    Chess Anyone?
    54 Posts 18 Posters 5.5k Views 18 Watching
    • david_hD
      david_h
      Thanks Boo.
      • P
        Prisoner
        Nice model (would be interesting in which way it would change your play), great render. Twilight amazes me with every new picture I see.
        • boofredlayB
          boofredlay
          I did this Wobble Chess set a while back. I think it likes Twilight ๐Ÿ˜‰
          http://twilightrender.com/phpBB3/download/file.php?id=1676
          • GaieusG
            Very cool, Eric. Great job both modelling and rendering! ๐Ÿ‘
            I can imagine it's a good set for shiops and aeroplanes as the figures can fall off harder.
            ๐Ÿ˜‰
            • michaliszissiouM
              michaliszissiou
              Thats an excellent render ๐Ÿ‘
              There's one mistake in this model though, you know what it is? ๐Ÿ˜„
              • massimoM
                massimo Moderator
                The board is inverted. H1 square has to be white. ๐Ÿ˜‰
                • michaliszissiouM
                  michaliszissiou
                  It was obvious massimo. So e2-e4 ... ๐Ÿ˜†
                  • massimoM
                    massimo Moderator
                    Sure it was...e7-e5 ๐Ÿ˜„
                    • boofredlayB
                      boofredlay
                      Oops. ๐Ÿ˜†
                      • michaliszissiouM
                        michaliszissiou
                        OK this thread is not about chess, maybe a Ruy Lopez was coming (I play this better as black). ๐Ÿ˜„ KT f3
                        Boofredlay you should render these positions. Is twilight fast enough? ๐Ÿ˜†
                        • boofredlayB
                          boofredlay
                          Ha ha. It may be but I am not ๐Ÿ˜†
                            in the Ru(b)y Lopez...
                            That is Fairy Chees ๐Ÿ’š
                            • david_hD
                              david_h
                              Wobble Chess
                              That is terrific. But Massimo is right. . .lower right H-1 should be white. but that is fussing. The design is awesome.
                              It reminds me of Man Ray's 1926 chess set in the MoMA.
                              • massimoM
                                massimo Moderator
                                ...Nc6. Be careful, I'm an expert of the Marshall gambit (especially the Steiner variation) in the Ruy Lopez... ๐Ÿค“
                                Ok, draw? ๐Ÿ˜†
                                • michaliszissiouM
                                  michaliszissiou
                                  B b5... OK draw.
                                  • E
                                    Ecuadorian
                                    Hey, Eric. If you replace the board with a flat one, you could render an animation of a Chess opening with cmd's Mover.rb. ๐Ÿ˜›
                                    -Miguel Lescano
                                    • michaliszissiouM
                                      michaliszissiou
                                      No, no, thats not funny, we need this particular board, its (as our friend oli uses to say) its sexy. ๐Ÿ˜† We just need Boofredlay to render positions. "chess anyone" is the name of this thread. It will take a month but this is not a problem for experienced players like massimo and me. A ray traced chess game... ๐Ÿคฃ
                                      • boofredlayB
                                        boofredlay
                                        Better yet, how about I post up a chess model (I can't do the Wobble because it is FF property) and you can download it, make your move then render it with whatever you want. Even straight SU output. The trick is you have to pick a side and never play for the other.
                                        The other chess board I did here at the beginning of the tread is free and clear. I have others I want to model as well... Give me a day or so and I will have one up. ๐Ÿ˜„
                                          ScottPara
                                          Eric,
                                          The wobble board is great (other than the obvious). One thing that stands out is the repeating table wood texture. With such a close shot a higher res image is really needed. Maybe a bit of bump as well but this is ultra critical ๐Ÿ˜„
                                          Nice work!
                                          Scott
                                          Love the fact that some HATE my avatar.....
                                          • massimoM
                                            massimo Moderator
                                            This is a whole chess game (Kramnik-Topalov, 2003 blindfold) in a single image! ๐Ÿ˜ฎ I just love it. You can read about it here.
                                            • 2 / 3
