    How do you detect a Polygon?
    31 Posts 7 Posters 2.6k Views 7 Watching
      @tig said:
      If the ArcCurve Curve's Vertices are not looped
      I check the radius of the ArcCurve to work out if it's a Circle/Polygon. Less entity iteration that way.
      def self.is_circle?(ent)
      	# (i) A bug in SU makes extruded circles into Arcs with .end_angle of 720 degrees when reopening the file.
      	# Instead of checking for 360 degrees exactly, we check for anything larger as well. A 2D arc
      	# can't have more than 360 degrees.
      	return false unless ent.kind_of?(Sketchup;;Edge) && ent.curve && ent.curve.kind_of?(Sketchup;;ArcCurve)
      	arc_curve = ent.curve
      	# This doesn't work. Maybe due to rounding errors?
      	#return (arc_curve.end_angle - arc_curve.start_angle >= 360.degrees) ? true ; false
      	return ((arc_curve.end_angle - arc_curve.start_angle).radians >= 360) ? true ; false
      @tig said:
      So how does SUp know the difference between a Circle/Arc and a Polygon
      SU must have more info internally which isn't hooked up to the Ruby. 😞
      @remus said:
      Sorry, i forgot to add that it should also be a curve/arccurve. Beyond that the distinction is pretty arbitrary anyway because of the segmented nature of circles in SU.
      Polygons comes out as an ArcCurve - so still no go.
      Ingenuous suggestion πŸ’š
      You can't read the "Entity info" by ruby? πŸ˜‰
      Nope. 😞
        That was the only method I could think of as well. But for what I want to use it for (my Selection Toys plugins - that can potentially evaluate millions of entities in some models) it would be too slow. 😞
        I guess an evaluation that doesn't require to test-push-pull the polygon/circle is something to ask for in a feature request?
        I tried to have a quick look at the private methods - hoping to find something locked up there. Might try to have another look.
        Crosswords puzzles are boring. SU Ruby challenges are much more fun! πŸ˜„
          I had hopes for .typename to work - but alas. 😞
          • TIGT Online
            You would parse down the entities quite quickly ?
            all_entities ==1000000
            all_edges ==500000
            edge.curve ==50000
            is ArCurve ==25000
            ArcCurve.is_loop? ==10000
            that ArcCurve.is_polygon? ==1000
            BUT, it would be MUCH easier if we had access to the internal methods that SUP has to return Polygon etc in the Entity Info Panel !!!
            • TIGT Online
              Lateral solution [at last !!!]... πŸ€“
              which we can now write into three new methods - ArcCurve.is_loop? [returns true if it's a Circle OR a Polygon; false if it's an Arc] and also ArcCurve.is_polygon? [true if it's a Polygon and false if it's a Circle or an Arc], or ArcCurve.is_circle? [true if it's a Circle and false if it's a Polygon or an Arc[/ruby] ...
              EDIT: added all 'three' methods...
              class Sketchup;;ArcCurve
                def is_loop?()### circle OR polygon
                  self.edges.each{|e|
                    e.vertices.each{|v|
                      if not v.edges[1]
                        return false ### it's an arc
                        break
                      end#if
                  return true
                end#if
                def is_polygon?()
                  self.edges.each{|e|
                    e.vertices.each{|v|
                      if not v.edges[1]
                        break
                      end#if
                  ### if we get here it might be a polygon !!!
                  model=Sketchup.active_model
                  entities=model.active_entities
                  edge=self.edges[0]
                  all_connected=edge.all_connected
                  tgroup=entities.add_group(all_connected)
                  es=edge.start.position
                  ee=edge.end.position
                  group=tgroup.copy
                  tgroup.explode
                  gents=group.entities
                  gedges=[]
                  gents.each{|e|gedges<<e if e.class==Sketchup;;Edge}
                  gedge=nil
                  gedges.each{|e|
                    e.smooth=false
                    e.soft=false
                    gedge=e if (e.start.position==es and e.end.position==ee)or(e.start.position==ee and e.end.position==es)}
                  ### remove all faces so only face and pushpull's remain
                  gents.each{|e|e.erase! if e.class==Sketchup;;Face}
                  gedge.find_faces
                  face=nil
                  gents.each{|e|face=e if e.class==Sketchup;;Face}
                  return false if not face
                  face.pushpull(1.0)
                  edges=[]
                  gents.each{|e|edges<<e if e.class==Sketchup;;Edge}
                  edges.each{|e|
                    if e.smooth? and e.soft?
