    [Plugin] Geom Interpolated Curve ver. 1.3.
    26 Posts 16 Posters 29.3k Views 16 Watching
      kirill2008
      This plugin became obsolete but you can find all its functionality in 'Recursively Smoothed Curve' tool of 'LSS Toolbar 2.0' extension. It is still only a beta version, but this particular tool works stable enough. Find out more at http://sketchucation.com/forums/viewtopic.php?f=323&t=47399
        remus
        Very cool, particularly like the explanation lines 😄
          Funny for curious caligraphy 😄
            Jörg
            very cool, kirill!!!!
            Thank you very much!
            • N Offline
              notareal
              👍 I like it.
              • FletchF Offline
                Fletch
                good idea...
                I'm concerned that the word "Smooth" is already "taken" in SketchUp... and usually applies to a specific type of edge, so if we could come up with a better name for this tool, it may avoid confusion.
                may I suggest "Curve Toy" or "Curve Control" or "Squishy Curve" or "Marilyn Monroe" 😕 I don't know... something unique.
                !["Smooth" is already "taken"](/uploads/imported_attachments/fAgq_smooth.jpg ""Smooth" is already "taken"")
                Fletch
                  chango70
                  Very cool. What do you do with the explanation lines? can you manipulate the geometry with those lines? Sorry I am not with SU range.
                  • mitcorbM Offline
                    mitcorb
                    Very interesting videos. I will have to review them again.
                      Panga
                      Thanks a lot !! Very usefull for me.
                      • erikBE Offline
                        erikB
                        Very usefull for me to ! 👍
                        Thanks,
                        erikB
                          kwistenbiebel
                          Tremendously useful for me 😄
                          It seems like a good plugin to make the curves as a start for a soap-skin-bubble session.
                          Thanks Kirill! 👍
                          • I Offline
                            ideas_arte
                            This is amazing and very very helpful, thank you very much for your generosity.
                            greetings
                              kirill2008
                              I agree. I like "Marilyn Monroe" 👍 😄
                              Well maybe "Geom Interpolation" (long, but close to what it really is).
                              Unfortunately explanation lines are only to show, how intermediate vertices were modelled (lines are practically useless and there is no way to interact with them only to admire).
                              Actually it is necessary to implement 2 additional 'control lines' at the start and at the end of the initial opened curve to affect 1-st and last segment curvature (the same way as cubic spline). Closed curve does not need it.
                              And another issue: current version does not 'remember' control points across sessions also (the same as 'ctrlpnts.rb'). I'm on my way to implement such functionality.
                                kirill2008
                                In the current version (1.2.) the command name to launch the plugin was renamed to "Geom Interpolation..." to avoid confusions with other commands.
                                And now script recalls control points after opening the file which contains curve. I'm going also to add interactive control points editing (the same way as in ctrlpnts.rb).
                                  Kirill, thank you for this plugin.
                                  Several I watched your videos demonstrating it and then tried to use it. I must be missing something because you seem to be able to make it do things I can't. Could you give a little basic training?
                                  I can get the curve alright after setting the control points out. After that, I select Edit Geom Interpolated Curve... If I click on the left arrow key I get some additional points but no lines joining them to the points on the curve. Also, if I click on a control point and try to drag it, nothing happens. If I click on a control point and let go of the button, the next click creates a new point away from the first point as if placing a guide point with the Tape Measure tool. Nothing I do will let me edit the curve.
                                  I've tried following the messages displayed at the bottom of the screen but with no luck. Could you give some guidance? Thank you.
                                  Curve with Explanation Lines except no lines appear
                                  Hovering over a control point
                                  Click on control point move mouse and just before click.
                                    chrisjk
                                    Dave,
                                    I have tried this and find it a bit hit and miss to pick a control point. You have to move the select tool around a fair bit until a tool tip says "Guide point". You can click on this and the curve turns red and a message in the status bar says "Feel free to pick a c_point to interact with" then clicking on that point allows you to move the point and the line will follow.
                                      Thanks Chris. I did see that deal with the curve turning red and the message "Fill{sic} free to pick..." but even then I can't move the control point.
                                        chrisjk
                                        Dave,
                                        I don't know if it helps but here is a little video I made of using it.
                                          kirill2008
                                          I think it would be interesting to check out the video of 'crvsmth.rb' revival:
                                          [flash=560,315:3r34p2is]http://www.youtube.com/v/8nbMaKKNkm8?version=3&hl=ru_RU[/flash:3r34p2is]
                                          Finally I decided to reanimate this ancient 'scripture' and make its use more intuitive this time... So now it is adapted into modernized 'LSS Toolbar' infrastructure and its reincarnation name is 'Recursively Smoothed Curve' tool.
                                          For now 'pre-alpha' version of 'LSS Toolbar' is available. Feel free to use it at your own risk.
                                          lss_toolbar_2_0_pre_alpha_5.zip
                                          • Bob JamesB Offline
                                            Bob James
                                            This is just downright awesome 👍 🎉
