    Chess Anyone?
    54 Posts 18 Posters 5.5k Views 18 Watching
    • boofredlayB
      boofredlay
      Well David as much as you play down how you did it, it is still a nice chess piece, cheers.
      And... "I fart in your general direction. Silly English types" πŸ˜„
      • david_hD
        david_h
        Thanks Boo.
        • P
          Prisoner
          Nice model (would be interesting in which way it would change your play), great render. Twilight amazes me with every new picture I see.
          • boofredlayB
            boofredlay
            I did this Wobble Chess set a while back. I think it likes Twilight πŸ˜‰
            http://twilightrender.com/phpBB3/download/file.php?id=1676
            • GaieusG
              Very cool, Eric. Great job both modelling and rendering! πŸ‘
              I can imagine it's a good set for shiops and aeroplanes as the figures can fall off harder.
              πŸ˜‰
              • michaliszissiouM
                michaliszissiou
                Thats an excellent render πŸ‘
                There's one mistake in this model though, you know what it is? πŸ˜„
                • massimoM
                  massimo Moderator
                  The board is inverted. H1 square has to be white. πŸ˜‰
                  • michaliszissiouM
                    michaliszissiou
                    It was obvious massimo. So e2-e4 ... πŸ˜†
                    • massimoM
                      massimo Moderator
                      Sure it was...e7-e5 πŸ˜„
                      • boofredlayB
                        boofredlay
                        Oops. πŸ˜†
                        • michaliszissiouM
                          michaliszissiou
                          OK this thread is not about chess, maybe a Ruy Lopez was coming (I play this better as black). πŸ˜„ KT f3
                          Boofredlay you should render these positions. Is twilight fast enough? πŸ˜†
                          • boofredlayB
                            boofredlay
                            Ha ha. It may be but I am not πŸ˜†
                              in the Ru(b)y Lopez...
                              That is Fairy Chees πŸ’š
                              • david_hD
                                david_h
                                Wobble Chess
                                That is terrific. But Massimo is right. . .lower right H-1 should be white. but that is fussing. The design is awesome.
                                It reminds me of Man Ray's 1926 chess set in the MoMA.
                                • massimoM
                                  massimo Moderator
                                  ...Nc6. Be careful, I'm an expert of the Marshall gambit (especially the Steiner variation) in the Ruy Lopez... πŸ€“
                                  Ok, draw? πŸ˜†
                                  • michaliszissiouM
                                    michaliszissiou
                                    B b5... OK draw.
                                    • E
                                      Ecuadorian
                                      Hey, Eric. If you replace the board with a flat one, you could render an animation of a Chess opening with cmd's Mover.rb. πŸ˜›
                                      -Miguel Lescano
                                      • michaliszissiouM
                                        michaliszissiou
                                        No, no, thats not funny, we need this particular board, its (as our friend oli uses to say) its sexy. πŸ˜† We just need Boofredlay to render positions. "chess anyone" is the name of this thread. It will take a month but this is not a problem for experienced players like massimo and me. A ray traced chess game... 🀣
                                        • boofredlayB
                                          boofredlay
                                          Better yet, how about I post up a chess model (I can't do the Wobble because it is FF property) and you can download it, make your move then render it with whatever you want. Even straight SU output. The trick is you have to pick a side and never play for the other.
                                          The other chess board I did here at the beginning of the tread is free and clear. I have others I want to model as well... Give me a day or so and I will have one up. πŸ˜„
                                            ScottPara
                                            Eric,
                                            The wobble board is great (other than the obvious). One thing that stands out is the repeating table wood texture. With such a close shot a higher res image is really needed. Maybe a bit of bump as well but this is ultra critical πŸ˜„
                                            Nice work!
                                            Scott
                                            Love the fact that some HATE my avatar.....
                                            • 2 / 3
