    Maxwell V2 is out
    extensions
    76 Posts 12 Posters 13.8k Views 12 Watching
    • F Offline
      frv
      Oh, and Richard, for as long as the bugs are not yet resolved, could you set up a different photo for your profile. You look like a its all perfect for you now. We might send the wrong message to Nl ...
      • RichardR Offline
        Richard
        Mate I'm not on OSX, PC!
        I know what you mean about maxwell in comparison to the cheaper apps, it is hard to break away from the devil you know, particularly when it actually works!
        I recently did a stack of renders for a project home builder, he would come to my office and I would model his facades with him, testing various configurations and material tests, I would push out maybe 20 different tests in a day all flawless and all eye catching to the client (albeit without landscaping). For that purpose it was and still (1.7.1) the perfect solution!
        Initial tests with V2 are proving that the quality is vastly improved and given the previous quality thats hard to imagine! Bump response thankfully is just so much better now.
        I found a fair few of my problems were caused by a bad first install, the second install fixed many of the issues though some still persist!
        Yeah your right its hard to look pissed off with a smiley face!!!
        I've not totally written off the upgrade to V2, I've always stuck by my patience toward waiting till the bugs are fixed with any x.1 release and keeping finger crossed! That siad I will probably still invest in Thea when released, though there it is easy for me to dispell if initial clean up is slow! There in lies my ongoing issue with Indigo, such a great app but initial clean up meant quick testing / tweaking eroded it's worth.
        I'd much rather something take twice as long to final quality as long as the initial clean is fast - I'd rather spend less of my time waiting over the pc just crunching in the end!
        BUILTBRAND.COM.AU
        • brodieB Offline
          brodie
          Richard,
          Which version of Windows are you on? I'm running Vista 64 and am getting ready to make the switch to 2.0. I'm hopping it's not a Vista issue. I'll probably switch to Windows 7 when it comes out though so maybe it won't be a big deal either way.
          -Brodie
          • F Offline
            frv
            I need Maxwell for all its options to tweek the settings. If you know what you are doing the proces is actually fast. Proxy components, 2 point perspective (shift lens), rather fast till SL 10 which works for me in most cases and its real light simulation.
            I can already get a look and feel of how a design will work in natural light. That means I can experiment with dark or light colors, less or more reflective surfaces etc. Other apps are too much a matter of articficial tricks to get good results. Natural light simulation is a bit like having a studio with with handmade actual buildingmodels available.
            I got a mail from NL that they are working on the autoMXM issue under OSX. I am sure it must be a simple bug, MXM reporter also ran into a bug in the way OSX writes a path to the library and he fixed it somehow.
            • W Offline
              Whaat
              Hey Richard,
              I am surprised at your comment. Indigo's speed has improved drastically in recent releases. For example, if you are rendering an exterior and you have the Tracing Method set to 'Path Tracing' the overall image is clean very fast (usually in a matter of seconds). Of course, areas of indirect light will take longer, but to say that Indigo is not acceptable for quick testing / tweaking is just not fair. The initial clearing for MLT methods take a bit longer so maybe you had been using this setting for your exteriors?
              Indigo also supports region rendering, so if you are testing/tweaking, you can render just the region you are interested in and the noise will clear even faster.
              • W Offline
                Whaat
                @kwistenbiebel said:
                Also, you can easily launch several renders at the same time (I sometimes launch 5 simultaneously on my octocore using Indigo 64 bit, while still being able to continue modeling!).
                😮 😮 Time for new computer!
                The fastest workflow I experienced using any render engine,especially in terms of material and light setup!
                That's a very strong statement. 😄 Any chance we could quote you on that on the Indigo website? (PM me if you prefer)
                • StinkieS Offline
                  Stinkie
                  True, though. Kwist is absolutely right.
                  I own both Maxwell and Indigo, but I hardly use Maxwell anymore. This is due to SkIndigo.
                    kwistenbiebel
                    The MacPro (using Windows) that I bought a year ago has proven to be my best investment ever. The 8 core Xeon costed twice as much as the usual 4 core rig, but it easily tripled the joy of working and productivity. I took the thing with me to Australia as I can't miss it.
                    I meant what I said. Material setup is literally a 2 second thing. I always start with clicking one of those material presets and quickly change some numbers. Done. (I am using Skindigo 1.1.15 for now but I want to upgrade to 2.x).
                    Feel free to quote . I feel special now 😄
                      kwistenbiebel
                      I can say the same about Fryrender. Bought it, but hardly ever use it anymore.
                      Developers should understand that the bridge to the host app (in this case Sketchup) is crucial!
                      You can have a superb render engine, but with a crippled SU plugin, it's worth nothing.
