    Hide Toolbars On Load
    16 Posts 7 Posters 3.1k Views 7 Watching
      MartinRinehart
      This area looks like it was implemented by an engineer badly in need of sleep, no? Straightforwardly, you would have a toolbars collection and each would have a name attribute, no?
      If you don't mind losing the names, something like:
      toolbars = []
      UI.toolbar_names.each{ |n| toolbars.push( UI.toolbar(n) ) }
      I've done this. Turning off all toolbars (View/Toolbars menu) I ask:
      toolbars.each { |t| puts t.visible? }
      It prints "false" 13 times. Turn on a few toolbars, run it again and it still prints "false" 13 times.
      Has anybody sorted out what works and what doesn't here?
        simonstaton
        it seems like quite a few people are having this problemg
          Jim
          I'm happy it doesn't work. I would very much not appreciate it if your plugin messed with my toolbars.
            simonstaton
            I am in touch with abe from hypercosm and he seems to of done this with his viewer so maybe he can give me some insight
              MartinRinehart
              No you're not, Jim. Plugins are easy to delete, which I'm sure you'd do if some plugin author thinks he knows better than you what toolbars you should be looking at. But there's a lot of potential for plugins whose purpose in life is to let you organize your toolbars your way.
              Think about plugins specific to showing/hiding toolbars. I don't use toolbars (keyboard shortcuts rule!) but I'd like a tiny one that I could tailor to show stuff like an Add Scene and Update Scene at movie-making time and turn them off when the model's not ready for movies. I'd even like a button that turns the large toolbar on when I need no-shortcut stuff like Follow Me and the Protractor.
              And I'd like a plugin that converts the View/Toolbars submenu into a toolbar.
              • AdamBA Offline
                AdamB
                I'm with Jim on this. Sounds a like a disaster to allow plugins to impose their view on how the GUI should work.
                And if its just for something small - why do you not simply create your own toolbar for this? Then you can flash it on and off to your hearts content πŸ˜„
                Adam
                  simonstaton
                  well tbh I am changing the look of the GUI. I am handing out a copy of sketchup to our clients and it is going to have all of our 3d models in the components panel however we dont want them to be able to edit the components which we know some of them will end up doing with things like the draw tool. so we have built our own toolbar that exports the model as a jpg and can also add it to a shopping cart.
                    simonstaton
                    I am actually quite suprised at how hard this is turning out to be I thought it would be a simple one line code hideing a toolbar
                    • AdamBA Offline
                      AdamB
                      You might be finding it hard because you're trying to hammer a square peg into a round hole... Like anything you've got to play how a system wants to play rather than try and beat it into submission.
                      If you want to have a bunch of components that you don't wish to be edited permanently, then you install your Components in Sketchup.find_support_file 'Components' so they appear in the Component browser but are 'copy by value' when used so any changes don't mess with the 'original'.
                      Or ship your components all wrapped as 'Locked' Groups.
                      Adam
                        Jim
                        Have you considered handing out the SketchUp Viewer instead of SketchUp?
                        Nevermind - I see you would like to be able to run Ruby code too.
                          Seems that the Toolbar options like toolbar=UI.toolbar("Drawing");toolbar.show, .hide, .restore etc just don't work: also UI.toobar_names only returns the standard toolbar names not custom-toolbar ones... a whole messy method area in need of some TLC... 😞
                            @jim said:
                            The closest I've gotten to that is this:
                            UI.toolbar_names.each{|n| UI.toolbar(n).hide}
                            but it doesn't work.
                            UI.toolbar_names.each{|n| UI.set_toolbar_visible(n, false) }
                            UI.set_toolbar_visible works for the built-in Sketchup toolbars.
                            UI.toolbar works for Ruby toolbars
                            UI.toolbar Will never fail. If you use a name of a toolbar not present, Sketchup will create a new toolbar. !!!
                            UI.toolbar_visible? Works only for the toolbars returned in UI.toolbar_names
                            For Ruby toolbars you need to use UI.toolbar('Sandbox').visible?
                            I've seen in the Windows registry that Ruby toolbar names are mentioned in their setting section. Might be possible to extract a list there. Not sure how you query Mac settings...
                            This is also an option. http://forums.sketchucation.com/viewtopic.php?f=180&t=16756&p=132602#p132602
                            • Dan RathbunD Offline
                              Dan Rathbun
                              @simonstaton said:
                              ...now is there one of these [methods] that I can make that will hide the getting started toolbar on load? ...[snip]...
                              ANSWER: Yes there is !
                              The following code hides the "GettingStarted" toolbar at any time, whether it's docked or floating.
                              status = UI.set_toolbar_visible("GettingStarted", false)
                              I'm not here much anymore.
