    Right click menu disabled???
    26 Posts 11 Posters 6.6k Views 11 Watching
    • EarthMoverE
      EarthMover
      Ken, at least now you know you're not the only one...unfortunately for me..I'm the other guy. LOL
      I've had Selection toys installed for a long time with no problems. Only within the past week has this started happening. I completely lost Joint Push Pull from my shortcut and right click menu around the same time. Wonder if there is a connection?
      Content Creator at Skapeup
      • P
        prismcnd
        I had a similar problem earlier this week when I downloaded a couple of plugins. After I had selected an object or group and right-clicked, the object would be deselected before the menu came up so in effect I was right-clicking with nothing selected. I traced it down to a couple of plugins by using they ruby window to identify that there was in fact an error generated. I then made a copy of my plug-ins folder on my desktop and emptied the original of all files with an ".rb" extension. On the copied folder i arranged my files by type and systematically copied large batches of files (15-20) at a time until I whittled the list down to the offending plug-ins and renamed it with an ".broke" extension. Solved the immediate issue but because i am in the middle of a number of projects I haven't had a chance to pursue it further. I believe it was a clash between two plugins. Let me know if this helps
        “Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
          Jim
          Jon, can you please take a minute to identify the offending file(s)? A number of people would very much like to have this solved.
          • P
            prismcnd
            unfortunately due to as power supply death my desktop is down and i am unable to access that file directory. i'm currently running of my laptop with an older backup of the plugins folder and no problems.
            • P
              prismcnd
              i'm not sure if it's the exact same problem cause based on the screen shots the object is still highlighted whereas with my problem, the object would de-select prior to the menu appearing
                What version of ST do you have installed? The very latest should not cause this, but the two released before that did cause it.
                • EarthMoverE
                  EarthMover
                  Thanks Thom...I just installed the newest version..I'll let you know if it helps.
                  If not, I will sort my .rb files by date of creation and go backwards through the list removing one at a time, until I find the culprit.
                    dedmin
                    I have the same problem - no Selection Toys instaled!
                    • scottliningerS
                      scottlininger
                      Hey guys,
                      Some questions for the folks who are having this problem:
                      1. What operating system are you using?
                      2. What exact version of SU are you running?
                      3. The problem is described as "right click" menus. Is it only Ruby items that are grayed out, or are all of them grayed out?
                      Hopefully we can track it down...
                      Cheers,
                      • Scott Lininger
                        SketchUp Software Engineer
                        Have you visited the Ruby API Docs?
                        Hey guys,
                        Cheers,
                        When I saw it due to my Selection Toys plugin it showed itself in SU6 and SU7 (both updated to the latest version - sorry, don't recall the exact number, but I know it was the latest). And on XP SP3 machines. It started with some menus greying out and slowing increasing in number until all menu items, including non-ruby items becoming disabled. The screenshot in one of the previous posts show this.
                        It seem to be various reasons for this issue - but the most likely method to reproduce it would be to install my Selection Toys plugin. The code that caused it is still in the latest version - just commented out.
                        Seems to be more likely to occur on larger models - with a number of layers and after a while of use. (might also occur quickly on smaller models.)
                          rv1974
                          This is it!This faded context menu is driving me mad.
                          I guess it started 2 days ago and the cause is one of those newest rubies (2 weeks maximum). The number of bugsplats also rose exponentially :
                          Tomorrow I'll try to replace the the plugins folder with
                          the older one.
                            dedmin
                            The latest plugin i have installed was center of component - before that everything were fine.
                              rv1974
                              No- I didn't have it installed. Meanwhile I deleted pnts2mesh.rb (fredo's proxies will be next 😄 )
                              • EarthMoverE
                                EarthMover
                                Installed the newest Selection Toys and still having the same problem.
                                It happens without warning...usually 5-10 minutes into a session.
                                I'm running SU7 on Vista.
                                All the right click items become disabled...not just rubies.
                                • scottliningerS
                                  scottlininger
                                  Is everyone else having this problem using Vista?
                                  • Scott Lininger
                                    We see this on our XP SP3 machines at the office.
                                      dedmin
                                      Same here - XP SP3 all updated.
                                      • P
                                        prismcnd
                                        sorry been away on a project, i'm running sp3 as well
                                        • halroachH
                                          halroach
                                          Hi EarthMover,
                                          I am unfamiliar with the different toolbars you are using and am curios what they are:
                                          1. the second column from the left - I recognize Vray and Twilight render. what are the others below them?
                                          2. the bottom most toolbars?
                                          3. 2D tools!? searched from them and couldn't fine them...
                                          I remember seeing a thread with a ruby script toolbar pictures? anyone remember something like that?
                                          Sorry I can't help with your problem 😄 good luck with that!
                                          http://forums.sketchucation.com/download/file.php?id=33044&mode=view
                                          FlexTools - Super Quick Windows, Doors, Slats...
                                          • O
                                            orei
                                            i've the same worth problem.. those are the ruby plugin script that i've installed in my plugin su folder:
                                            http://img8.imageshack.us/img8/4694/rubyscript.th.jpg
                                            plugin script
