    Randomness
    94 Posts 33 Posters 37.6k Views 33 Watching
      raduteo
      The texture was made in photoshop (obviously), however, the texture UVW mapping was made in Blender (it's free), you export your SU model as .3ds or .obj, spend 5-10 minutes creating the layout, export it from Blender and import it in SU as .3ds and the UV coords get carried through. Apart from the texture the model has applied to it a displacement map and bumpmap.
      This is one of probably three dinosaur models that will populate my paleoscene.
      Thanks.
        raduteo
        Indeed, would be great if SU would possess such a tool/plugin, I just wish I knew about it before I started projecting plane textures on the locomotive, it would of spared me 8 hours.
        Also, there be no dragons herehttp://en.wikipedia.org/wiki/Carnotaurus
          No matter what wikipedia says, these monsters are dragons to me.
          ๐Ÿ˜ฎ
            Jackson
            Raduteo,
            Thanks for explaining that workflow, I'll have to take another look at Blender if it has such good UV mapping tools.
            Is this still rendered in V-Ray for SU? If so I'm suprised the UV mapping from the imported Blender mesh renders properly in V-Ray- I was led to believe by one of the developers that distorted maps in SU couldn't be "read" properly by render plugins.
            Jackson
              raduteo
              I had no idea there was such a problem/speculation, it works fine for me. However, remember not to go over 2048x2048.
              http://img442.imageshack.us/img442/2004/55603228.jpg
                dolphus
                Call me biased but this is not as impressive as your locomotives, but i can understand wanting to change....maybe ? ๐Ÿ˜’
                  Jackson
                  V-Ray can read any size of diffuse bitmap, so there's no reason you can't load a huge bitmap into SU and although it will be downsampled to 2048 x 2048 in the SU viewport, V-Ray will render it at full resolution.
                  I'm intrigued about the UV mapping, it may only be SU's in-built UV mapping tool which doesn't work properly with render plugins.
                  However much you prefer locomotives, how you could find anything negative to say about such incredible modelling and texturing is beyond me. ๐Ÿ˜’
                  Jackson
                    raduteo
                    I have no idea, I'm probably the least experienced guy when it comes to those things, so far I'm pleased I didn't run into any problems.
                    From a modelling standpoint any organic form is much harder to do than a locomotive for example, nevermind studying theropod anatomy and all the recent papers to have in the end a correct model, I'm sorry if I failed to deliver in your eyes. I don't quite understand the last part of your sentence.
                    • david_hD Offline
                      david_h
                      I think they are all awesome. Just imagine how good you will be when you combine your gifts and start modeling Romanian theropods. ๐Ÿ’š
                      • McGyverM Offline
                        McGyver
                        Well, that did it... ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ Thank you for the inspiration!!! I'm gonna go dig out my NYC R-34 subway and have another go at it.... I guess this shows what a truly talented person can do with SU!!! Great Model!!
                        Visit My ShareCG Freebie Gallery
                        • michaliszissiouM Offline
                          michaliszissiou
                          Great work. Great modeling!
                          About this work flow, blender's UV mapping just rocks. My favorite.
                          http://forums.sketchucation.com/viewtopic.php?f=81&t=20553
                          http://forums.sketchucation.com/viewtopic.php?f=81&t=19867
                          Just a question. This is modeled in SU? Or blender, or even better zbrush+blender? Or mudbox?
                          This model came from decimation. See wire frame.
                          SU is a fine modeler for buildings but not for this kind of organic forms, doesn't have a UV editor, doesn't support huge polys (or it does after all?)
                            michaliszissiou
                            A second thought. This last model is baked in another app. And that's OK. A talented person you are. ๐Ÿ‘
                            Anyway baking is my favorite work flow.
                            http://forums.sketchucation.com/viewtopic.php?f=81&t=21549
                            http://forums.sketchucation.com/viewtopic.php?f=81&t=21352
                              raduteo
                              First one textured, it was an absolute pain, took me about 15-18 hours just to texture and I'm glad it's done. :]
                              http://img264.imageshack.us/img264/729/841340031.jpg
                              http://img264.imageshack.us/img264/6954/324237450.jpg
                              And in a more "realistic" setting, the station is from GW, as always critics/comments are always welcome, ejoy!
                              http://img264.imageshack.us/img264/1081/322746940.jpg
                                raduteo
                                Thread renamed to something more appropriate.
                                http://xadu.proqstudios.net/tempimg/722_11.jpg
                                http://xadu.proqstudios.net/tempimg/722_22.jpg
                                • olisheaO Offline
                                  olishea
                                  awesome. i dont even like this car but you make it look sweeeeeet!!
                                  oli
                                    raduteo
                                    It's probably the most tasteful looking supercar currently out.
                                    Will post a sketch of this car as soon as I scan it.
                                    • david_hD Offline
                                      david_h
                                      (Buzzer Sounds)
                                      Okay . .. I am going to have to ask from a ruling from our panel of judges. That has to be a photo of the real car.. . . ๐Ÿ’š
                                        michaliszissiou
                                        Glorious! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                        • MarianM Offline
                                          Marian
                                          WOW ๐Ÿ˜ฎ ๐Ÿ˜ฒ , are you sure that's a sketchup model??
                                          It looks AMAZING!!!!!!!
                                            sepo
                                            This is amazing modeling and very fine rendering man.
                                            • 4 / 5
