    [Plugin] Scale2Face.rb
    27 Posts 10 Posters 45.6k Views 10 Watching
      su30
      I used the script and followed the steps, but this happened every time,
      this is the feed back, please check the picture bellow:
      su30
        su30
        I'm getting the exact same problems ! I didn't before - I am investigating...
          Version 1.1 is here...
          http://forums.sketchucation.com/viewtopic.php?p=173374#p173374
          Fixed the glitch [I think]...
          Code was all messed up somehow !!!
            su30
            Here is a simple feedback of the script,
            scale items to a single slope.
            It works pretty fine with the boxes in group and component,
            but a little problem with 'Bryce', a face camera component.
            picture followed...
            su30
              su30
              This is another test for v1.1
              groups, components, single slope
              components are in different x,y,z position, and in different x,y,z scale,
              it proves good with these items.
              now the plugin works when only 1 face was selected, I don't know if it is possible to do it on multi faces or curve face,
              maybe you have already worked on it, TIG.
              Sorry that I can't reply on time because the time difference...
              su30
                I have considered multiple faces and have a draft almost ready...
                I don't know why 'Bryce' fails - I suspect it's because the face was originally draw flat on the Z plane and then tilts up to 'face-me' ? I'll look at it...
                In passing: I've also got an early draft for a 'Stretch2Face' Ruby that takes works with groups and faces; the topmost vertices of any vertical faces in the group get moved up to snap onto the face(s) selected - that way you could easily stretch the top of a wall face up to the underside of a sloping or even curved roof ?
                Thanks for the feedback, any other ideas or problems please let me know... πŸ˜„
                  su30
                  yes I am looking forward for the multi_face version
                  this script will be very efficiency while editing a big amount of components, and I think it is promising.
                  thank you TIG for the excellent work!
                  su30
                    su30
                    TIG, I am wondering if you have some process script I can have a try?
                    still watching this ^_^
                    su30
                      Very busy - maybe next week ? 😐
                        dtrarch
                        Hi All
                        Didier's [Project_faces_vector.rb] will put selected face on inclined plane.
                        Just draw a reference line vector in the direction wanted for projection path.
                        dtr
                          su30
                          Sure TIG, in no hurry πŸ˜„
                          su30
                            j_forrester
                            Great Plugin btw,
                            Just wondered if there are any developments of a version that takes into account a sloped surface instead of a flat plane?
                            Many thanks
                            • utilerU
                              utiler
                              @j_forrester said:
                              Great Plugin btw,
                              Many thanks
                              Ditto.
                              I think this would be neat!!!
                              Just Curious...
                                j_forrester
                                TIG,
                                Tried and tested.
                                Works absolutely perfect! Many thanks this will be a great help.
                                  At long last version v1.2 is now available.
                                  Link: http://forums.sketchucation.com/viewtopic.php?p=173374#p173374
                                  It Scales any Selected Component-instances/Groups up in Z to Selected Faces above them. It works for curved Surfaces, but remember that it Scales to all Selected Faces... so if you select a horizontal cylinder its whole curved Face gets Selected (which is actually Face facets) and therefore it Scales to the lower [nearer] Faces and then the upper Faces - if you want to Scale to just the lower [nearer] Faces you must first switch on Hidden Geometry and them Select just the lower Face facets required and it then Scales things just to those...
                                  Feedback please
                                  • olisheaO
                                    olishea
                                    nice plugin, thank you
                                    oli
                                      rv1974
                                      Tig it doesn't work within groups 😒
                                      And maybe clicking 3 points instead of face would be better solution?
                                      Thank you (I mean it!)
                                        Here's a Ruby that'll do it [please change the original post's title to [Plugin]...]
                                        . scale2face.rb
                                        Usage:
                                        Select face(s) & group/component-instance(s) located below face(s).
                                        Unacceptable selections produce error dialogs.
                                        Pick 'Scale2Face' off the Plugins Menu
                                        or type scale2face in the Ruby Console.
                                        The selected items will be
                                        scaled upwards [in the Z] until their CLs meet the face or faces.
                                        Any intermediate faces etc are ignored; the scaling passes through them.
                                        It has a one step un-do.
                                        To Do: Alternative orientations to just the UP in Z.
                                        E.G. down and in XY
                                        Version: 1.0 20090717 First Release.
                                        1.1 20090721 Tweaked to avoid height glitches.
                                        1.2 20090811 Multi-face support added. Error msgs disabled.
                                        1.3 20090819 Now works within groups/component edits.
                                        Put in Plugins Folder...PayPalButton
                                          It does work inside groups etc now !
                                          See here for v1.3 http://forums.sketchucation.com/viewtopic.php?p=173374#p173374
                                          Easy fix ray[1] .last gives face if in group/component edit mode... πŸ˜„ πŸ€“ πŸ€“
                                          • X
                                            xrok1
                                            don't know how i missed this one 😳
                                            Thankyou! πŸ˜„
