    [Plugin] Tree generator v0.2
    36 Posts 20 Posters 90.6k Views 20 Watching
      a4chitect
      few more pictures (1 min job)
      1.draw line (root line - pointing upwards)
      2.run l-system
      3.select all top branches, run Qhull>Pointify [voronoi/convex hull script]
      4.select all created construction point, run Qhull>Export points
      5.run Qhull>Convex hull
      [sometimes this doesn't do a thing when running the second time, try opening command prompt, go to sketchup\plugins\qhull
      and type this 'qhull.exe TI points.txt Qj o TO qhull.txt' and press enter. then run Qhull>Convex hull in sketchup again]
      6.select convex hull, make it into a group, scale this group by 1.1 around center
      7.select all tree lines
      8.run didiers line2cyl script (precision used is 5)
      • K
        kwistenbiebel
        Great idea 😄
        It would be great if those lines that are generated (the branches)could be components.
        In that way, people could perform a 'substitute component' and replace it by their custom made branch.
        The same goes for leaves....replace it with low poly clipmaps or full 3D leaves etc...
        I can imagine some people want low poly branches and other people want high poly ones for rendering.
        • K
          kwistenbiebel
          You also might want to check out this thread on the Podium forum about the sketchup 'Tree Factory'. I made some trees with it, but it works manually. It would be great if it was made into an automated script though 😉.
          (scroll further down the page):
          Unknown Forum
          (www.websitetoolbox.com)
          TREE FACTORY 2.skp
          TREE_FACTORY.pdf
          • I
            ilay7k
            also using applyto-script for changing
            then using displ.or bump map to branch in your favorite render.engine
            Konstantine(aka mentor) use lsystem(onyxtree4max and Houdini) made such http://www.3dmentor.ru/3dcenter/branch_grow_01.mov and http://www.3dmentor.ru/wip/dbm3_test_45.jpg, http://www.3dmentor.ru/wip/dbm3_test_36.jpg ....
            • K
              kwistenbiebel
              An example tree made with the Tree Factory:
              http://i140.photobucket.com/albums/r3/kwistenbiebel1/PART 2/treefactoryexample1.jpg
              (SU file see attachment)
              I am convinced that with a 'component substitution' method (branches and leaves as components), a Tree generator plugin could have the potential to make Xfrog quality trees easily.
              It would only involve modeling some nice branches and leaf clusters as components to load in a "L-system" plugin as A4chitect started .
              treefactoryexample.skp
              • RichardR
                Richard
                Unknown Forum
                Hey mate you did well to drag that up it's been around now for years, thanks for posting it it was one of the first things I ever did with sketchup and lost the tut somewhere in my system! I do remember some years ago working with one of the scripters Rick? who did get part way to making a script to automate variations of trees from those original camponents.
                I'll see if I can dig it out and find who it was, might have his details in the script.
                Must say with the quality of onyx's package - hard to beat that - though I would love to see someone write a script to find similar geometry within a component and make them nested replacing each instance of the similar geometry with a component.
                Meaning say you have 2000 leaves each of similar geo but the location and orientation differs the script searches each instance of this similar geometry and replaces it with a copy of the first (component) and locates, rotates the new component to suit the geometry being replaced.
                BUILTBRAND.COM.AU
                • K
                  kwistenbiebel
                  Hi Richard,
                  I did wonder which Richard it was who made that tutorial 😉.
                  It turned out to be you....so Kudos to you for both the tut as the original tree factory SU file.
                  I had lots of fun with it and having an automated version would be awesome.
                  Hopefully one of those fine scripters sees something in it and develops it further.
                  • bigstickB
                    bigstick
                    This looks fantastic, but it doesn't look like they are for SketchUp. I'm sure someone could implement this sort of thing though. We have some spectacular complex plugins, it's a case of one of the ruby gurus getting inspired to write one which builds trees though I guess 😄
                    • JClementsJ
                      JClements
                      http://xaraxtv.at.tut.by/products.htm
                      The LSVG utility (fractal generator) type approach looks interesting. The author has already modified his spiral generator to produce DXF output for SU users.
