    Install 7.0 and 7.1 side by side.
    23 Posts 12 Posters 4.4k Views 12 Watching
    • Chris FullmerC Offline
      By default, if you install 7.1, it will overwrite 7.0 (it leaves all your plugins and styles, etc intact, it only overwrites the program files). But it is possible to install 7.1 and leave 7.0 installed too, for people who want to use both versions, or see if 7.1 is worth upgrading).
      A word of warning, this does mess up your shortcuts and icons, big time! But I tihnk its all fixable.
      Before installing 7.1, copy your entire 7.0 directory into a new directory. Then run the 7. installation file, and have it install on top of the original 7.0 folder. Then your current working SU version will be 7.1, and you will have a backup working copy of 7.0 in your copied folder. It will still run, but's icons get messed up and it loses its shortcuts and preferences. But at least you can stilll have 7.0 and 7.1 installed simultaneously.
      PS: I can take no credit for working out this method.
        Aerilius
        For me, SU7 and SU7.1 use the same registry keys. That means you have always the same settings and preferences in both applications
          That is interesting, I had thought something like that would occur, but it did not work like that for me. Maybe I did it wrong πŸ˜„
            hm... What OS are you both using?
              I did it on XP. But I have not really spent much time back in 7.0 honestly. πŸ˜„
                geomp
                I really want to do this too, anybody tried on OS X Leopard?
                Ta
                • W Offline
                  watkins
                  Dear Chris,
                  If one has Version 7.0 installed with the .dwg and dxf importers, what happens to those importers if one installs Version 7.1 over the top of 7.0. Are those importers deleted from the free version?
                  Regards,
                  Bob
                  • FrederikF Offline
                    Frederik
                    While Chris is out for a moment, allow me to answer...
                    Yes - you will loose these in ver. 7.1...
                    That's why some might find it handy to have v. 7.0 and 7.1 installed side by side... πŸ˜‰
                    But for a limited time, you can get the DFX/DWG import plug-in for v. 7.1...
                    You can find it here... πŸ˜‰
                    Cheers
                    Kim Frederik
                      And though you already have the link to that importer, Bob, in the other topic, the answer to your question is - no, if you use Chris' "trick" above (and can run both SU 7.0 and 7.1 together), your importers in SU 7.0 will remain untouched.
                      • W Offline
                        watkins
                        Thanks everyone!
                        • W Offline
                          wmanning
                          @geomp said:
                          Ta
                          Yes, I did it on Leopard and it works. Open the finder, then go to Applications / Google SketchUp 7 and there you can right click on it and select "Copy "Google SketchUp 7." It will use the same plug-in folders and other resources found at Mac HD / Library / Application Support / Google SketchUp 7, but because the application folders changed you can go back there and run 7.0
                            Jackson
                            Anyone know how to install SU 7.0 over SU 7.1, i.e. a reverse update? I want to avoid actually uninstalling SU 7.1 first as it may screw up links and paths in the V-Ray for SU plugin. Is the only way to uninstall SU 7.1. and the reinstall SU 7.0?
                            I ask as SU 7.1.4871 doesn't work properly with V-Ray for SU- it's very buggy.
                            Jackson
                              You can do the same - just the other way round - as described in the first post I guess. Just move your current SU 7.1 install in another directory and install SU 7.0 (no guarantee though - but this "trick" was not only provided as an exceptionalway for this during the tests).
                                Jackson
                                Thanks Csaba, but unfortunately that doesn't work- SU's installer detects that a newer version is already installed. I daren't try editing registry keys as I still have SU6 installed and God knows what gremlins will plague my machine if I have 3 versions of SU installed and a manually-edited registry! πŸ˜•
                                I guess I just have to uninstall SU7.1, reinstall SU7.0 and pray that it doesn't mess up my existing skp/V-Ray files.
                                Jackson
                                  Jackson
                                  I just finished reinstalling SU7.0- turned out to be much harder than I was led to expect as simply uninstalling SU7.1 and installing SU7.0 screwed up the registry so SU7.0 wouldn't run. When I finally got it installed and running, V-Ray for SU wouldn't load.