                      group.erase! if group.valid?
                      return false ### a circle
                    end#if
                  return true ### a polygon
                end#def
                def is_circle?()
                  self.edges.each{|e|
                    e.vertices.each{|v|
                      if not v.edges[1]
                        break
                      end#if
                  edge=self.edges[0]
                  group=tgroup.copy
                  tgroup.explode
                  gedges=[]
                  gedge=nil
                  gedges.each{|e|
                    e.smooth=false
                    e.soft=false
                  gedge.find_faces
                  face=nil
                  face.pushpull(1.0)
                  edges=[]
                  edges.each{|e|
                      return true ### a circle
                    end#if
                  return false ### a polygon
                end#def
              end#class
              πŸ’­
                Jim
                Can't just check if 2 adjacent edges are soft? Circles are, polys are not, right?
                Guess not.
                  Guess not.
                  You'd think so, so did I and TIG, but that's not the case. πŸ˜•
                    @thomthom said:
                    Guess not.
                    Thinking of it - it makes sense that they don't as that would render extruded circles invisible.
                    • TIGT Online
                      The Edges in a Curve that's an ArcCurve, that's either a Circle and a Polygon, are identical [neither are smooth nor soft] !!! It's only when you Extrude them in 3D the difference is visually [and Ruby-test-ably] apparent. There is [seems to be?] no Ruby-accessible Method to see if a looped ArcCurve is a Circle or a Polygon... UNLESS you do my elaborate lateral and clunky test by extruding it and testing the extrusion's edges for smooth/soft? ...
                        Another oddity. Select an extruded circle. From the console: sel[0].soft=true If you click on the circle where one of the edges now are soft - the circle is now selected as well as the faces connected to it.
                        • TIGT Online
                          @thomthom said:
                          @thomthom said:
                          Guess not.
                          Smooth/soft edges that are profiles stay visible...
                            Jim
                            Right, it's the connecting edges of an extrusion that are softened, not the perimeter of the polygon/circle.
                              Only the edges that forms the outline of the geometry from the current view.
                              Look at it from an angle where it doesn't take part of the outline and it's hidden.
                              • TIGT Online
                                When you Smooth/Soften the Polygon's Edge its Face merges with the already Smoothed/Softened side Faces in the extrusion to give a single 'Surface' - as reported in the Entity Info Box. This 'Surface' Selects and Highlights as one thing... unless Hidden Geometry is 'on', then the separate Faces that make up that 'Surface' are individually Selectable/Highlighted. Presumably the [assumed] Face::is_surface? method that Entity Info uses, simply looks to see if some of the Face's Edges are Smooth/Soft and have extra Faces attached ?
                                  I added a feature request on this topic.
                                  • snicoloS Offline
                                    snicolo
                                    Ok,
                                    a quick and dirty way is to use
                                    Sketchup.active_model.selection.count
                                    if it returns 24 (default segments' number in a circle) it is a circle
                                    if it returns anything else it is a polygon
                                    This way does not work if you have 24 segments polygons or if you have changed the circle default segments number.
                                    I am still trying to figure out a better way. πŸ˜‰
                                    Simone Nicolo
                                    QA Manager
                                    http://www.sketchup.com
                                      Circles can be converted to Polygons - so that won't do either. Detecting circle is easy - checking the start and end angle if it's 360degrees or more. (SU weirdness - circles some times comes out with an total angle of 720 degrees...)
                                      Personally I often change the default segment count. And I also get lots of circles from DWGs.
                                      • TIGT Online
                                        My new method ArcCurve.is_loop? tells you if it's an open ended Arc, or looped as a Polygon or Circle, ==no_loose_ends.
                                        The other methods ArcCurve.is_circle? and ArcCurve.is_polygon? return true if it is...
                                        A clunky fix but it works...
                                          FYI: the Google response to this:
                                          Hi Thomas,
                                          I’ve traced this through the code, and I’m sad to report that there is nothing exposed in the API that allows you to (quickly) tell the difference between circles and polys. Internally, we store a flag so that says which tool created the curve object. I’ve logged a feature request to expose this in the API.
                                          Until then, the only thing I can suggest is to make a hidden copy of the curve, extrude it, then see if the edges of the resulting faces are smooth. I haven’t tried this yet to see if it works successfully though.
                                          Matt
                                            FYI: since SU 7.1M1 you can detect polygons using Curve.is_polygon?
                                            TIG: that code snippet of yours will now conflict with the new API method.
