    New API doc - typos and questions
    370 Posts 35 Posters 371.9k Views 35 Watching
      The Model collection some times doesn't list all the materials when you call .each on it.
      http://forums.sketchucation.com/viewtopic.php?f=11&t=21243
        WebDialog.new
        See Martin's post: http://forums.sketchucation.com/viewtopic.php?f=180&t=21502
          MartinRinehart
          The following was agreed, in http://forums.sketchucation.com/viewtopic.php?f=180&t=21502 to correctly document WebDialog.new.
          Alternate to the API docs, with help. This is for PC:
          title - string - This text will appear in the title bar of your WebDialog
          scrollable - boolean - This is a NOP. You get scrollbars, regardless. Workaround: <body scroll=no>.
          key - string - If this is nil or an empty string, your dialog's size/location is stored in "HKEY_CURRENT_USER/Software/Google/SketchUp7/WebDialog_". You should definitely include here the name of your Ruby, which will be concatenated:
          "HKEY_CURRENT_USER/Software/Google/SketchUp7/WebDialog_MyRuby"
          width, height, left, top - integers - size/location, in pixels, of the first appearance of your WebDialog. All subsequent appearances will be taken from the registry entry.
          resizeable - boolean - if false, your user cannot resize the dialog. Defaults to true, if omitted.
          • T
            tomasz
            class ShadowInfo
            ShadowTime_time_t
            SunRise_time_t
            SunSet_time_t
            TZOffset
            UseSunForAllShading
            Those keys are not mentioned/explained in the documentation.
              MartinRinehart
              Topic: WebDialog.new
              The second parameter, scrollbars, appears to be operational on the Mac. PCs get scrollbars, regardless.
                Jim
                Just a general request for the API docs. When viewing a method which references another class, would it be possible to link to that class? For example, you are the viewing Model.bounds description - it would be nice to be able to jump right to the BoundingBox class.
                Thanks.
                  Jim
                  I wonder if we should lock this list and start a new one for 7.1?
                    Maybe once Scott has updated the docs first?
                      Entity.typename
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#typename
                      I think it's worth noting here that .typename comparison is slow and should be avoided if possible. Ref: http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&st=0&sk=t&sd=a#p166340
                      .typename is required if you need to identify entity types that don't have ruby API classes, such as DimensionLinear, DimensionRadial and Polyline3d. And if you scan for these that you check for entities of class DrawingElement before you do a .typename comaprison.
                      • T
                        tomasz
                        "DisplayColorbyLayer" key of RenderinOptions should read "DisplayColorByLayer"
                        • N
                          NewOne
                          What's wrong with Colorby Layer ? 🤣
                          • T
                            tomasz
                            Try read the value of it. Such a key does not exist.
                              Did I miss a joke..? 😕
                              • N
                                NewOne
                                hey, that was a joke 😛 I got your point and you are right...
                                • C
                                  cjthompson
                                  I'm afraid you are much too easily amused 😄
                                    Sketchup.register_importer
                                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#register_importer
                                    The docs says SU6.0+, but isn't it SU7.0+ ?
                                      Sketchup.read_default
                                      http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#read_default
                                      True if successful, false if unsuccessful.
                                      Surely it would return the value being accessed?
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Verified!
                                        Sketchup.read_default('Preferences','SnapAngle') returns 15.0
                                        [My current setting; which happens in this case to be class Float.]
                                        The API doc is vague about the default argument. The definition should read (as things work now):
                                        "(optional) A value to return, if the variable is not found or empty."
                                        [The way it is written, I read it as being a value to write into the registry.]
                                        The lack of error checking in this method, can easily create false Resistry Keys.
                                        Example: if you misspell the key (section on the Mac,)... ie:
                                        [note misspelled 'Preferences']:
                                        Sketchup.read_default('Prefer ances','SnapAngle')
                                        ... the method creates a new 'Preferances' key, with nothing under this new WORTHLESS key. (No Valuename, no value.) The method then just returns nil. [On Win32, we must manually use the Registry Editor to get rid of this junk!]
                                        If the key is correct, but the Valuename is wrong (or does not exist,) the method just returns nil, [again,] or the default ReturnValue.
                                        If the the Key is correct, AND the Valuname is correct, but the Value is empty, the method returns nil, [once again,] or the default ReturnValue.
                                        So we have 3 situations in which the method can return nil, and no way thru the SU API to tell what the situation is. [yes we can use one of the full ruby Win32 Registry modules, and I may begin doing this.]
                                        A fourth situation, is if the value is an empty string, (ie '' or "" are stored in the registry value the method just returns the empty string (and NOT nil.) The return class of the method is string in this case.
                                        This can happen if you use Sketchup.write_default( key, valuename, ""), but its not necessary as each value in the registry has a type, and strings don't need delimiters.
                                        We should use instead Sketchup.write_default( key, valuename, nil) to clear a string value in the registry.
                                        I would propose a change to this method...
                                        (1 as is.) IF everything exists, it works OK, and the value is returned.
                                        (2 as is.) If (the Key exists, AND the Valuename exists,) AND the value is empty, then the method should return NIL without a default Return Value (3rd parameter,) OR the 3rd parameter if given.
                                        (3) If the EITHER the Key OR the Valuename do NOT exist, then the method should raise an exception similar to a hash index error, viz:
                                        Error in myprog.rb:22:in `Sketchup.read_default': key not found (IndexError) ...
                                        Then (reference methods for Hash class):
                                        CREATEseveral new boolean methods similar to Hash.has_key?, Hash.has_value? and Hash.empty? so the programmer can decide in their RESCUE block what action to perform;
                                        I'd envision these boolean methods to be named similar to:
                                        Sketchup.default_empty?
                                        Sketchup.default_has_key? (perhaps with a Mac alias .default_has_section? for plist files)
                                        Sketchup.default_has_valuename? (perhaps a Mac alias .default_has_variable? for plist files)
                                        Thoughts?
                                        I'm not here much anymore.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Face.mesh
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                                          Valid flags are:
                                          [condensed: 0, 1, 2, 4 ]
                                          Add these numbers together to combine flags. A value of **5** will include all flags, for example.
                                          I seem to get 7 (as shown in the example,) when I add all the flags.
                                            Some of the methods to access toolbars needs clarification.
                                            UI.set_toolbar_visible UI.toolbar_names UI.toolbar_visible?
                                            These only works on the native Sketchup toolbars. And UI.toolbar_names doesn't list all native toolbars.
                                            UI.toolbar is used to return Ruby toolbars. But (!) it will never fail if you try to refer to a non-existent toolbar - it will create a new one. Have not found a way to detect if a Ruby toolbar exists or not.
                                            http://forums.sketchucation.com/viewtopic.php?f=180&t=21156
                                            • 11
                                            • 18
                                            • 19
                                            • 9 / 19
