    Can't place guidelines precisely in 7.1
    4 Posts 4 Posters 1.1k Views 4 Watching
      davidheim1
      Has anyone had this problem with SU 7.1? I can't place a guideline precisely by typing in a number in the Measurements box. The guideline simply stays wherever I released the mouse to do the typing. Same thing happens when I try to draw a line to a precise length. I'm using a Mac PowerBook, running OS 10.4.1.1.
      Any suggestions or advice? Or, better, a solution? I've tried reinstalling 7.1 twice. No change.
      Thanks,
      davidheim1
      • T
        tim
        I'm on an iMac 2.4/4850gpu and have no problem with mixing guides and precise dimensions.
        • honoluludesktopH
          honoluludesktop
          David, Were you able to place guide lines prior to 7.1? If not, can you make a simple box, and then write what you do, step by step in order to place a guide line?
          • SketchUp Guide TommyS
            Hi David,
            It sounds like you're running into this issue:
            http://sketchup.google.com/support/bin/answer.py?hl=en&answer=162724
            In SketchUp 7.1, there's a known issue where SketchUp will ignore input to the Measurements box when you click or tab into the box prior to typing.
            Cheers!
            Regards,
            SGT
