    [Plugin] Mirror UV Mapping (1.0.3)
    35 Posts 17 Posters 34.5k Views 17 Watching
    • soloS
      Someone mention ex frog?
      http://www.ruffordsmallgrants.org/files/rana muerta.jpg
        Errrhh... ๐Ÿคข
          davide.skp
          Ivรกn, for now i'm playng with tree[d] and Hothouse 3d... this one, hothouse, seems very very good!!! ... I try xfrog but ... too expensive ((and complexxx) for me ๐Ÿ˜ž ...
          so, TRY HotHouse ...
          A) create your plant with hothouse
          B) for a light model create some billboard ... from a photo or directly from HotHouse
          C) import directly in sk
          d) With the WONNDERRFULLL ThoMThom'plugin Mirror the uv map...
          very very funny!!!
          • I
            ideas_arte
            very very funny!!!
            Thank you very much..! to share this info, ๐Ÿ˜„ I will try to make some little pines ๐Ÿ’š
            Take care ๐Ÿ‘
            • free agentF
              free agent
              thomthom have u looked into the texture mirroring to the backfaces of triangles? is it possible?
              http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                It doesn't mirror triangles?
                • free agentF
                  free agent
                  woah thats wierd, it refuses to mirror on a mesh ive imported, but works fine on a quick separate test... can i send you the problem mesh?
                    Yea, do so. I'll have a look at it.
                    • utilerU
                      utiler
                      I liked it Pete..... ๐Ÿคฃ ๐Ÿคฃ
                      Just Curious...
                        If you tried to email me anything then it might very well be lost. My host messed about with some files and I lost my email aliases. ...grumble...
                          araki009
                          Thank you very much thomthom for plugin
                          • C
                            chango70
                            Tom sorry for my stupid question. What exactly does this plug in do? Apply texture to both sides?
                              It copies the texture and it's UV coordinates from one side and to the opposite side.
                              • C
                                chango70
                                Ok thanks very useful in certain situations.
                                • Y
                                  Yanman
                                  Hi thomthom .Thank you very much for Good plugin. ๐Ÿ‘ ๐Ÿ‘
                                    Ruturaj
                                    ๐Ÿ˜„ ๐Ÿ’š ๐Ÿ˜„ ๐Ÿ˜‰ ๐Ÿ˜ฎ
                                    Thanks,
                                    RuturaJ
                                    • P
                                      ploink100
                                      Is there a plugin that can lock & unlock specific 3D sketch after using the push/pull tool so that a certain dimension of 3D sketch is glued? There were times I accidentally re-pull/push portion of the sketch.
                                      I will be happy if someone can give me a link for the plugin, or someone can make such plugin.
                                        hm... maybe Driving Dimmension...?
                                          Maybe you don't need a plugin. Maybe it is a training issue.
                                          Based on your description it sounds like you have pre-selected the face before you apply Push/Pull. Either don't pre-select the face (Push/Pull will work without pre-selecting) or just hit Esc after the Push/Pull operation is completed. No plugin required.
                                          • P
                                            ploink100
                                            You are right Dave R...
                                            It is an issue for me, an issue for beginner and intermediate user, and may also be an issue for some professional user. My point is to prevent such issue so that you dont have to train your hands and mouse cursor. I thought of before someone could make such plugin. And maybe you dont need such plugin if it is in the menu when you right click the mouse; locking a point, a line, axes[X,Y,Z], or a plane[face].
                                            • 2 / 2
