    Chess Anyone?
    54 Posts 18 Posters 5.1k Views 18 Watching
    • michaliszissiouM Offline
      michaliszissiou
      Thats an excellent render ๐Ÿ‘
      There's one mistake in this model though, you know what it is? ๐Ÿ˜„
      • massimoM Offline
        massimo Moderator
        The board is inverted. H1 square has to be white. ๐Ÿ˜‰
          michaliszissiou
          It was obvious massimo. So e2-e4 ... ๐Ÿ˜†
          • massimoM Offline
            massimo Moderator
            Sure it was...e7-e5 ๐Ÿ˜„
            • boofredlayB Offline
              boofredlay
              Oops. ๐Ÿ˜†
                michaliszissiou
                OK this thread is not about chess, maybe a Ruy Lopez was coming (I play this better as black). ๐Ÿ˜„ KT f3
                Boofredlay you should render these positions. Is twilight fast enough? ๐Ÿ˜†
                  boofredlay
                  Ha ha. It may be but I am not ๐Ÿ˜†
                    in the Ru(b)y Lopez...
                    That is Fairy Chees ๐Ÿ’š
                    • david_hD Offline
                      david_h
                      Wobble Chess
                      That is terrific. But Massimo is right. . .lower right H-1 should be white. but that is fussing. The design is awesome.
                      It reminds me of Man Ray's 1926 chess set in the MoMA.
                      • massimoM Offline
                        massimo Moderator
                        ...Nc6. Be careful, I'm an expert of the Marshall gambit (especially the Steiner variation) in the Ruy Lopez... ๐Ÿค“
                        Ok, draw? ๐Ÿ˜†
                          michaliszissiou
                          B b5... OK draw.
                          • E Offline
                            Ecuadorian
                            Hey, Eric. If you replace the board with a flat one, you could render an animation of a Chess opening with cmd's Mover.rb. ๐Ÿ˜›
                            -Miguel Lescano
                              michaliszissiou
                              No, no, thats not funny, we need this particular board, its (as our friend oli uses to say) its sexy. ๐Ÿ˜† We just need Boofredlay to render positions. "chess anyone" is the name of this thread. It will take a month but this is not a problem for experienced players like massimo and me. A ray traced chess game... ๐Ÿคฃ
                                boofredlay
                                Better yet, how about I post up a chess model (I can't do the Wobble because it is FF property) and you can download it, make your move then render it with whatever you want. Even straight SU output. The trick is you have to pick a side and never play for the other.
                                The other chess board I did here at the beginning of the tread is free and clear. I have others I want to model as well... Give me a day or so and I will have one up. ๐Ÿ˜„
                                  ScottPara
                                  Eric,
                                  The wobble board is great (other than the obvious). One thing that stands out is the repeating table wood texture. With such a close shot a higher res image is really needed. Maybe a bit of bump as well but this is ultra critical ๐Ÿ˜„
                                  Nice work!
                                  Scott
                                  Love the fact that some HATE my avatar.....
                                  • massimoM Offline
                                    massimo Moderator
                                    This is a whole chess game (Kramnik-Topalov, 2003 blindfold) in a single image! ๐Ÿ˜ฎ I just love it. You can read about it here.
                                      michaliszissiou
                                      Sicilian defense now. Thats why its so beautiful. ๐Ÿ˜†
                                      • massimoM Offline
                                        massimo Moderator
                                        Hmmm...biased like any true Sicilian's player is. ๐Ÿ˜’ ๐Ÿ˜†
                                          boofredlay
                                          Ok, here is an update. I fixed the square positions, rounded some more edges, added a base to the board for more weight and changed the chair.
                                          http://twilightrender.com/phpBB3/download/file.php?id=1703
                                          • massimoM Offline
                                            massimo Moderator
                                            Now that's really nice. ๐Ÿ‘
                                            • 2 / 3
