    [Plugin] CleanUp
    974 Posts 217 Posters 1.1m Views 217 Watching
    • E Offline
      Ecuadorian
      Thank you, man. I have the perfect file to test it. ๐Ÿ˜„
      -Miguel Lescano
        A particular troublesome file? Please let me know how it goes. Not sure if I've got it fully tuned in yet.
          remus
          Cheers thom, a very useful script.
          • E Offline
            Ecuadorian
            ๐Ÿ˜ฒ Wow... no more lost faces (as happened with other cleanup scripts), and cleanup is top-notch.
            Here it is applied only to the horizontal white borders:
            You do realize the importance of this script in the history of SketchUp, do you? Thanks again! ๐Ÿ‘
            -Miguel Lescano
              Good to see it working on other complex models. I only tried it against one complex one, large triangulated terrain with 80K+ faces. (Though that model had all the potential problems you could run into AFIK.)
                Jim
                Ack! it doesn't look at materials?
                Oh, and thank you! ๐Ÿ‘
                  No, but that's a very good suggestion.
                  Ecuadorian did find some issues with some geometry, so I'll push an update when I've gotten around to look at it.
                    Ecuadorian:
                    I had a look at your sample file. I see the issues. I think it's a tolerance issue. I'll have to investigate a little more to tune in the tolerance.
                    • E Offline
                      Ecuadorian
                      Thanks! I think I now remember what the problem might be, also. The model is scaled a lot. ๐Ÿ˜•
                      -Miguel Lescano
                        This is strange. When I compare the dot product of various faces, I find an overlap in the return value for faces where you can erase the connecting edge:
                        	# Not coplanar
                        	# 0.999999999898786
                        	# 0.999999999901467
                        	# 0.99999999992968
                        	# 0.99999999995352
                        	# 0.999999999959393
                        	# 0.999999999974808
                        	# Coplanar
                        	# 0.999999999917881
                        	# 0.999999999918562
                        	# 0.999999999984962
                        	# 0.999999999999148
                        	# 0.999999999999408
                          I did notice that - but I exploded it and it still occurs...
                          • Chris FullmerC Offline
                            Could you take the edge, find its connected faces. Then get the object id for those faces, and get all their vertices positions. Then delete the edge if it is planar. Then test to see if those faces still exist. If they do, move on. If they do not, then rebuild them using their vertices' positions? Painful yes, but maybe useful?
                              I did that kind of stuff in my previous version, prior to 7.1 - wasn't stable. So many cases to take into account. Faces with inner holes etc...
                                I think I might have misunderstood this whole DOT product from vectors... will have to look deeper into it.
                                  Can you hit ctrl-z in ruby? ๐Ÿ˜„
                                    remus
                                    What do you think is not working? from my quick browse of your script the dot product should do what you want.
                                      Yea, http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#undo
                                      But that would ruin any kind of possibility to undo the whole erase coplanar operation.
                                        ...could create a temp group and use that to replicate the two faces (when within a range where we can't be certain.)
                                        but I'd still try to avoid that if I can calculate this.
                                        • honoluludesktopH Offline
                                          honoluludesktop
                                          Hi Thomas, I lost a texture from a face in a 61k faces model. BTW what happens when you have coplaner faces with different textures, or images placed on textured faces (say a run on a wood floor). Didn't read all the post, so sorry if already covered.
                                            At the moment it doesn't take into account materials. Only geometry.
                                            Images? You mean an actual Image entity (It says "Image" in Entity Info when you select it?)
                                            • 48
                                            • 49
                                            • 1 / 49