                      It would nice if there was a way for Ruby to create these patterns and to do so using a similar interface.
                      • E
                        Ecuadorian
                        I hereby bump this ancient thread as I think it contains really interesting ideas. 👍
                        Perhaps a combination of...
                        • The fractal generator in this page
                        • Richard's Tree Factory techniques to place some branches in the generated lines
                        • Some nice .png clipmaps applied to low-poly elements for smaller branches and leaves
                        ...would be excellent. I mean, something like this:
                        http://sketchup.google.com/3dwarehouse/details?mid=eaf0e00f27efcd4746db4da39bd77ac3
                        but with more 3D elements and smaller clipmaps so they are less noticeable.
                        -Miguel Lescano
                        • soloS
                          I hope I'm not speaking out of turn or raising unrealistic expectations but Tom (Tomsdesk) is busy with a few things that so far look very promising, I was fortunate to get a prototype of a realistic tree he made and must say it's frigging awesome and works great with SU, in fact It's a 2.8 tree (more than the normal 2.5, but not exactly 3, which can be massed and viewed from any angle including top, I had 200 in ascene without glitch.
                          Hopefully he will be done soon and post some images or samples.
                          • C
                            chango70
                            That sounds great! Can't wait!
                              Justo79
                              Ditto
                              Cheers
                              Justin
                              • AdamBA
                                AdamB
                                Good to hear.
                                I got a model last month with a tree apparently authored by a well known poster in these parts..
                                It has 18600 groups, 19000+ component instances and 260,000 triangles. For 1 tree. Ay Caramba!
                                Procedurally generated stuff does tend to go nuts very quickly. I was wondering whether to write a tool that reports how "dense" each Component Definition you have in your model. Polygons / cubic meter type thing as I keep seeing models with an innocent chair or table in the corner with absolutely insane detail in comparison with the rest of the model.
                                Adam
                                • PixeroP
                                  Pixero
                                  Ouch, and I thought for a moment you would write a low poly tree script. Well, well. 😒
                                  Question: Would it be very difficult for someone to write a directx (filename.x) importer to SU?
                                  I have this great tree[d] software that might be useful if there was a way of getting the model into SU.
                                  • RichardR
                                    Richard
                                    I'm keen to see tom's trees.
                                    There has to be a good way to get trees working light weight for SU that will also work in renders! Large clips don't work so well for foliage as they tend to show an edge in renders.
                                    I started working on a few ideas and some where proving very light weight and worked well in depth when rendered but they soon ended up exactly in the same spot as my low poly cars - working well but left to be done one rainy day! I've got to order a new box to crank out faster tests then I'm on again!
                                    You have to say Pete the ones you see from your own work with Vue, full 3d trees are really required for rendering, watercolour renders are a different thing. Hopefully Toms new idea can break the back on this!
                                    BUILTBRAND.COM.AU
                                    • RichardR
                                      Richard
                                      Yeah I've got that and did that but cant remember how, I think pete had another way to do it too! I think I ended up getting it through to SU as an obj file with jim's plugin after another process.
                                      It was a really cool little application, I remember at the time emailing the developer and suggesting he was really on to something and to keep at it!
                                      BUILTBRAND.COM.AU
                                      • B
                                        BTM
                                        This reminds me of a code I wrote at the start of the month 😮
                                        It was originally just an idea( I have a lot of mostly-useless codes i've written), and didn't end up with very realistic results. I mostly based it on how to add thickness to branches, though they are all separate segments and not really attached, and not so much on the branch-generation (which was buggy).
                                        (Amount of 2nd and 3rd stages of branches can be set, as well as radius, amount of circle-segments of branches (detail), and length of branches.)
                                        Tree generator v0.2 vs. my tree gen thing.
                                        • E
                                          elteja
                                          It's a research project that analyses how to design fractal objects
                                          http://www.ideascad.es/project.php?id=4
                                          • majidM
                                            majid
                                            I am still waiting for a more advanced tree-generator ruby, hope to see it soon.
