    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 50.0k Views 44 Watching
      kwistenbiebel
      Hi Al,
      Just wanted to get back on the 2D/3D subject.
      As I understand, the treegenerator is actually 3D based by default right?
      So what about the option to have the full 3D tree as output?
      Would be great for us render headz. 👍
      cheers,
      Kwistenbiebel
        ScottPara
        I second (or third) the 3D request.
        Scott
        Love the fact that some HATE my avatar.....
          Third! (fourth?) 😎
          • Al HartA Offline
            Al Hart
            Al,
            As earthmover stated we (vray users) will still need to generate a alpha/clipmap for these to work. I am not sure how much trouble it would be for the program to export out the associated clipmap at export but it would be a huge time saver.
            Thanks again,
            Scott
            Send me, or upload, a .SKP file or .PNG of a RpTreeMaker tree and a alpha/clipmap of the same tree so I will know what it is you need. Is the clipmap stored in SketchUp anywhere, or separately?
            We store all the old .PNG files in the RPS_TreeMaker_Images sub-folder of your temporary folder. If we can easily make a clipmap we could store it there as well.
            Al Hart
            IRender nXt from Render Plus
            • Al HartA Offline
              Al Hart
              Got it working. It's a pretty neat tool. Can you change color? If so, how? This would be very important.
              Thanks,
              Huck
              To change color, you can take the raster images for the leaves or bark, change the color, and save them with a new name.
              These are stored in:
              C:\Program Files\Render Plus Systems\RpTreeMaker\Support\Plants
              in a Bark and a Leaves sub-folder.
              Here I took the standard leaf, made it yellow, saved it as a new leaf, and used it to render the tree.
              You can create your won bark and leaf images by altering the color of existing images.
              You will need a paint program which respects the Alpha Channel.
              (I don't have one, but there is a tool in RpTools which will convert the background color of an image to an alpha channel which I used.)
              Al Hart
              • Alan FraserA Offline
                Alan Fraser
                There are methods of obtaining a clipmap from a png using any decent image editor. What you effectively end up with is an alpha-channel image. That is a separate image of the tree, exactly the same size as the png, in which every transparent pixel is represented as black and every opaque one as white.
                I'm assuming Rick has already worked this out in his image profile ruby in order to generate the path of the vector outlines....but that'll be the encrypted or server-side bit. 😉
                3D Figures
                • Al HartA Offline
                  Al Hart
                  Scott
                  I will try this out (creating full 3D plants) and see if it works and or is practical.
                  However, this may effect the "Free" aspect of RpTreeMaker. I will have to discuss this with the developer, since he includes this product as a tool in his own rendering package (nXt) - which is not free.
                  Al Hart
                  • Al HartA Offline
                    Al Hart
                    That will be easy to do - to create a second PNG image.
                    The RpTreeMaker images are not all-on / all-off transparent. the edge pixels are partially transparent.
                    See how the horizon is partially visible through the pixels at the edge of the leaf. This helps make the tree blend in better at the edges.
                    I presume a clipmap uses gray pixels to represent partial transparency?
                    Also, is there a naming convention which would make these easier for V-ray users to use?
                    Al Hart
                      Alan Fraser
                      I'd imagine that there would need to be a degree of feathering around the outline, Al. A pixelated all-or-nothing outline would be just plain nasty.
                      3D Figures
                      • Al HartA Offline
                        Al Hart
                        The sample clipmap Scott sent me does indeed have feathering around the edges:
                        Al Hart
                        • DanielD Offline
                          Daniel
                          Al, thanks for the fantastic plug-in; you've solved the problem of cloned tree/shrub components.
                          While playing around with it, I noticed it makes the insertion point at the center of the component. This means if you have a lopsided or leaning tree, it's not at the trunk; when orbiting the model, the trunk's location will change. Any chance the program can be modified so that the insertion point is always on the base of the trunk?
                          My avatar is an anachronism.
                            mirjman
                            I might be missing something here, but is there a slider to adjust the taper for the actual trunk object? I am thinking of the giant redwoods or ponderosas out in California- they are hundreds of feet tall and don't have the cute "flare" at the base of the trunk that I can't seem to get rid of.
                            • Al HartA Offline
                              Al Hart
                              We're going to do two things.
                              1. Clip the roots at the ground - right now we make an image which includes roots below the ground. That is useful sometimes, but much too confusing.
                              2. Create the image (and component) so that the center of the bottom of the trunk is at the center of the image (and component)
                              Al Hart
                                Stu
                                Go to 'Trunk'...and use the 'spread' slider
                                A 3D version sounds attractive but if you look at the way this app can produce leaves [or in 3D, polygons] I would guess that you could come up with 50 and 60 Mb trees [if you could get that far without SU crashing 😄]
                                http://www.landesign.com.au
                                • david_hD Offline
                                  david_h
                                  Okay. . .So I am playing with this, and Have created a Dang Ugly tree if I say so myself. When I did Render 1, I didn't see it at all, but then exploded it and it showed up--But as you can see--rectangular shadows.
                                  Any quick tuts on a remedy? I have read thru most of this stuff, and I am a bit confused. (Nothing new there, hehe, but still . . .)RPTRee Test Image.jpg
                                    Stu
                                    Dave...youve got me confused now.....how did you explode the tree without seeing it? 😕
                                    But anyway, there is no point in exploding the tree unless you are using it in a renderer like Podium [in which case the square shadow turns into a realistic shadow after rendering]
                                    At the moment, the trees dont cast shadows in SU....unless exploded....and by doing that you also loose the 'face me' capability.
                                    Oh, and Id loose the roots....looks a bit like one of those plastic Xmas trees 😄
                                      mirjman
                                      the spread control still results in a trunk that smoothly tapers from the base, which is fairly unrealistic for trees like pines which begin to taper farther up from the ground.
                                      I am also experiencing some double grouping with the created components where they have a group inside the component- not sure if this is desirable behavior
                                      Also thought I should mention here, this plugin works hand in hand with "component spray" ruby to create fast environments: rendered in podium
                                        Stu
                                        Mirjman, that sprayed image looks great!
                                        I dont know a lot about DCs but given that its really easy to produce leaf variations on one tree....would it be possible to make a DC that could display the whole range of seasons?
                                          Alan Fraser
                                          Yes Stu, You can also have different growth stages too. You can do this by having any number of variants occupying the same space and use the DC attributes to specify which one is visible. The file itself would be quite large, but the performance would only be the same as if the visible form was the sole element. I haven't tested how multi-part DCs export to Kerky etc. but when exported to another format, only the visible element gets exported.
                                          3D Figures
                                          • Chris FullmerC Offline
                                            Yeah Stu, that would be pretty easy. You could create all 4 seasons and then combine them in a DC. Then you could have a pull down option as to what season to display. You could also creat a series of heights for each season, then make a menu that would let you choose what age to show during what season. All of this is also do-able by some tricky layer management too though if you don't want to dig into DC's
                                            Alan beat me to it
                                            • 4 / 8
