    Modeling Roofs
    13 Posts 8 Posters 1.4k Views 8 Watching
      bocomofo
      I've found that the 'roof' plugin by TIG takes care of most of my roofing needs!
      404 Not Found
      (forums.sketchucation.com)
      have you tried that?
        bocomofo
        pipped at the post by wbarch
        • dcauldwellD Offline
          dcauldwell
          Yep, I like TIG's 'roof' ruby too. It is quick and effective, but as with all things if you want more detail or complexity then you may need a different approach (mine being one such way). I need the complexity because I then use a section through the roof to illustrate the construction. But if you just want simple roof elements then TIG's is hard to beat.
          David
          Sketchup 2017
          (vray 2.00)
            MartinRinehart
            @dcauldwell said:
            I have made a 2d section through a roof
            That works, but it pushes the challenge back a step. Permit me to reformulate the question: is there an easy way to get the original cross section?
            TIG does great work, doesn't he? I looked at roof.rb but it wasn't an exact match. I want a roof of a specified depth in a separate .skp. It gets imported into a completed model (and turns into a component on File/Import). TIG makes the assumption that you want a roof on something (which is quite sensible), and that "something" is already in your model (which is not my case).
            • jeff hammondJ Offline
              i might be misunderstanding so...
              you just want a way to make the gables at different pitches?
              something like these?
              do you want them to be a set length (these for instance were drawn on top of wall 16' apart) or are you just concerned with the angle?
              are they all going to be fractional pitches (4/12, 5/12 etc) or do you use degrees as well?
                here are a couple of ideas.. one shows just the angle being made and the other shows it being made with a set span..
                the key (to me) is using the units of the pitch to your advantage.. for instance, 4/12 mean up 4 and over 12 so that how i got the angles (entering the length in the measurement box at the lower right.. i used inches but the units can be what ever you want.. if you want it to a specified degree, just use the protractor instead.
                [flash=640,385:1ca3tbdv]http://www.youtube.com/v/svuWcKQ6MWw&hl=en&fs=1&rel=0&color1=0x2b405b&color2=0x6b8ab6[/flash:1ca3tbdv]
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi folks.
                  Don't forget that you can enter pitches in the Dimension box (DB) instead of an angle when using the Protractor Tool.
                  For example, for a 4:12 roof, enter just that in the DB.
                  Using the Arc Tool with 2 segments will get you a very quick 12:12 pitch or 45° angle when you draw a half circle. You will have to unsmooth the roof apex after pulling the end face to create the roof.
                  Just ideas.
                    Jim
                    Smart modeling, Jeff. Thanks.
                      arklandesign
                      Wow.... That roof ruby script from TIG is a thing of beauty and really saves a lot of time... Its like magic :O) Now if only I could get tools on surface to work... still working on that set up... LOL
                        MartinRinehart
                        Nice tutorial! You understood.
                        Actually, I'm working on my tutorial's Ruby section and I want to suggest that this is a good example of a deceptively simple drawing that is really helped by having a Ruby.
                        Using this is easier:
