Importing CAD as Component?
Sometimes my ACAD imports are loose geometry, and sometimes they are Components. I don't see any specific option to control this, so why does this happen?
Ok, so it seems when I first start SU, the first import I do comes in as a Component. If I hit File > New, and do the exact same import the file is all loose.
A ACAD block, or xref will import as a component.
I noticed this too.
I've theorised that if you have existing geometry in the model it will group the imported CAD data into a component. If you have an empty model it comes in as loose geometry where only ACAD blocks are components. -
Opps, I should have read the question carefully.
Yup, thats right Thom. They said that they figured if you are importing into an empty model, they would not make it into a component. But if you are importing into a model that already has some geometry in it, then they would need to make it a component so it did not mess with existing geometry.
Good to know. In the past, when I imported dxf files into a empty file, Sang or his equivalent has always been present, and my files have always maintained their block/component structure, so it's something I have never noticed.
Anything else besides import origin, and units that I should be aware of?
Units and origin are the most important things. If screwed, these are the hardest to fix (although mostly can be)
But this is the exact opposite of what I experience. So I checked Outliner - and it turns out when I first open SU I have an odd, empty Group in my model. When I draw something, the Group disappears from Outliner. Ans when I hit File > New, it goes away also.
I deleted all my Templates sometime ago, so there are no template files available. So when SU starts with no template available, it generates a Group for some reason.
Sketchup Gremlins
I used to wonder why SU opened with Sang, and decided that it must have to do with initializing default conditions, and values. I once tried to customized opening SU with command files, special templates, and unique desktop icons, and had problems with drag and drop because of Sang, so now I use my system in the manner that SU intends.
