    [Req.] remove instance duplicates plugin
    10 Posts 4 Posters 1.6k Views 4 Watching
    • N Offline
      NewOne
      Hy! I need a script that removes all component instances that share same space. (I guess I'd better say component instances who have same transformations).
      I usually extract cutting lists from my furniture projects and if accidentally some parts are copied over themselves, this thing can not be identified visually, but in my cut list I will have more parts than I need.
      It would be nice to identify other types of geometry that coincide (let's say a group over a component having same shape)
      I did attached a visual example because I am not sure if it's really understandable what I mean.
      Thank you.
        hm...
        detecting overlapping bounding boxes are one thing. detecting the same shape... not so easy...
          remus
          Newone, when you say 'component instances' do you mean the components that share the same space are the same? or are they different components?
          • N Offline
            NewOne
            Components that share the same space are the same. Let's say resulted from duplicating and not moved.
            • N Offline
              NewOne
              @thomthom said:
              hm...
              Trying to use vertex number and position to match geometry shape might make this possible? (if the number of verticles is identical for both component instance and group and their positions coincide, in that case those elements are overlapping, right?) -I guess this can be used to identify free geometry overlapping a component/group in the same manner.
              • TIGT Online
                So you want a 'duplicate_check' tool so that any overlaid components are found ? Something like this ?
                ### (c) TIG 2009
                require 'sketchup.rb'
                def duplicate_check()
                  model=Sketchup.active_model
                  defns=model.definitions
                  ss=model.selection
                  ss.clear
                  dup=0
                  defns.each{|defn|
                    bbs=[]
                    defn.instances.each{|inst|
                      bb=inst.bounds;bbmax=bb.max;bbmin=bb.min
                      if bbs.include?([bbmax,bbmin])
                        ss.add(inst)
                        dup+=1
                      end#if
                      bbs<<[bbmax,bbmin]
                  puts(dup.to_s+" Duplicated Instances Highlighted...")if dup>0
                end#def
                To use: type 'duplicate_check' in the Ruby Console. If there are any duplicated then their number is shown in Console and they are highlighted - use 'delete' key or Move etc as desired...
                This only traps duplicate instances of each definition BUT could be adjusted to find all duplicated bbs of any definition instances (which'd include groups too - though it'd be very easy to have duplicate bbs for these with different geometry inside !) ? Checking for duplicated 'shape' is going to be almost impossible if there's any sort of complexity !
                • N Offline
                  NewOne
                  It only tells "nil" in console and doesn't highlight anything.
                  I had 3 component instances in model, two of them were one over the other, and the third was at a distance.
                  • TIGT Online
                    Works for me. Are the overlapping instances the same definition and are they exactly overlapped? Copy one and move it by a corner snapping back over the other - you should then get a highlighted instance when tested...
                    • N Offline
                      NewOne
                      It works now. It is possible that I did not overlapped exactly. Now I tried again moving back by exact distance. Can you add a tolerance ? +/- 0,1mm ? Bigger tolerance is easy identified by eye.
                      Thank you for the script!
                      • TIGT Online
                        An xyz tolerance is possible for bbmax and bbmin... unfortunately I don't have time right now... Can someone else do this part ??? πŸ˜„
