr.com/3111/3445848872_4686e3bd87.jpg
          Source (with more resolution): http://www.flickr.com/photos/javier1949/3445848872/in/set-72157616634272377/
          Forgive my spanglish...
          • GaieusG
            Ah yes, but as you say, those Goths learned to build in Hispania, not in Pannonia (where they had also been). Just like their "brothers", the Ostrogoths, who went to Italy from Pannonia and lerned to build only there.
            Here, there wasn't much to learn.
            And wow, look at this wood texture! (It's untouched/unchanged Olda's wooden material pack from the KT Forums). And yes, before somebody mentions, I know that the timber/beam ends should be painted with something different. 😒 I will, promise (although "from below", no-one would spot it out).
            • MALAISEM
              MALAISE
              Hi Gaius, great work you're doing !
              Could you explain how you extract a "plan" of the first picture leading you to the drawing of building. Do you use PhotoMatch ?
              Please let's see other W.I.P 😍
              MALAISE 👍
              • GaieusG
                I'd love to use PhotoMatch (although not for constructing but for later "matching" the perspective 3D model with the photo) however, as you can see there, there are no vertical edges of the building as it is just the ruins - say the "plan".
                So that's it basically; as meticulously mmeasuring everything on site and drawing the remains (to scale) by hand is part of the documentation process of an archaeological excavation, I have the plan exactly measured and drawn already, when I start with such a project.
                • Alan FraserA
                  Alan Fraser
                  I thought you might like a headsup on this, Gai. http://www.procedural.com/cityengine/import-export/export-samples.html
                  There are links to some exported City Engine buildings. They are pretty high-poly, but can be got into SketchUp. They contain some fairly useful textures too...variations of typical Roman brick and some very decent roof tiles.
                  3D Figures
                  • GaieusG
                    Thanks Aalan, already trying to import. Unfortunately the images are generally rather low res but will see what I can use.
                    • P
                      pichuneke
                      With my free version of sketchup I can't import the roman houses with textures.
                      Collada gives me problems with sketchup. I have problems too when importing/exporting to Blender.
                      • Alan FraserA
                        Alan Fraser
                        Even the Pro version crashes when trying to import the Collada 2009 file. I had to use the second, triangulated version. It still took several minutes to import.
                        3D Figures
                        • P
                          pichuneke
                          By the way, you have to visit this guy. I am his number one fan. 😄
                          Error 404 (Not Found)!!1
                          (sketchup.google.com)
                          He does a model in just one week. I enjoy rendering for fun his models with kerkythea, this is my last one based on his Trajan's Forum.
                          http://img94.imageshack.us/img94/8312/trajano.th.jpg
                            Aerilius
                            Me too.
                            The collada version does not contain components. And as the roof + all balustrades are modeled, they make up 3/2 of the file.
                            I think in large models, especially generated models, its initial set up makes are huge difference (i.e. png images for balustrades...). Recently I reworked the roof tiles of a model and reduced the poly count to less than the half.
                            Has someone found the roman man? He would be useful for my me. I dream of something like this:
                            [flash=425,344:31lc30xb]http://www.youtube.com/v/ZA3gzqG94JQ&hl=de&fs=1&[/flash:31lc30xb]
                            • Alan FraserA
                              Alan Fraser
                              It will cost you a few cisterces. 😉 http://www.formfonts.com/viewModel.php?id=8465&config=1&action=&sub_action=&type=&active=
                              Of course you could always make a 2D Face Me from the thumbnail...for your own use, of course.
                              3D Figures
                              • GaieusG
                                I have a couple of photos taken in a Roman reenactment camp this summer. Some of them are actually not bad for 2D Face me's (sigh... planning to make some for quite a while now...)
                                http://picasaweb.google.com/csaba.pozsarko/Lugio2009FirstDayAndOpeningCeremony#
                                There are more images - I would just need to organise them and upload. Anyone feel free to use them for face me's or such however.
                                Update; this one is particularly tasty:
                                http://lh6.ggpht.com/_zcvsIuYiVbo/Sm61nMRrRJI/AAAAAAAABhE/lAOP01kL6zg/s720/Lugio_2009_0188.jpg
                                • Alan FraserA
                                  Alan Fraser
                                  Some more here. http://www.erminestreetguard.co.uk/cov/index.htm
                                  Plebeians, obviously....terrible hairstyles. 😄
                                  3D Figures
                                  • michaliszissiouM
                                    michaliszissiou
                                    It happens every were. It happens in greek orthodox churches too. Ancient marbles and columns from greek temples as walls of beautiful byzantine churches. This is the truth. Lets not talk about "barbarians", lets talk about what is civilization.
                                      Aerilius
                                      In fact they are (partly) my ancestors. 😳
                                      • michaliszissiouM
                                        michaliszissiou
                                        Well aerilius, my ancestors are ancient greeks. 🤣 🤣 🤣
                                        Only in our imagination...
                                        • N
                                          notareal
                                          Thanks for the hint!
                                            Wish I had a job of modelling ancient building like this.
                                            • 2 / 3
