    Particle FX preview
    46 Posts 12 Posters 4.4k Views 12 Watching
      Aerilius
      I could imagine that it will have great realism, when you apply a radial png texture to the round faces.
      Just like this one:
      • W Offline
        Wacov
        SU has problems display textured transparency, and it'd be hard to position the texture. Plus, they're actually simple spheres πŸ˜„
          Aerilius
          Ok, I thought it would be "face camera" circle components. But maybe it would be worth a try to replace the spheres by other geometry. The plugin has really great possibilities!
            Physicsguy1
            Wacov, I'm not sure you have already devised this but I want to make sure. Can you code it to have the effects originate at a determined Point3D? Or code it so you can do something like this: SetEffect('smoke',[0,0,0])?
            • W Offline
              Wacov
              The code in the demo lets you choose where you place it, among other things. Once I get the final thing done, it'll be:
              createParticle([0,100,100])
              Giving only a position will create a construction point. Giving a position and radius will create the default black smoke, and you'll also be able to copy a custom group, or (maybe) choose between a few presets. You'll have the option to make your own update code for the particles, which will be executed along with the normal code.
                Physicsguy1
                could you possible have a direction for smoke and such? Like this createParticle([0,0,0],[10,10,10])
                • W Offline
                  Wacov
                  If you mean give it a velocity, sure, that's shown in the demo. Once I get the custom update working, you'll be able to make them do pretty much whatever you want 😍
                    JaViXP
                    Can you increase my FPS then? πŸ˜„
                    It sounds pretty cool. Can you upload another .skp model to see if it runs faster?
                    "Giving up is way harder than trying"
                    JaViXP's Rendering
                      CPhillips
                      You might want to check your video settings and make sure that you have Hardware acceleration turned on. Also maybe update your video drivers.
                        Physicsguy1
                        Now I have my FPS; 33.
                        • H Offline
                          hobbnob
                          forgive me for appearing stupid, but was it a mistake rollling back to rc1? i did this so tat i can upload to 3dwh, but there seems to be a lot going on here that i can't access because of my wish to remain on wh? i have tried running this demo in rc1 but i get an error message.
                          My WIP Thread:Here
                            phy
                            If you have a enough space on your computer, you can copy and paste the Google sketchup folder and install sp3X28 in the one sketchup plugins folder and the original sp3x in the other. be warned though thumbnails might not work correctly.
                            Tableau de comparaison de Staxyn s'agit d'un mΠ“Β©dicament uniquement sur ordonnance.
                              JaViXP
                              OH YEAH ! ! I got it running at 50 FPS
                              JaViXP's Rendering
                              • N Offline
                                NorviewsVeteran
                                I'm getting 30-35 fps. πŸ‘
                                //This_Is_All(I)+=Know()About.Code;
                                • 2 / 3
