    .quick house. updated**
    16 Posts 10 Posters 2.6k Views 10 Watching
    • artysmediaA
      artysmedia
      If this is a quick house i dont imagine how good can be the slow houses πŸ’š πŸ‘
      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
      Blog: Artysmedia
        Rob D
        This is gorgeous. Just right for the type of building imo. I'd love to know how you managed the stone texture? Is it a combi of two images in photoshop?
        Regards
        Rob
        • plot-parisP
          plot-paris
          Jason, that is a great image. exactly the right amount of detail (I find myself modelling in higher detail quite often, only to discover, that it doesn't really look good - too many lines) the whole image really works.
          would you do me a favour and post an untextured image (I know, painfully honest, such an image - but really interesting)
            mike d
            Jason
            that look amazing. just as your stuff always looks
            The grass is always GREENER on the roof.
              d12dozr
              Shoot, I think that looks great! Is this all SU, or some PP? Great technique, too. πŸ‘
              http://goo.gl/f7ooYh
              • spenceS
                spence
                I find myself saying the same thing about your work every time I see it, it's fantastic! You really blew through this one and it looks great. I hope your client thinks you worked on it all night long.
                Spence
                • marked001M
                  marked001
                  appreciate the comments again, guys!
                  again, nothing special here.... Rob, i cant recall where i originally got the stone texture, but I just added a watercolor filter in pshop...maybe some grain, i forget....and adjusted the RGB in sketchup to get the right 'lightness'...these are direct from sketchup... always have to do that with these guys because they ask for a million changes at the last minute, and there's no time to take everything into pshop...
                  http://www.revision21vis.com
                  instagram: revi21on
                    Rob D
                    Hi Jason
                    I just had a quick go at your method using SU's own textures. Is this how you did it?
                    With SketchUp's own textures
                    And after the adjustments you mentioned:
                    After ajust texture in GIMP
                    • marked001M
                      marked001
                      pretty much... but really, for the most part you can adjust the texture 'in' sketchup... just edit the texture and go to RGB and make it anywhere from 50, 50, 50 to 255, 255, 255 depending on how light or dark you want it. this will remove the color + lighten or darken it. much easier than using an external editor....the only reason i used one on that stone, was because it was a little 'too' detailed for the image..
                      instagram: revi21on
                        Rob D
                        I see what you mean. Thanks for the tip!
                        desaturated within SketchUp
                        • marked001M
                          marked001
                          ok..this project moved along... not that i had much more time to work on it..
                          building off the existing model i had already built...i updated the addition, added the rear of the house... and did the interiors.... this is the result one long night, one all-nighter, and pretty much all day today... some compositions and people, trees, etc could be better...but i was under the gun....
                          http://img32.imageshack.us/img32/807/howarthv3082209.jpg
                          http://img24.imageshack.us/img24/3115/howarthv2082209.jpg
                          http://img38.imageshack.us/img38/2986/howarthv1082209.jpg
                          http://img26.imageshack.us/img26/5594/howarthv4082209.jpg
                          http://img15.imageshack.us/img15/3074/howarthv5082209.jpg
                          http://img20.imageshack.us/img20/7559/howarthv6082209.jpg
                          instagram: revi21on
                          • marked001M
                            marked001
                            http://img18.imageshack.us/img18/9529/howarth1stflrv1082209.jpg
                            http://img193.imageshack.us/img193/4451/howarth1stflrv2082209.jpg
                            http://img196.imageshack.us/img196/7701/howarth1stflrv3082209.jpg
                            http://img10.imageshack.us/img10/5038/howarth1stflrv5082209.jpg
                            http://img18.imageshack.us/img18/663/howarth1stflrv6082209.jpg
                            http://img17.imageshack.us/img17/4592/howarth2ndflrv7082209.jpg
                            http://img16.imageshack.us/img16/1521/howarth2ndflrv8082209.jpg
                            http://img29.imageshack.us/img29/6986/howarth2ndflrv9082209.jpg
                            instagram: revi21on
                              d12dozr
                              Great work Jason πŸ‘ ,and a pretty slick website too πŸ˜‰
