    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 31.3k Views 12 Watching
      phy
      Sketchyphysics isn't recognizing @@pos2 for some reason. To see for yourself open ruby console hit the play button.
      Tableau de comparaison de Staxyn s'agit d'un mΠ“Β©dicament uniquement sur ordonnance.
      • W Offline
        Wacov
        Thanks Phy! Since you pinpointed it, I found the problem. Seems it was trying to use @@pos2 before it had been created, I just had to add it into onstart and it worked fine!
        • W Offline
          Wacov
          Okay, playing around with vectors (another toe in the API pond). Basically, I'm finding them, then changing their length with joystick inputs. I then use them to control the velocity of an object; in this case, the player in an FPS system; this works pretty sweet, so I'll continue to add features, and see where it takes me!
          EDIT: Fixed. Tell me if it's not πŸ˜‰
          FPS Rig1.0.skp
            Physicsguy1
            there is an Error. double-clicking wont kick the object.
              CPhillips
              I removed double click = kick because it was seldom used and interfering with the new events.
                CPhillips
                Here is another useful script. It allows scripts to print text to the screen. In this case a log of whatever touches the floor.
                   #add blank text to screen at 10,50
                @@log=SketchyPhysics;;addWatermarkText(10,50,"")
                   #place to store lines
                @@lines=[]
                ontouch{|t,s,p|
                      #add new line
                   @@lines.push(t.name+" touched "+self.name)
                      #ensure only 5 lines on screen at once.
                   @@lines.shift if @@lines.length>5
                      #display lines
                   @@log.text=@@lines.join("\n")
                onend{
                   @@log.erase!
                   @@lines=nil
                logging.skp
                  JaViXP
                  Very nice script! πŸ‘
                  Can we upload with this version if we don't use the new features? πŸ˜‰
                  "Giving up is way harder than trying"
                  JaViXP's Rendering
                    Physicsguy1
                    Never really got back to this one: Are we going to be able to set an object's scripting from an external source code?(ie setting an emitted object to explode on impact.)
                      JaViXP
                      Nice question, what do you want it for? πŸ˜‰
                      Something like this should work (this one doesn't work, just play around with it):
                      ontouch{|toucher,speed,pos|
                         if(toucher.name=="box"){
                            split(self,1)
                      Hope this helps! πŸ˜„
                      JaViXP's Rendering
                      • W Offline
                        Wacov
                        Any SU ruby would work, ao you might be able to load an external .rb file as an ontick func, or whatever. But you don't need that to do what you're asking, as Jav has shown; and anything that SU can detect can be acted upon.
                          CPhillips
                          Hi everyone. Sorry I have been quiet lately. Been taking some time off and enjoying the summer.
                          I think it is possible to set events externally with this version. I know the the syntax is a bit weird and I plan to clean it up.
                          Create a good sized cone and put this in its scripted field.
                          b=copy
                          b._setEvent("ontick",
                          <<CODE
                             push([0,0,1])#go forward
                             if(frame>50)
                                destroy #die after 50.
                          CODE
                          The cone will copy itself and then set the "ontick" event in the copy.
                          I tried to make an example that uses "ontouch" but it didnt work for some reason. I will have to debug it.
                          • N Offline
                            NorviewsVeteran
                            Sorry I don't have much to add, but there are a few things. I'm no programmer, I'm on the mechanical team.
                            1. You guys are blowing my mind. Wacov, when I opened your cloth file my jaw dropped for so long I almost drooled on my cat.
                            1. I needed an excuse to upload the Gopher.
                            Gopher Armored Car.skp
                            //This_Is_All(I)+=Know()About.Code;
                              CPhillips
                              Nice model!
                              • N Offline
                                NorviewsVeteran
                                Thank you, have another.
                                I figured out the scripted joints (big for me) to the point where I used universal joints for the bogies and you can copy more cars to the train, but the problem is I had to daisychain the joints under the cars so much the sag makes the cars lean in turns. Just beware of derails, they seem to be quite frequent...
                                If anyone can figure out a way around this, that would be great.
                                train.skp
                                • W Offline
                                  Wacov
                                  b=copy
                                  > <<CODE
                                  >    if(frame>50)
                                  >    end
                                  > CODE
                                  It totally crashes my SU when I try it in ontouch, and freezes the sim in ontick... also, I can't drag the original object. It highlights, and the drag line appears, but no movement πŸ˜•
                                    Physicsguy1
                                    Err... looks like you didn't try it in the right field.
                                    • W Offline
                                      Wacov
                                      I mean ontick/touch as in:
                                      ontick{
                                      Try it, see what you get.
                                        CPhillips
                                        I am not 100% sure that works in this version. It may depend on some unreleased code. Can anyone confirm it works?
                                          Physicsguy1
                                          It works for me.
                                            JaViXP
                                            Same for me.
                                            JaViXP's Rendering
                                            • 4 / 5
