    [Plugin] 2D Tools
    791 Posts 178 Posters 588.7k Views 177 Watching
    • majidM Offline
      majid
      thax again dear master TIG ...for all you are doing for us...
      but 2d hatch never worked for me ,at any version... what do you guess?
      also it is a while that I've lost "search panel" beside my explorer, does it depends on?
      • F Offline
        Foun10Head-X
        A newbie here wanting to say many thanks.
        • N Offline
          nurg
          thanks cool plugin
            Please start the 2D Hatching Tool with the Ruby Console open and send us the messages that appear there - if any.
            Also report what it says on the Bottom of the Screen 'VCB' bar...
            We will fix it... โ“
              Version 3.0 is now available here...
              http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
              There has been a general re-write to improve robustness.
              The 'Help' section is now in htm format and suits all platforms,
              A brand new tool 'Adjust' has been added - this allows you to Select a set of Target-Lines and then 'Adjust' [Trim/Extend] Picked Lines to them [Target-Lines can also be Adjusted]. It is quick, intuitive and easy to use - with simple mouse-click-to-pick or mouse-drag-with-button-down-to-multi-select, then double-clicking to toggle between target-select and line-adjust [or exit], there is easy add/remove to targets-set by toggle-key <shift>, clear VCB prompting, and informative color changes to targets-set and the cursor [orange during stage1=select-targets, cyan during stage2=adjust-lines] etc...
              Feedback please...
                Ben Ritter
                TIG, thank you again for the incredible tools.
                Like Majid, the hatching tool has never worked. Here is what I get with Ruby Console open:
                "Cancelled 2D Hatching.
                Error: #<NoMethodError: undefined method display_name' for nil:NilClass> C:/Program Files/Google/Google SketchUp 6/Plugins/2Dtools/2DhatchingTool.rb:134:in onMouseMove'
                Error: #<NoMethodError: undefined method `display_name' for nil:NilClass>"
                Then this message keeps repeating as I move the mouse.
                Ben
                  I think I've fixed this '2D Hatching' glitch that some of you were experiencing - I had to try very hard to make it fail on my PC at all, but now I know what the message is it's a bit clearer ! ๐Ÿ˜’
                  Here's v3.1 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                  Please try it and see how it goes...
                  ๐Ÿ˜ณ
                    Thanks TIG. I never did have a problem with the hatching but I appreciate your continued attention to detail.
                    BTW, immediately above the link for the ZIP file it says that the file is no longer available. I'm guessing that just needs to be edited?
                      This Hatching glitch needs you to do a sequence of things when you first run the tool, that then mess it up subsequently ! Took me ages to work out what, as like you I had no problems with it at all...
                      I think (hope) that's now trapped...
                      I've also edited that initial 'typo' in the post !
                        Ben Ritter
                        ๐Ÿ˜ณ
                        I appreciate how quickly you fix things TIG, however, I still can't get the hatching to work with v3.1. It cancels out right away and I don't even get a chance to see anything in the VCB.
                        Thanks again for this great script.
                        Ben
                          ๐Ÿ˜ณ
                          Ben
                          Aaargh! ๐Ÿ˜
                          What messages do you get in the Ruby Console ? What is your OS and your Platform SUp version etc... ? It will get sorted - still works for me... ๐Ÿ˜ณ
                            Ben Ritter
                            Aaargh! ๐Ÿ˜
                            What messages do you get in the Ruby Console ? What is your OS and your Platform SUp version etc... ? It will get sorted - still works for me... ๐Ÿ˜ฎops
                            TIG, like I said, the message in the console is "Cancelled 2d Hatching". That's it.
                            I am running on an HP, quad core, 2.67 ghz, Windows XP/Service Pack 3 and SU 6.4.112.
                            Sorry. ๐Ÿ˜ž
                            Ben
                              @ben ritter said:
                              Aaargh! ๐Ÿ˜
                              Sorry. ๐Ÿ˜ž
                              Ben
                              None of this should be causing a problem ! Although XP+SP3 and SUp v6 is a 'constant', but I can't see how it makes the thing fall over... I'll try some alternatives. I'll continue this by PM with you and Majid... We WILL fix it... ๐ŸŽ‰
                              • JClementsJ Offline
                                JClements
                                TIG:
                                I set my Z at 10'
                                I draw a circle.
                                I import a jpg photo which is placed automatically at Z=0. The image is under the circle.
                                I get the Face Make and click on the point in the circle. The circle gets a face and a color AND the image under gets "painted" too.
                                • mitcorbM Offline
                                  mitcorb
                                  TIG:
                                  The hatching tool simply does not engage for me, version 3.0. The bottom left line instruction is only there for an instant, saying choose a pattern and it does not make the call to the folder. I am running XP SP3 with a Pentium 4. Yes, I know it is an old dog, but it limps along.
                                  I am getting ready to deploy version 3.1 with the console open.
                                  mitcorb
                                  EDIT ok 3.1 returns "Cancelled 2D Hatching" in the console and the bottom left message is only there for an instant on activating the hatching button. Repeatedly clicking the tool repeats the console message--no other information, no ruby code or anything.
                                    TIG, FWIW, it's still not giving me any problems. Hatching works as advertised for me. I opened the console and it remains blank while running the plugin.
                                    I wonder what it is that is different between my installation and these folks who are having problems. Is there something we can do to compare installs or something? Is it possible that something else is running that is causing the problem?
                                    • EarthMoverE Offline
                                      EarthMover
                                      Yes, hatching has always worked well for me, also. SU 7 Pro on Vista.
                                      I am having an issue with the line tool. Not sure if it's a bug. I try to click once and pull the line out on an axis and then type in the distance in the vcb, however the line doesn't draw and I get a partial construction line. I don't remember it having this glitch in the previous versions. Is this intentional and maybe there is some feature I don't know about?
                                      Here's a screen record of what's happening. http://screencast.com/t/vcIikXHeg7
                                      Content Creator at Skapeup
                                        @jclements said:
                                        TIG:
                                        I set my Z at 10'
                                        I draw a circle.
                                        Thanks for the feed back.
                                        I that case - make a Face for the Circle by using the Normal Line Tool and drawing over one of the Circle's Segments. The Image Face won't change now.
                                        What I do in the next release is either to have a <Shift> toggle so that it makes Faces only to found Loops without Faces OR toggled it makes Faces to all found Loops including existing ones and <defaults> the Material and flips it up if needed OR alternatively I might just limit the Making of Faces to any Loops on the Z (in your case at 10'). I might also need to do this for Hatching as it works in a similar way... I'll make a decision about which way to do it shortly...
                                          Thanks for the feed back...
                                          The Hatching issue seems related to XOsp3 and v6 BUT I am on to a fix for those users... I would like to know if the LineStyle Tool works for those with Hatching problems, and what happens if they right-mouse click when hatching is failing...
                                          The Line Tool didn't use to do this - a fix on the inferencing has made this new glitch... I'm onto a fix - watch for next release next week... The problem is that the <Enter> after the VCB input seems to be taken as a 'end this line-set' command and the line isn't made and the temporary cline/cpoints etc don't get tidied up like at other times... I think a fix will be relatively easy... โ“
                                            EarthMover
                                            Thanks TIG! Regular line tool will do for now.
                                            • 39
                                            • 40
                                            • 5 / 40