                                  3 hours later I finally got it to work thus:
                                  **1 ) Copy the "Google 7" folder (which contains the SU 7.1 files) from "Program Files" to "My Documents" as a backup.
                                  2 ) Uninstall SU7.1 using CCleaner.
                                  3 ) Run CCleaner's registry tool.
                                  4 ) Run Registry Mechanic.
                                  5 ) Manually delete the "Google 7" folder from "Program Files". Not deleting this is what screwed up the install the first two times.
                                  6 ) Run CCleaner's registry tool again.
                                  7 ) Run Registry Mechanic again.
                                  8 ) Reboot.
                                  9 ) Install SU7.0.
                                  10 ) Reboot.
                                  1. Copy backed-up SU 7.1 files (Components, Materials, Plugins, Styles) from their folder in My Docs into the newly installed "Google 7" folder in "Program Files".
                                  12 ) Reinstall/Repair V-Ray for SU (it didn't load the first time).
                                  13 ) Reboot.
                                  SU and V-Ray for SU appear to be working ok now, although I haven't run the test skp/VfSU file which was crashing this morning yet. Tests will continue tomorrow.**
                                  Of course I can't say for sure that it was SU 7.1 which was causing these problems, but it's a huge coincidence that I've never seen SU crash to desktop before. That, combined with SU7.1 freezing when orbiting is enough to rule out using it for day to day work until the cause is tracked down.
                                  Jackson
                                  • I Offline
                                    Insitebuilders
                                    So, I keep getting Orbit crashes as well as hitting other "bugs" and now I find the new version will not load some of our larger files (150mb +). That and other probs mean we've also voted to bail out of 7.1 and return to 7.0 (7.0 download date 4/13/09). Never again...tho I've said that b4.
                                    Is the Jackson-Method easier to do if I'm not using V-Ray and only want to save the plain old shortcuts and settings...? Components are already in separate HD files.
                                    IOW, can I just save the Goog 7 folder, do the uninstall for 7.1, and reinstall 7.0
                                    OR
                                    do we need this registry tools CCleaner and Registry Mechanic (which sounds tricky...) to do a simpler uninstall and reinstall?
                                    Any one try a simple switch back? Do you thk there'll be other issues?... 😞
                                    Thx for any advice.
                                    /Dennis
                                    insitebuilders.us
                                      Hi Dennis,
                                      Indeed, the current V-ray for SU plugin has something to do with the buggy behaviopur of SU 7.1 but good news that the GSU Team seems to be aware of the issue and working on it (maybe even together with V-Ray?).
                                      • I Offline
                                        Insitebuilders
                                        @insitebuilders said:
                                        ...V-ray for SU plugin has something to do with the buggy behaviopur of SU 7.1
                                        Thanks Gaieus (tough name for me to spell πŸ˜‰ )
                                        So I guess that means it's OK to just give the reinstall a try w/o all the techie stuff Jackson was listing...? I'll give it a try tomorrow -- what the heck.
                                        Pls let us know when you know the bugs are gone....
                                        Thx again
                                        /D
                                          As I heard, according to user feedback (wider than Beta testers), Google is working on some maintenance releases both for Windows and Mac. This is "normal" anyway with any new version (even if just a "dot" or "sub" release).
                                            Goggin
                                            Are files created in version 7 not backward compatible to version 6?
                                            I received a file from one of my architects and I couldn't open it. I got a message saying it's version 7 and I don't have version 7. Oddly enough, when I check for updates using the Help tab in SketchUp it tells me that I have the latest updates. I'm 99% certain I only have version 6, though, and that's what I see when I click on properties.
                                            Anyway, is there a way to read this file w/o upgrading? I'm hesitant to upgrade now because my computer always gets bogged down when I do something like that, and I'll probably be upgrading in a few months anyway. But I need to access this file now.
                                            Thanks.
