    Where to Start with Ruby?
    18 Posts 10 Posters 2.5k Views 10 Watching
    • G
      Gruff
      Thanks everyone for all the advice.
      So there is no programming environment with a debugger for Ruby inside Sketchup. (Similar to VBA inside Solidworks, Inventor, Autocad, IntelliCad, Excel, Word, Etc...)
      Sigh
      Does Sketchup Expose their API externally for other languages?
      (Or for that matter stand alone Ruby for Windows.)
      I notice that when I pull up VB6 there is a reference for the Sketchup Library. I cannot instantiate the SU Application object though. No errors. the object just returns a value of nothing. Wierd.
      Private Sub Command1_Click()
        Dim oSU As SketchUp.SkpApplication
        Dim oDoc As SketchUp.SkpDocument
        Set oSU = SketchUp.SkpApplication
        Set oDoc = oSU.ActiveDocument
        MsgBox oDoc.Description
        Set oDoc = Nothing
        Set oSU = Nothing
      End Sub
      Resistance is .... Character Forming. Grin
        There are some various solutions to plugging an debugging IDE to SU. I've not tried it - but you find them if you search for "debug".
          RickW
          The SDK exposes SU to C++, but from what I hear, it's a bit of a mess.
          RickW
          www.smustard.com
          • G
            Gruff
            Thanks to 'NewOne' I managed to get Notepad++ up and running with the bridge link to Sketchup.
            Modified the Box.rb example as a simple test. Works nice.
            I ran a search for SketchUp Ruby Debugger on this forum.
            Found something by 'Pecan' but the page will not display.
            It says I do not have the rights to view the page. ???
            In any case I have a couple of beginner questions about box.rb script.
            I notice that the require 'Sketchup.rb' uses single quotes while other references to literal strings use double quotes.
            What is the distinction between the two?
            • GaieusG
              Sorry but Pecan got pissed off by the ads and pulled off his script. His choice.
                You should not require 'Sketchup.rb' but instead require 'sketchup.rb'. Note the lower case s. If you do the former you will add another "Ruby Console" menu item under the Window menu.
                " vs '
                Double quotes can contain variables: "Hello #{variablename} World" while in single you can't do that.
                Like PHP (which has similar difference between single and double quoted strings), in webdesign it's best to stick with single quotes as they require less processing. But that's because there's so much string processing in website programming. In SU scripting - which has usually very little string processing you will most likely not notice any difference.
                Since I come from an webdesign background - being used to PHP - I use single quotes unless I need the special features of double. Force of habit.
                • G
                  Gruff
                  Case sensitive? Ouch. I can see that giving me major heart burn.
                  Does Sketchup have something similar to Excel's Record Macro?
                  Such that I might dump the steps by which something was constructed?
                    remus
                    Unfortunately not. Its fairly simple to write ruby scripts to do a list of operations to each object in a selection, though.
                    e.g. http://www.sketchucation.com/beginning-ruby-2-writing-a-script/
                      i know this is completely useless info, but there was a book i read online about ruby programming that was both hilarious and very easy to understand. From what i remember it concerned 2 little animals( i think ) and lots of strange analogies?
                      Can anyone think of the name? it's wrecking my head 😠
                      • N
                        NatBridge
                        "_why's poignant guide to Ruby"
                          Jim
                          I do not think it was ever hosted here. He always had it at google code. It's too bad he felt he had to leave, but his work is may be useful to some people:
                          Error 404 (Not Found)!!1
                          (code.google.com)
                          • G
                            Gruff
                            Read Chris Pines Tutorial and put this cheat sheet together for myself.
                            ==== Ruby for VB Programmers ====
                            --- Variables ---
                            All variables are variant objects.
                            Variables do not have to be declared before use.
                            Variables are not formally declared. (No Dim statement).
                            As variants they may be re-assigned any data type at any time.
                            Variables that are assigned strings or numbers have methods. (As in VB.NET).
                            Variables that are spelled the same but with different letter case ARE BY DEFINITION different variables.
                            Variables must be assigned names beginning with a lower case letter
                            Ruby --- VB
                            Nil ---- Nothing
                            --- Conversion methods ---
                            to_i = String to integer
                            to_f = String to float
                            to_s = Integer or float to string, Concantinates elements when used with string arrays.
                            --- Strings Manipulation ---
                            Literal Strings are denoted by single quote ( ' )
                            Backslash is an escape character: ' results in single quote. (\=)
                            Double quoted text is a more flexible form of string defintion. (Inserting and formating)
                            Ruby --- VB
                            • ------ & ------------------------ Concantination
                            • ------ Str(<string>, <count>) --- Repeat Char/String
                            ------ ' ------------------------ Comments
                            --- Operators and Comparison Operators ---
                            Ruby --- VB
                            ** ----- ^ ----- Exponent
                            % ------ Mod ----- Modulus
                            == ----- = ------ (Comparison) Equivalent
                            != ----- <> ----- (Comparison) Not Equivalent
                            --- Bracket Characters ---
                            denote an array.
                            Curly Brackets { } denote a hash
                            Parenthisis ( ) used in a formula or logical statement work as they should but are optional for methods
                            --- Hashes / Dictionary ---
                            Define as you would an array but with curly brackets and a key.
                            myList = {}; myList{'Bob Mitchell'} = '54823-11'; myList{'Phil Brown'} = '23872-08'; #Etc...
                            --- Arrays ---
                            Arrays are denoted by square brackets rather than parenthisis
                            Arrays are zero based.
                            Arrays elements do not have to be all the same type.
                            Arrays as objects also have methods. (Push, Pop,Last, Length, Sort, Etc...)
                            --- Loops ---
                            Arrays have an interator method: While Loop myArray.Each do | <variable> | ... End
                            While <Statement True> puts <variable> puts <variable> end
                            --- User Methods ---
                            Last variable or Return <variable> Returns value
                            Ruby ----- VB
                            Def( ) --- Sub( ) or Function( )
                            --- Classes ---
                            Any class may be extended including Ruby's supplied classes.
                            The new method (Implied) is required for object instantiation.
                            An Initialize method may be declared inside a class.
                            The Initialize method can take user parameters. these parameters are required after the <Class>.new method.
                            Properties are defined by the use of the @prefix on variable names.
                            local variables are private to class
                            Private is a Class keyword in Ruby that defines all methods below it as internal to the class.
                            Ruby --- VB
                            Time --- Date