                      • StinkieS Offline
                        Stinkie
                        Hm, yes. At the very least, both NL and RC should implement a material making workflow similar to SkIndigo's. That, I think, would make their respective products far more usable to SU users. Or at least to the ones who, like me, couldn't care less what the IOR of a mat is, or how many layers of varnish it has in real life. 😄
                        • RichardR Offline
                          Richard
                          Yeah I'm probably over critical from past experience with Indigo and admit to not having tested the latest version. I was always waiting for a dumbing down of terminology before I went there again.
                          I did download the latest version the other day prompted by chris the new zealand distributor so will give it a run again!
                          I think I gave up earlier (though I liked the results) I couldn't get my head around the material blending setup for including weathering and dirt maps that required me to have all materials in scene and the problems that caused when doing a purge and the inherant issues of large maps in SU! I should investigate more I guess OR just not make niave comments. Hopefully those issues are overcome now!
                          I do wonder though how without a studio type feature you guys do quick tweaking of materials - does this mean you need to open each material individually in the editor? and how you adjust light intensities without a Multilight type feature or is there one? And how do you handle heavy poly scenes?
                          Must say I really do like the auto subdivide feature for displacement - one of the benefits obviously of having a good plugin developer!
                          Whaat BTW have you seen the MXM reporter pluging that a guy posted to the forums here, makes material linking so easy and something work considering in Indigo's workflow!
                          Kwist? I'm not sure what you mean about distructive? You don't have to use studio, though for me on a recent project it was a godsent (stack of similar renders for one project builder 30 scenes), I just modelled my scene in SU with materials named and then exported the scene out shut down the render and then dragged into a fully setup MXS (studio file) where I had all materials to be used over the range of renders and then just used the "replace all new with existing" feature and then tweaked material colours or drag / dropped alternatives. Really simple and amazingly fast!
                          I just modelled in SU using feally bold colours or low res B/W bump maps with wild colours added through SU material editor (like blue or red, green etc) so modelling, nav and that darn SU material browser popup (f...!!!) is all kept fast - no linking, no fuss! This I guess is one of the things that I do enjoy about MR the ability to work in a stack of different workflows!
                          I'm also keen to see now how the material blending works as said earlier just couldn't get my head around it earlier and the distructive issue of the UV's then if the geometry was edited was a downer! Though it is one feature that has it over the others that UV's for each blend map can be assigned in model! Also to see how weight mapping is handled, I've come up with a simple way of making all my lowpoly interiors for exterior scenes use just the one map and one MXM - beats the pants off having multiple materials to deal with!
                          BTW is there a multilight type feature for Indigo?? These days I'd be a bit lost without that, I've become very lazy!!!
                          Seriously I'll check out Indigo out again, I haven't gone through the documentations or all the features but clearly from the comments it has seen some major improvements!
                          @ brodes - mate I've only tested on XP 32bit at this stage, will test on Vista 64bit soon!
                          I'm blown away by the improvements in Bump map results by the way it's almost like your using displacement now! And the new AGS wizard (although I didn't like it at first) is so cool once you play with it, so easy now to set good glass!
                          Still I yern for a better way to handle IBL's with respect to location and channel intensity!!!
                          Not so happy with the conversion of 1.7 materials > 2.0 materials.
                          And hopefully soon they overcome the bug when using physical sky that the first emitter in the emixer has to be turned off or the scene turns to snow!
                          BUILTBRAND.COM.AU
                          • brodieB Offline
                            brodie
                            Richard,
                            Good comments. I'd have to agree that Studio is definately a plus. As you say, one doesn't have to use it (it would be nice if the plugin was such that this were more true than it is) but it's there if you want it. As I've said before, I don't know how one would do an arch-viz scene with lots of trees/cars without it.
                            I hope vista doesn't have the problems you've had with XP. But you're just getting Vista 64? Man, Windows 7 is coming out in, like, a week! By all accounts it solves a lot of the crap which Vista has.
                            I am excited about the bump. I haven't had much chance to play with it in the demo but it's exciting that it and normal mapping are working as they always should have.
                            -Brodie
                            • RichardR Offline
                              Richard
                              -Brodie
                              No mate my laptop runs Vista (grrrrr, shit!) yeah I've been waiting for 7 before I spring for a new machine!
                              BTW B/W bump maps seem to do REALLY well now too! I think they heard you and I ranting in that long bump issue thread!!!
                              BUILTBRAND.COM.AU
                                remus
                                I usually do it by going back in to skindigo and editing the material there, you can then re-export just the materials in the scene (so you dont have to export the mesh again, big time saver with large models.)
                                yes, its called light layers. When your creating emitting materials you can assign them to a layer, then when your rendering you just go to the layers interface and tweak away. You can change the colour as well, a la colour multilight in v2.
