    [Plugin] Color by Slope
    52 Posts 25 Posters 63.6k Views 25 Watching
    • B
      BTM
      Nice script!
      • I
        icepam
        @chris fullmer said:
        ok aa, I checked out your version, and thats great! I want to update the rDoc info at the top to make it current. Once I do that, I'll post it up in the top post so everyone finds it easier. Thanks!
        Great! while you're at it, here's a suggestion for a quick and very useful utility: let it give a name to the created materials, you should be able to construct it from the slope segment eg if you've got 3 colors, the materials will be named "0 to 30", "31 to 60", "61 to 90".
        it would be great and trivial to have an option where instead of the number of colours you give it a angle, and it does the division... i would do it but too many cooks... πŸ˜‰
        and you're absolutely right about putting all your color face plugins into one package with a great GUI. let me know if you need help. i may not be the best ruby scripter, but am great at testing for usability.
        -aa
        • Mike LuceyM
          Mike Lucey
          Thanks Chris, I wonder what it could be used for, other than visual effects? Has anyone any ideas .... I probably end up saying Doh!
          • I
            icepam
            ok i gave that a wiz, the only way i figured how to do it is to create a materials array instead of a colors array, and assign the right one in the second step.
            it creates materials called "segment 1 [0 to 30]", "segment 2 [30 to 60] etc.
            ISSUES:
            • it works fine if other materials have already been created with a similar max_number, but renames the sets of materials by adding numbers at the end. to avoid confusion: delete previous materials and/or purge them.
            • the brackets are required, othewise the materials get renamed weirdly if they already end with a number.
            attached is an updated version, and here's the diff:
            Difference Report - 17/07/2009, 22:35
            File 1: "aa_color_by_slope-REVISED.rb"
            Last modified on 17/07/2009, 22:28
            File 2: "aa_color_by_slope.rb"
            Last modified on 17/07/2009, 22:31
            Lines added at 1
            •   materials = model.materials
            •   matarray = []
            •   	#create a material and give it the right name and color
            •   	hi =90 - i * astep
            •   	low = 90 - (i+1) * astep
            •   	seg = max_colors - i
            •   	matname =  "segment #{seg} [#{low} to #{hi}]"
            •   	#puts matname
            •   	m = materials.add matname
            •   	m.color = [r,g,b]
            •   	matarray.push m
            Lines modified at 221
            •   	a.material = colors [segment]
            •   	a.back_material = colors [segment]
            •   	a.material = matarray[segment]
            Lines added at 223
            •   	a.back_material = matarray[segment]
            EDIT: file removed, please see top post for download link
            • I
              icepam
              It is an amazing utility if you work with landscape and terrains. I'm an urban designer and architect and I use it for example to figure out which parts of a terrain are too steep to build on etc.
              geologists use slope analysis to figure out if there is any danger of landslides, and landscape designers to figure out what they can plant where.
              you can also use it to figure out if snowfall will build on certain areas and not others.
              and from a "image creation" perspective, if you combine the color by slope and the color by z, you could "automatically" create procedural maps of materials for example if you have a mountain, you can cover the highest parts with snow, the flat parts with grass, and the sheer parts with rock πŸ˜„
              • Mike LuceyM
                Mike Lucey
                Thanks Icepam for that informitive description, and yes I agree that Colour by Slope would be invaluable in these cases.
                • JClementsJ
                  JClements
                  Mike:
                  For freeform shapes, I can see where it could be used as a contrasting tool (like bumping up the contrast in your photoediting software) where SU's builtin Sun for Shading doesn't quite do the trick.
                  I am wondering if you could start with a grayscale mapping of the surface slopes, then take the grayscale value for each surface and tweek the HLS value of colors used for the surface, create a Palette of these shades, and apply them to their respective surfaces.
                  • Didier BurD
                    Didier Bur
                    I've done something similar (well, sort of) in my "paint_altitude_faces.rb" veeeeery ooooold script. Go look into it if it can help, it is not crypted πŸ˜‰
                    DB
                      mattg
                      Chris,
                      Was just wondering if you updated your version of the script with all the new inclusions? No offense intended, but im not sure how stable or whatever the other versions are.
                      Cheers.
                      -Matt
                      • olisheaO
                        olishea
                        thanks for this plugin. im a big fan of your color by z plugin too, I use it far too often!
                        oli
                        • Chris FullmerC
                          UPDATE! version 1.5 available. (But not much changed, just compiled all the scripts that had been lying around this thread, and now I've uploaded it to smustard to host).
                          @MattG, sorry it took so long to respond here! Yes, the other versions that were posted were quite stable. I've now consolidated everything into a single script and uploaded it to smustard.com:
                          @Olishea - thanks! I'm glad you like these scripts πŸ˜„ It always nice to know poeple use some of them.
