    [Plugin] VisMap - Layer/Scene Visibility Map
    126 Posts 15 Posters 50.3k Views 15 Watching
      markozeta
      Naming your scenes BM6.2 or MS4.8 (Which is the official name) ... will kill the program.
      Sighs
      Also another request for those with complex models is the ability to use freeze panes on the scene list and layer list.
      Thanks for the work though, your script will help us put everything into layout correctly.
      BSME - Cal Poly Pomona
      Sketchup Pipe Maniac
        MartinRinehart
        @takesh h said:
        I tried it on OSX/SU7 and it worked beautifully. ... it worked flawlessly as if it's designed for OSX!
        @edson said:
        i tried it on OSX/SU 7 but thw vismap window appears blank no matter what i do. i opened several files but the problem remained.
        Help!
        Edson, I'm adding some bullet-proofing that will, in some cases, tell you where it's failing. This may be constructive.
        Ahhhh! The sort of problem that might be solvable. Thanks.
        Freeze panes? What is a freeze pane?
        Martin
          MartinRinehart
          @malaise said:
          I just got a strange message several times on one model ( I may upload it if needed) ... The vizmap leaves blank.
          Yes, the model (ideally the subset that causes the problem) would be key to tracking this down.
            MartinRinehart
            @takesh h said:
            vismap window appears to be blank right after it's opened, resizing it or clicking on the window doesn't make the situation any better
            Working on it. Be patient. The U.S. Open is in week two, which really cuts into my free time.
            Very, very odd: your screenshot shows buttons on top, icon and title on bottom, other things reversed. As a guess your appendChild() JavaScript method is appending to the front of the list while my PC appendChild() appends to the end of the list. Hmmmm.
            • EdsonE Offline
              Edson
              please let us know when you post a modified version.
              http://www.mahfuz.arq.br
                markozeta
                Martin
                Since your a Linux man, I'll quote you the OpenOffice version instead of the excel version:
                InPics Solutions - Free computer tutorials
                In Pics Computer Tutorials (inpics.net)
                It would help a ton, but most code that you could drop into your javascript routine would try to freeze the top and side, when you want the two sides to be frozen.
                  MartinRinehart
                  There is a new version now fixing a Mac issue. The strange "backwards UI" thing should now be gone.
                  Does this have any effect on Edson's "no UI" issue? I doubt it, but you never know.
                  • EdsonE Offline
                    Edson
                    i am afraid there has been no change: still no UI.
                      MartinRinehart
                      I changed "ground_floor" and "second_floor" to "ground.floor" and "second.floor" without problem. Can you post a file? Thx.
                        markozeta
                        Martin,
                        The issue seems to be size. I could give you the model, but it's too large for these forums to post! However, as I was trying to reduce the size of the model in order to post it, when it got under 3.4 MB or so, the script worked!
                        The bug seems to be not in getting data, but in sending it back to the model. When I do that, I get a prompt asking me if I want to continue running scripts.
                        This prompt states "Error at Line 78, Char 4" of the script, and the error given was "The data area passed to a system call is too small."
                        Could this be an overflow error of some type?
                        Edit: I have 50 layers and 43 scenes, if that helps. That's a total of 2,150 check points. When deleting to fit to size, I also "purged unused", and then it worked.
                        Mark
                          MartinRinehart
                          @markozeta said:
                          Martin,
                          Thanks for your help!
                          Line 78, char 4 is the middle of a variable name. MSIE's error reporting is very near to totally worthless. It has to be SketchUp passing data to a system call, so this is a SketchUp bug. (Remember that numbers like 50, 43 and 2150 are very small numbers - though the VisMap you get probably looks huge.)
                          Today I am going to try to get good with one or the other of Ruby's alternative exception handlers and see if I can get enough information to pass back to the JavaScript so you get an error message that might be helpful.
                            MartinRinehart
                            @markozeta said:
                            [Freeze panes] would help a ton, but most code that you could drop into your javascript routine would try to freeze the top and side, when you want the two sides to be frozen.
                            OK. I'm up to speed on freeze panes. What exactly is your design?
                              MartinRinehart
                              I just ULd new Ruby and JavaScript.
                              The Ruby now traps errors in the bit of the code where I think they might happen, passes the error message on to the JavaScript. In turn, the JS uses the error message to create an error report where you were expecting the VisMap UI.
                              If my guess is right about the source of the trouble, there should be no more blank UIs.
                              • EdsonE Offline
                                Edson
                                martin,
                                there has been some improvement: the UI is no longer blank, as you can see, but it does not get any data from the model. i have 24 scenes and about 40 layers in this model. i am on mac (10.5.8/SU 7)
                                  MartinRinehart
                                  Beautiful!
                                  First, I see that your scene list is on the wrong side. I can fix that. (Edit: done.) Second, it appears that there was an issue with your scene list, as it appears to have broken before/during the scene name collection process. I'll cast a wider net for breaks and see if I can get you a genuine error message. (Edit 2: also done.)
                                  (It's rained all day. The U.S. Open is closed.)
                                  • EdsonE Offline
                                    Edson
                                    martin,
                                    i downloaded the plugin again but not only there was no improvement as we are back to the blank UI. keep trying.
                                      markozeta
                                      Aha! It is a bug with overflow.
                                      http://www.boutell.com/newfaq/misc/urllength.html states that IE can only have a URL of length 2,083 chars.
                                      Line 78 to 82 of vismap.js states...
                                      function rubyCalled( callback_name, message ) {
                                      	if ( (typeof message) == 'undefined' ) message = '';
                                      	url = 'skp;' + callback_name + '@' + message;
                                        	window.location.href = url;
                                      With my example, this would request a url from internet explorer that would contain a 2,150 character string attached to an 11 character header to form a 2,161 character url - which exceeds IE's ( 🤢 ) limits.
                                      I guess the only way I could suggest fixing this is with a conversion of binary (1 for V, 0 for I), converted to ASCII, and then back on the ruby side. Ruby will be able to unpack it though, using str.unpack in ruby, but still, this will be difficult to overcome.
                                      Not much help, sorry. 😳
                                        MartinRinehart
                                        This is not good. I wish I were in front of your computer. Hmmmm.
                                        Right now I believe the smart thing is to sleep on it.
                                        Do you know anything about Ruby or JavaScript?
                                          MartinRinehart
                                          I've done a lot with bit maps, so packing 16k bits into a 2k string is not a problem. But is 16k going to handle really large animations? Or should I find (they're there) a more capacious solution?
                                          Edit: "The data area passed to a system call is too small." Remember? That's the 2k data area that IE is trying to fit 2k+ bytes into.
                                          • EdsonE Offline
                                            Edson
                                            very little. however, i have been able to run tests for other coders when there was any problem about running scripts on mac. but i would have to be guided for that to work.
                                            • 2 / 7
