    Crazy Hard Modeling Challenges!
    11 Posts 3 Posters 1.4k Views 3 Watching
      MartinRinehart
      (No, I don't want you to do my work for me.)
      1. My File/New template is down around 7k. Can I lose many more bytes here? I don't know if this is possible.
      2. I want a tree. Trunk, big branches, smaller branches, twigs and leaves, all connected. Deciduous, with 4 season layers, please. Genuine 3D tree, please. Small cheats are OK: basswood/cottonwood have roughly triangular leaves. Triangles are OK if they look leafy. Fall colors from a sugar maple on a cottonwood is OK. My budget: 100kB. I've fiddled with this enough to think it possible. (Branches? Scale the trunk component.)
        remus
        1. 😎 6.26kb
          min start test.skp
        Just tried to minimise the amount of settings SU had to remember, so played around with styles and changed a few things in the model info dialogue.
          MartinRinehart
          Remus,
          Everything I tried fattened your model. Even very counter-intuitive stuff: Window/Preferences/Shortcuts/Reset All, for one. If this isn't the absolute minimum, it's close. I am VERY impressed.
          Anyone think they can do better?
          (The SU default template, if you delete Sang, tips the scales at 37600 bytes. That's a lot of bytes to spend for no geometry.)
            Have you checked for attribute dictionaries that might be attached to the model?
              Save template in SU7 I end up with 7.34KB.
              Save template as SU3 format - 3.74KB.
              SU7
              SU7-SU3 Format
                MartinRinehart
                Almost missed this one, ThomThom. Ah, the good old days! Save As Template balloons it back up to mid-7 KB, but maybe I can sneak it into my template directory without going through SU.
                All: no one taking up the tree challenge? I think it's possible.
                  http://mycomputergeneratedworld.blogspot.com/
                    MartinRinehart
                    Thomthom,
                    Did you actually try that tree?
                    I get very strange results. Any orbit, hand, whatever performs like the model is many, many megs in size.
                      I did check it out after I posted the link. It has many thousands component instances. It's high-poly - but small file size since it has no textures and uses lots of components.
                        MartinRinehart
                        I've got to change my challenge's terms and conditions: 100KB that actually feels like 100KB.
                          Yea - File size isn't a good scale for a "light" component. Textures alone can make a simple model be very heavy in file size - since they store the original size - not the 1024x1024 that SU actually use.
                          Max 100Kb & 1000 faces? (Maybe a couple of thousands more?) What's it's going to be used for?
