    [Plugin] Mirror UV Mapping (1.0.3)
    35 Posts 17 Posters 34.0k Views 17 Watching
      It doesn't mirror triangles?
      • free agentF Offline
        free agent
        woah thats wierd, it refuses to mirror on a mesh ive imported, but works fine on a quick separate test... can i send you the problem mesh?
        http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          Yea, do so. I'll have a look at it.
          • utilerU Offline
            utiler
            @solo said:
            Someone mention ex frog?
            http://www.ruffordsmallgrants.org/files/rana muerta.jpg
            I liked it Pete..... ๐Ÿคฃ ๐Ÿคฃ
            Just Curious...
              If you tried to email me anything then it might very well be lost. My host messed about with some files and I lost my email aliases. ...grumble...
                araki009
                Thank you very much thomthom for plugin
                  chango70
                  Tom sorry for my stupid question. What exactly does this plug in do? Apply texture to both sides?
                    It copies the texture and it's UV coordinates from one side and to the opposite side.
                      chango70
                      Ok thanks very useful in certain situations.
                      • Y Offline
                        Yanman
                        Hi thomthom .Thank you very much for Good plugin. ๐Ÿ‘ ๐Ÿ‘
                          Ruturaj
                          ๐Ÿ˜„ ๐Ÿ’š ๐Ÿ˜„ ๐Ÿ˜‰ ๐Ÿ˜ฎ
                          Thanks,
                          RuturaJ
                            ploink100
                            Is there a plugin that can lock & unlock specific 3D sketch after using the push/pull tool so that a certain dimension of 3D sketch is glued? There were times I accidentally re-pull/push portion of the sketch.
                            I will be happy if someone can give me a link for the plugin, or someone can make such plugin.
                              hm... maybe Driving Dimmension...?
                                Maybe you don't need a plugin. Maybe it is a training issue.
                                Based on your description it sounds like you have pre-selected the face before you apply Push/Pull. Either don't pre-select the face (Push/Pull will work without pre-selecting) or just hit Esc after the Push/Pull operation is completed. No plugin required.
                                  ploink100
                                  You are right Dave R...
                                  It is an issue for me, an issue for beginner and intermediate user, and may also be an issue for some professional user. My point is to prevent such issue so that you dont have to train your hands and mouse cursor. I thought of before someone could make such plugin. And maybe you dont need such plugin if it is in the menu when you right click the mouse; locking a point, a line, axes[X,Y,Z], or a plane[face].
                                    So it sounds like you'd rather have a plugin than to learn to use the tools correctly? Is that what you are saying?
                                    • 2 / 2
