    1.5k Posts 476 Posters 4.0m Views 476 Watching
    • fredo6F Offline
      Not completely sure it could be very useful in practical life, but I forgot to mention that the algorithm used by the script allows for custom profiles, under 2 conditions:
      • The profile must be symmetrical
      • it only works in Round mode (not in Sharp mode)
        Of course, I would need to build some GUI to design and select custom profiles.
        RoundCorner custome profiles detail 2.jpgRoundCorner custome profiles detail.jpg
        I enclosed a few examples in the attached SKP file (SU7 format).
      RoundCorner with custom profiles.skp
      • CadFatherC Offline
        CadFather
        ..amazing, Fredo. ๐Ÿ˜ฒ
        • boofredlayB Offline
          boofredlay
          This is absolutely beautiful, thank you.
          • urgenU Offline
            urgen
            ...cool! ๐Ÿ‘
            --pupil forever...------
            • W Offline
              watkins
              Dear Fredo,
              This is how it's done in Inventor
              and variable
              Kind regards,
              Bob
              • ely862meE Offline
                ely862me
                ๐Ÿ˜ฒ
                Another masterpiece!!Works like a charm!
                Thank you very much!
                Elisei
                Elisei (sketchupper)
                Come and See EliseiDesign
                • fredo6F Offline
                  @watkins said:
                  Dear Fredo,
                  and variable
                  Kind regards,
                  Bob
                  Apparently Inventor does just fillet, whether fix or variable offset. I have not seen the 3-direction rounding of corners. And the profile seems to be always an arc of circle.
                    remus
                    What a nice surprise ๐Ÿ˜„ Once again, thank you fredo, your hard work is always appreciated.
                    • ely862meE Offline
                      ely862me
                      only one small thing .. when making this fillet some holes becomes filled ..can this be fixed ?
                      • fredo6F Offline
                        Actually, it is Sketchup that automatically generate the faces. RoundCorner algorithm does not 'see' them.
                        I need to see if I can do something, but no guarantee!
                        • PixeroP Offline
                          Pixero
                          It would be great if the round corner could be turned off and just turn it on before render.
                          • W Offline
                            watkins
                            Fredo,
                            This gives more details on the fillet and chamfer options for Inventor
                            http://www2.ivcc.edu/perez/Placed%20Features.pdf
                            Regards,
                            Bob
                            • W Offline
                              watkins
                              Dear Fredo,
                              I forgot to say that I think you are absolutely brilliant! Thank you for all your hard work in not only writing these scripts, but documenting them so well. You really are a very generous chap.
                              Kind regards,
                              Bob
                              • fredo6F Offline
                                @watkins said:
                                Fredo,
                                Regards,
                                Bob
                                Thanks. Interesting, but my first reaction would be that I understand why some of you prefer Sketchup, which is so much natural to use for this type of shapes (except maybe for the variable radius filleting).
                                • W Offline
                                  watkins
                                  For the mechanically minded, RoundCorner is just perfect for all those radiussed and chamfered features. Setting the offset equal to the radius on the end of a pin will round the end of the pin beautifully.
                                  Using RoundCorner.skp
                                  • Bob JamesB Offline
                                    Bob James
                                    Just loaded this plugin for the first time. I drew a circle and, using the default parameters, clicked to proceed and got this ๐Ÿ˜ฎ
                                    Not sure what it is, but it sure neat ๐Ÿ˜‰ Black hole generator maybe. ๐Ÿ’ญ
                                    Now on to more serious testing. ๐Ÿ˜Ž
                                    • Jean-FrancoJ Offline
                                      Jean-Franco
                                      you have to change the default parameter (1000mm) to a smaller value or draw a bigger circle.
                                      Jean-Franco
                                        Bob James
                                        Yes, I knew that but just wanted to see what would happen with the randomly sized circle I drew. ๐Ÿ˜„
                                        Still a fascinating result!
                                        • fredo6F Offline
                                          Actually creating black holes and big bang effects was the primary goal of the plugin. It is just a side effect that it sometimes round edges and corners, but promised, I'll fix this inconvenience:D ๐Ÿ˜„
                                            Bob James
                                            Fix it? FIX IT??? It's perfect already ๐Ÿคฃ
                                            • 74
                                            • 75
                                            • 4 / 75
