Vray Materials not reloading into model
Everytime I import and apply materials to a model in the usual way through the Vray material editor
they seem to dissapear when I close and reopen the model. The Names are still in the list but the
material settings reset to the default like would happen when you create a material from scratch.
All settings are lost etc...Anybody any ideas?
Couldn't face applying materials again and starting over for the third time
Known bug. Before you save the model, open and close the V-Ray Option window.
I'm experiencing the same problem (in SU Pro 7.1). The Options Window workaround has no effect whatsoever. A few changes stick (e.g, inversion of a bumpmap bitmap), most are lost, no matter if I open and close the options window and save and reload the model. Changes that get lost seem to be lost the very moment I hit Apply - the material preview doesn't change, and if I reopen the panel that I just closed values will already have reverted back to their initial state.
This is a pretty serious and seriously galling bug to find in software with this pricetag!
