    Hidden geometry help?
    3 Posts 2 Posters 465 Views 2 Watching
    • T
      tald311
      Greetings,
      I am having problems getting hidden geometry to become visible.
      On some components or even exploded components that are composed of many faceted faces, I try and unhide the lines. For example, if I take a 3D person, select the all the faces and edges (with hidden geometry turned visible, or not) and then try and unhide the edge, the hidden ones still remain hidden. Is there a way to make visible all the edges that composes faces?
      Thanks,
      Daniel
      • massimoM
        massimo Moderator
        Hi tald311, select your component then right click and select "soften/smooth edges". Then drag the cursor totally to left. Hope i undestood well your question.
        • T
          tald311
          Excellent! Thank you that worked.
          Daniel
