    .quick house. updated**
    16 Posts 10 Posters 2.6k Views 10 Watching
    • Chris FullmerC
      Great work indeed!
      In the film industry the saying is "If its out of the frame, it doesn't exist!" meaning, nothing, NOTHING gets built that is out of the camera frame. That is why the industry picked up on Sketchup - it helps them determine exactly what will be in the frame of a set, so they know exactly how far to build.
      So no Bruce, you are not alone. Its an unfortunately wise thing to do, even though for those of us who enjoy 3d models, it feels painful to leave things undone.
      • artysmediaA
        artysmedia
        If this is a quick house i dont imagine how good can be the slow houses πŸ’š πŸ‘
        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
        Blog: Artysmedia
          Rob D
          This is gorgeous. Just right for the type of building imo. I'd love to know how you managed the stone texture? Is it a combi of two images in photoshop?
          Regards
          Rob
          • plot-parisP
            plot-paris
            Jason, that is a great image. exactly the right amount of detail (I find myself modelling in higher detail quite often, only to discover, that it doesn't really look good - too many lines) the whole image really works.
            would you do me a favour and post an untextured image (I know, painfully honest, such an image - but really interesting)
              mike d
              Jason
              that look amazing. just as your stuff always looks
              The grass is always GREENER on the roof.
                d12dozr
                Shoot, I think that looks great! Is this all SU, or some PP? Great technique, too. πŸ‘
                http://goo.gl/f7ooYh
                • spenceS
                  spence
                  I find myself saying the same thing about your work every time I see it, it's fantastic! You really blew through this one and it looks great. I hope your client thinks you worked on it all night long.
                  Spence
                  • marked001M
                    marked001
                    appreciate the comments again, guys!
                    again, nothing special here.... Rob, i cant recall where i originally got the stone texture, but I just added a watercolor filter in pshop...maybe some grain, i forget....and adjusted the RGB in sketchup to get the right 'lightness'...these are direct from sketchup... always have to do that with these guys because they ask for a million changes at the last minute, and there's no time to take everything into pshop...
                    http://www.revision21vis.com
                    instagram: revi21on
                      Rob D
                      Hi Jason
                      I just had a quick go at your method using SU's own textures. Is this how you did it?
                      With SketchUp's own textures
                      And after the adjustments you mentioned:
                      After ajust texture in GIMP
                      • marked001M
                        marked001
                        pretty much... but really, for the most part you can adjust the texture 'in' sketchup... just edit the texture and go to RGB and make it anywhere from 50, 50, 50 to 255, 255, 255 depending on how light or dark you want it. this will remove the color + lighten or darken it. much easier than using an external editor....the only reason i used one on that stone, was because it was a little 'too' detailed for the image..
                        instagram: revi21on
                          Rob D
                          I see what you mean. Thanks for the tip!
                          desaturated within SketchUp
                          • marked001M
                            marked001
                            ok..this project moved along... not that i had much more time to work on it..
                            building off the existing model i had already built...i updated the addition, added the rear of the house... and did the interiors.... this is the result one long night, one all-nighter, and pretty much all day today... some compositions and people, trees, etc could be better...but i was under the gun....
                            http://img32.imageshack.us/img32/807/howarthv3082209.jpg
                            http://img24.imageshack.us/img24/3115/howarthv2082209.jpg
                            http://img38.imageshack.us/img38/2986/howarthv1082209.jpg
                            http://img26.imageshack.us/img26/5594/howarthv4082209.jpg
                            http://img15.imageshack.us/img15/3074/howarthv5082209.jpg
                            http://img20.imageshack.us/img20/7559/howarthv6082209.jpg
                            instagram: revi21on
                            • marked001M
                              marked001
                              http://img18.imageshack.us/img18/9529/howarth1stflrv1082209.jpg
                              http://img193.imageshack.us/img193/4451/howarth1stflrv2082209.jpg
                              http://img196.imageshack.us/img196/7701/howarth1stflrv3082209.jpg
                              http://img10.imageshack.us/img10/5038/howarth1stflrv5082209.jpg
                              http://img18.imageshack.us/img18/663/howarth1stflrv6082209.jpg
                              http://img17.imageshack.us/img17/4592/howarth2ndflrv7082209.jpg
                              http://img16.imageshack.us/img16/1521/howarth2ndflrv8082209.jpg
                              http://img29.imageshack.us/img29/6986/howarth2ndflrv9082209.jpg
                              instagram: revi21on
                                d12dozr
                                Great work Jason πŸ‘ ,and a pretty slick website too πŸ˜‰
