    .quick house. updated**
    16 Posts 10 Posters 2.4k Views 10 Watching
      mike d
      Jason
      that look amazing. just as your stuff always looks
      The grass is always GREENER on the roof.
        d12dozr
        Shoot, I think that looks great! Is this all SU, or some PP? Great technique, too. πŸ‘
        http://goo.gl/f7ooYh
        • spenceS Offline
          spence
          I find myself saying the same thing about your work every time I see it, it's fantastic! You really blew through this one and it looks great. I hope your client thinks you worked on it all night long.
          Spence
          • marked001M Offline
            marked001
            appreciate the comments again, guys!
            again, nothing special here.... Rob, i cant recall where i originally got the stone texture, but I just added a watercolor filter in pshop...maybe some grain, i forget....and adjusted the RGB in sketchup to get the right 'lightness'...these are direct from sketchup... always have to do that with these guys because they ask for a million changes at the last minute, and there's no time to take everything into pshop...
            http://www.revision21vis.com
            instagram: revi21on
              Rob D
              Hi Jason
              I just had a quick go at your method using SU's own textures. Is this how you did it?
              With SketchUp's own textures
              And after the adjustments you mentioned:
              After ajust texture in GIMP
                marked001
                pretty much... but really, for the most part you can adjust the texture 'in' sketchup... just edit the texture and go to RGB and make it anywhere from 50, 50, 50 to 255, 255, 255 depending on how light or dark you want it. this will remove the color + lighten or darken it. much easier than using an external editor....the only reason i used one on that stone, was because it was a little 'too' detailed for the image..
                instagram: revi21on
                  Rob D
                  I see what you mean. Thanks for the tip!
                  desaturated within SketchUp
                    marked001
                    ok..this project moved along... not that i had much more time to work on it..
                    building off the existing model i had already built...i updated the addition, added the rear of the house... and did the interiors.... this is the result one long night, one all-nighter, and pretty much all day today... some compositions and people, trees, etc could be better...but i was under the gun....
                    http://img32.imageshack.us/img32/807/howarthv3082209.jpg
                    http://img24.imageshack.us/img24/3115/howarthv2082209.jpg
                    http://img38.imageshack.us/img38/2986/howarthv1082209.jpg
                    http://img26.imageshack.us/img26/5594/howarthv4082209.jpg
                    http://img15.imageshack.us/img15/3074/howarthv5082209.jpg
                    http://img20.imageshack.us/img20/7559/howarthv6082209.jpg
                    instagram: revi21on
                      marked001
                      http://img18.imageshack.us/img18/9529/howarth1stflrv1082209.jpg
                      http://img193.imageshack.us/img193/4451/howarth1stflrv2082209.jpg
                      http://img196.imageshack.us/img196/7701/howarth1stflrv3082209.jpg
                      http://img10.imageshack.us/img10/5038/howarth1stflrv5082209.jpg
                      http://img18.imageshack.us/img18/663/howarth1stflrv6082209.jpg
                      http://img17.imageshack.us/img17/4592/howarth2ndflrv7082209.jpg
                      http://img16.imageshack.us/img16/1521/howarth2ndflrv8082209.jpg
                      http://img29.imageshack.us/img29/6986/howarth2ndflrv9082209.jpg
                      instagram: revi21on
                        d12dozr
                        Great work Jason πŸ‘ ,and a pretty slick website too πŸ˜‰
