    Modelling in a terrain
    18 Posts 5 Posters 2.2k Views 5 Watching
    • charly2008C
      charly2008
      Yes pete you are right.
      Karlheinz
      • soloS
        What i would do is create a single texture in say photoshop, and then apply it to the mesh using a top view projection
        Here is an idea, first is image of terrain and then a quick render, terrain attached.
        I did this very fast, you can obviously do it better.
        quick render test.
        http://img13.imageshack.us/img13/2676/terrainkarl1.jpg
        • charly2008C
          charly2008
          Dear Pete,
          you are the greatest. That is so simple but you have to know it. I tried it immediately and the result was a little bit different from yours. Did i something wrong? Before i projected the texture i removed all materials from the terain.
          Karlheinz
          • soloS
            hmm..
            I exploded your model when I removed the building, so maybe that helped.
            • soloS
              Another example of how I do it
              http://img3.imageshack.us/img3/1566/terrainpasting.jpg
              • charly2008C
                charly2008
                It worked now. This terrain from you is also i nice example.
                Thanks again
                • charly2008C
                  charly2008
                  With inserted model
                  • GaieusG
                    Yeah, you cannot project a texture on a group/component (unfortunately).
                    Nice Roman fort, BTW
                    A drawback of this technique however is that SU cannot handle very big image sizes (by default, only 1024x1024 max) and from a closer shot, the image can become rather pixelated. If you have the patience however, you can cut the (big resolution) image as well as the terrain into proper sizes and do a multiple projection.
                    • charly2008C
                      charly2008
                      Why everytime new buildings? I know the terrain texture isn't perfect.
                        m48
                        hi!..a have a little question.
                        The top view of the mountain, that texture, you did´t all whit Photoshop?
                        Tks for the help!