                                • RichardR Offline
                                  Richard
                                  I guess thats one of the things that having a studio feature has at advantage, it is so fast to go through a list of materials for editing where one can drag and drop maps from other materials and / or replace materials to geometry. And of course to do this without full entourage where it can be gragged in later.
                                  The light layers functionality sounds great!!!
                                  BUILTBRAND.COM.AU
                                    remus
                                    Most likely using proxies. If you call your tree component "tree" then make a new component of a tree shaped box and call it "tree_dummy", all the "tree_dummy" components will be replaced with "tree" components on export.
                                    • F Offline
                                      frv
                                      I just downloaded SKindogo and I am impressed. After working with Maxwell since it came out I think its time for a chance. NL(Maxwell) has a company-character bug that could be described as indifference toward their clients. Maxwell by itself is a rather superb application but the userinterface just does not make sense. That is because they hire the wrong people to do the job. They don't see it themselves and due to the amount of modeling app's they cater to they can not really provide service or decent plugin's update to keep up with the bugs.
                                      I now own the v2 of Maxwell but can not use the appropriate plugin to render with, I have to reinstall the old plugin to export to Studio and render from there. If they had tested this at all on an OSX system they would have fixed it before releasing the update. Another problem is that NL markets Maxwell v2 as something big for a while so you get all excited. It feels like having tickets for a big show and when you have seated yourself to watch it happen a curtain rolls down before your OSX-SU seat that reads sorry we did not expect you here, wait till the next show..... 😞 For how many times would you put up with that. I do not give up so easily were I should have quickly moved on. I am going to seriously look into Indigo, tx Kwistenbiebel for showing me your examples. How did you do the trees rendered in SKI ?
                                      By the way Richard, you are right about the rather messy new layout in Studio. even though it is advertised as comletely new and rewritten it still lacks hiärchy. Its hard to find what you need and it is needlessly complicated to work with.
                                        kwistenbiebel
                                        I didn't use proxies in those images.The tree in the front isn't really that high poly and there's a 2D clipmap tree line in the background.
                                        The whole scene doesn't weigh more than 11 Mb.
                                          kwistenbiebel
                                          I have to agree with Whaat.
                                          Indigo, even though it is unbiased, works very well in a design workflow of trial/error and constant design changes.
                                          The biggest advantage of Indigo over Maxwell is that the workflow is 'non-destructive' as you don't have to export to a 'studio' every time you do design changes.
                                          The only disadvantage of Indigo, but that counts for Maxwell as well, is the render time to get things clean.
                                          That is the reason why I also use Vray.
                                          An example of how I use Indigo for pre-design (extension of an existing office building):
                                          Those 4 images were rendered simultaneously. Launched all of them in the evening, put together on a sheet the next morning, ready for review.
                                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/A3-sheet-small1.jpg
                                          • RichardR Offline
                                            Richard
                                            Ok I've had a play with Indigo again and see there has been some huge development on that side!!
                                            Speed of initial clean up (my biggest concern) I'll still stick with my initial thoughts that it's slow in that regard, rendering out at 640 x 480 res allowed by the demo seemed very slow in comparison to Maxwell when rendered in any of the unknown terms!
                                            There certainly are thing that REALLY shined in regards to the tonemapping, camera, film etc settings once rendering and these seem to be the real beauty of indigo though man are there still so many darn tech terms and thing for me that could be made so much more simple!
                                            Being able to select from multiple film responses and adjust sky and sun levels independantly was a beauty though I so wished these and other lighting layers could be named rather than trial and error! How does on zoom in on the render window?
                                            Still have little understanding of the material editor eg is 20 for bump high? (who knows without reference limits), what does the power slider do? Is it an exponent increaser for all settings? And for god sake why does Indigo have to utilise every single terminology adverse to the norm if x=R, y=G, Z=B why not just RGB and have it done with it! Not an individual biggy but just reinforces I guess my belief that the developers have always just taken the tact of proving one up on the understanding of all the techno talk that goes into producing an engine!
                                            Material blending is still feeling clunky and the need to go back into SU each time to make a material change when preview is painfully slow
                                            How does one stop the material preview for generating? And again the material preview is SO slow!!!!
                                            OK these are just initial thoughts but many however do in some way reinforce my earlier feelings, that said howvever I do see some of the inherant beauty of Indigo as a useful tool just seems it's still a ways off being particularly user friendly and still feels beta like!
                                            Seriously I do't wish to sound negative I do see some amazing potential here but just wanting a much faster and intuitive workflow I guess! Well done has to be said on some of the Indigo features all round!
                                            BUILTBRAND.COM.AU
                                            • 3 / 4
