    Styles combination
    7 Posts 3 Posters 714 Views 3 Watching
    • P
      Peter Covnik
      Is here posibility combite 2 different styles in the same floorplan?
        What 2 styles? What is it you want to combine? If you want to use a line style from one Style and a watermark from another, you can use the Mix option in the Styles dialog.
        In some cases you might find that two exported images with different styles applied can be successfully combined in an image editor.
        • P
          Peter Covnik
          I want use two diferent line styles in the same scene its mean i want draw wall with continuous linestyle and stair draw with dash dot line style.
            I see. You can't combine line styles in SketchUp but you could create two scenes; one with the stairs invisible and a continuous line style applied to the wall. The stairs would be on a separate layer from the wall. The second scene would reverse the visibility with the Dash Dot style applied. Then you could export and combine the two to get what you want.
            Or, you could use the dashed line plugin to make the edges of the stairs dashed lines.
            • G
              Gjenio
              Don't know if you have the Pro Version. In that case the solution is here in combination with Layout
                Ah, yes. Of course Layout would make it easy to do as well.
                Good suggestion.
                • P
                  Peter Covnik
                  THX for yours help