                          Download
                          http://www.smustard.com/script/ColorBySlope
                          So go there now to download the final version of this script (I made one or two minor tweaks that might improve the speed, but I wouldn't count on it).
                            mattg
                            Nah no worries.
                            Thankyou so much for this and all you other scripts - you're an absolute legend!
                            • E
                              Ecuadorian
                              Thank you, Chris!
                              I could have used this when I was a student, as I had to do it manually for Urban Design class. You know, to decide which parts of a site to use for housing, which ones for parks, which ones not to use at all, etc.
                              -Miguel Lescano
                                riboflavele
                                I im trying to use this script, but i want to know its possible to change the colors and is it possible to know the slope % vs colors...? im not sure if my question is clear... Is it possible to have a legend or somthing to see for example that blue = 0% to 20% of slope and red = 40% to 60% of slope...
                                Sorry for my english...
                                  See
                                  mat.color=[(255-value),value,value]
                                  line #56~
                                  Sets the face color, value is set by the angle...
                                  Edit it there...
                                  • H
                                    halsktchup
                                    TIG, Chris,
                                    Thanks for the color by slope script. Like another person in here, I too am trying to see if I can get specific colors for specific slopes. Is there a later version to your script on smustard that contains this? For example if I need a certain red for anything above 20% slope, how do I get that?
                                    Thanks.
                                    • Chris FullmerC
                                      Hey, so far the script does not do that. I do plan on implementing it eventually. I've got a super busy week and I do not anticipate being able to look at it right away, but it might be easy enough to just tweak some lines of code to make it work how you want. Maybe by next weekend I'll be able to look at it.
                                        Hope I'm not standing on any toes... πŸ˜•
                                        ### edited/replace the code from here................
                                        faces = []
                                        flat = []
                                        angle = 0.0
                                        sel.each do |e|
                                          faces << e if e.is_a? Sketchup;;Face
                                        end#do
                                        ### first set up some [r,g,b] colors for various slope angles
                                        ### we use them if they exist, but if not make them...
                                        if not color_00_20 = model.materials["color_00_20"]
                                          color_00_20 = model.materials.add("color_00_20")
                                          color_00_20.color= [120,0,0]
                                        end#if
                                        if not color_20_40 = model.materials["color_20_40"]
                                          color_20_40 = model.materials.add("color_20_40")
                                          color_20_40.color= [150,0,0]
                                        end#if
                                        if not color_40_60 = model.materials["color_40_60"]
                                          color_40_60 = model.materials.add("color_40_60")
                                          color_40_60.color= [180,0,0]
                                        end#if
                                        if not color_60_80 = model.materials["color_60_80"]
                                          color_60_80 = model.materials.add("color_60_80")
                                          color_60_80.color= [210,0,0]
                                        end#if
                                        if not color_80_90 = model.materials["color_80_90"]
                                          color_80_90 = model.materials.add("color_80_00")
                                          color_80_90.color= [240,0,0]
                                        end#if
                                        ### you can adjust the colors' rgb values to suit...
                                        faces.each do |e|
                                          enorm = e.normal
                                          flat = Geom;;Vector3d.new(enorm[0],enorm[1],0)
                                          angle = (flat.angle_between enorm).radians ### angle in in degrees
                                          ### now set up the tests for different angles
                                          ### change these test ranges etc to suit your requirements...
                                          if angle>=0.0 and angle<=20.0
                                            color=color_00_20
                                          elsif angle>20.0 and angle<=40.0
                                            color=color_30_40
                                          elsif angle>40.0 and angle<=60.0
                                            color=color_40_60
                                          elsif angle>60.0 and angle<=80.0
                                            color=color_60_80
                                          else ### angle>80.0
                                            color=color_80_90
                                          end#if
                                          e.material = color
                                          e.back_material = color
                                        end#do
                                        ### end of edit/replace.................
                                        Make a backup copy of the original ruby script outside of the Plugins folder so it won't try load twice. If you mess up then you have the original to use again...
                                        Now edit/replace the version that's still in the Plugins folder, as set out above [open with Notepad.exe or equivalent plain-text editor].
                                        Save it and restart Sketchup - all slopes should now be colored in the angle-ranges and colors you've specified...
                                        πŸ€“
                                        • Chris FullmerC
                                          Nope, not at all! Thanks TIG,
                                            anilnimesh
                                            Color by angle by you is amazing...
                                            πŸ˜‰ rather i had changed name of the tool as 'Slope by angle' πŸ˜„
                                            wow! ur work is amazing.
                                            Please brief about color assignments in case of 'color by Slope'?
                                            About myself, i m an Architect from India and doing practice in Delhi.
                                            regards,
                                            Anil Nimesh
                                            • 1 / 3
